09-04-2009, 01:11 PM | #1 |
Everything is work in progress
Hydroboost pump bracket. Wanted!
Converting my truck to hydroboost. I bought the replacement pump and now it won't fit my standard pump mounting bracket.
I'm looking for a mounting bracket to mount the hydroboost pump up high on the drivers side of my sbc 350. Any pics would help. thanks in advance.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
09-04-2009, 11:11 PM | #2 |
60-66 Nut
Re: Hydroboost pump bracket. Wanted!
Does your new pump use a remote reservior or is it on the pump?
Long water pump or short?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-04-2009 at 11:12 PM. |
09-05-2009, 12:16 AM | #3 |
Res is on the pump. The hydroboost res has a second return line on it, and thats what is in the way of my old mount. Also the res is slightly differently shaped. My Gen 1 350 has a long water pump
09-06-2009, 03:55 PM | #4 |
You can 'T' your return lines into one and use a single return port on your reservoir. I did so and have not had any trouble.
Custom Vehicle, Custom Problems. |
09-06-2009, 03:58 PM | #5 |
Pirate4X4 has a great article in their tech. section.
