Old 10-02-2009, 01:35 AM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
brake bleeding
ok i replaced my rotor and my caliper and i started bleeding my bakes but i think i must be doing something wrong im gravity bleeding them but there is just no way there could be that many air bubbles in that junk i sat there for about a half hour bleeding them and it was the same amount of bubbles every time and my brakes feel supper spongy like the truck stops but not very well at all...i have to stop it just to slow down...so is there any suggestions here on what i might be doing wrong
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 10-02-2009, 02:14 AM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: brake bleeding
I remember reading that it can take Hours to do. get your girlfriend to help and get it done in 30 mins. have her pump the brake a bunch of times and then hold it, you open the bleed screw and then close it. make sure she does not let back up when it bottoms out. do that two to three times a wheel and then see how it is.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 10-02-2009, 09:55 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: brake bleeding
exactly what ^^ said start with the wheel further from the master and work backwards.. unless you opened the rear system or the master ran dry you dont need to bleed the back so just the right front then the left front
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-02-2009, 12:50 PM   #4
mbgmike
Re: brake bleeding
Here is the correct way to bleed or remove fluid vapor from brake lines.
Jack the whole vehicle up on jack stands (or a lift) and remove all four wheels.
install one lug nut at each corner and tighten it up against the rotor surface to limit caliper flex. To limit the flex that you may feel in the pedal.
check your fluid in mc and keep it on the max line.
Begin at the furthest corner from the mc and progress to the driver. RR,LR
RF,RF etc
Install your jar or whatever with clear hose. and place it above the drum /rotor.
Have your wife or whomever apply the brakes 3 times and hold the pedal down. Don't let them release it until you tell them to. Open your bleeder for a couple seconds. Don't leave it open as only a few seconds is needed.
Tell them to release the brakes. Keep doing that until you can see no more bubbles in the hose.
Check your master cylinder.
Keep doing it on all four until your finished and clean up all the bleeders with fluid and then check for leaks..
check you pedal and it should be firmer. If it is still mushy it may still be pads that are tapered or other brake component problem. Recheck you bleeders for leaking.
Put all your wheels back on and level the car , leave it off and apply the brakes a number of times.
You should be good to go.
I know you probably know this but sometimes people don't. If you still have a problem with soft pedal there could be problems elsewhere.
Many times soft brakes are not caused by air leaks. It can be from fluid vapor being released when the fluid is being compressed. brake fluid can get over 300deg for most street cars. It doesn't take much vapor to lose efficiency.
mbgmike is offline   Reply With Quote
Old 10-02-2009, 05:19 PM   #5
LONGHAIR
Re: brake bleeding
I would love to see an explanation of this one......
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-02-2009, 05:27 PM   #6
mbgmike
Re: brake bleeding
Straight out of GMI
Old 10-02-2009, 05:52 PM   #7
old Rusty C10
Re: brake bleeding
thats for a front wheel drive car not for a truck like ours
Bob
I hate cancer!!
Old 10-02-2009, 06:03 PM   #8
mbgmike
Re: brake bleeding
its for disc brakes
Old 10-02-2009, 06:36 PM   #9
3r!c84
Badass
3r!c84's Avatar
Re: brake bleeding
not for hub type rotors
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 10-02-2009, 06:43 PM   #10
Prerunner1982
Prerunner1982's Avatar
Re: brake bleeding
I recently replaced the pads and rotors on my Jeep Cherokee and had to bleed the brakes myself. The best way I have found to do it is to get a small jar (I cut the top off of an old brake fluid bottle) and a piece of hose. Connect the hose to the bleeder valve, put some brake fluid in the jar. Insert hose into jar and make sure the end is submerged. Open bleeder and pump the brakes slow and easy. It worked great.
Since you replaced the caliper and really opened up the system I would bleed all 4 corners to be on the safe side.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 10-02-2009, 07:10 PM   #11
mbgmike
Re: brake bleeding
I think I will just quit posting anything
Old 10-02-2009, 08:56 PM   #12
pokethesmot
Re: brake bleeding
i tried the pumping 3 times and then holding the pedal down while i loosen the screw but no air came out then i let it gravity bleed and tuns of air came out my gf said that as soon as i loosened the bleed screw the pedal hit the floor so i guess ima give gravity bleeding another try or try the pumping it with the hose in a jar thing and thanks for the help every one
Old 10-02-2009, 08:59 PM   #13
3r!c84
Badass
3r!c84's Avatar
Re: brake bleeding
is it full of brake fluid?
and is the lid on?
-00 Saturn 5spd
1/4:13:90
Old 10-02-2009, 09:18 PM   #14
pokethesmot
Re: brake bleeding
and is the lid on?
its full of brake fluid and the lid is on except when i gravity bleed it cuz it makes it easer to fill up
Old 10-03-2009, 10:21 AM   #15
old Rusty C10
Re: brake bleeding
Mike i hope you are not offended at what I said but i can't for the life of me figure out what a lug nut is going to do on a rotor that is fixed in place by the lock nut on the front of the spindle... the only time there is play in a rotor is in the front wheel drive where it lays on the lugs and is held in place by the wheel and the caliper this could also be said of a rear disc system but again neither of these is standard on our trucks
Id be curious to find out what the reasoning is behind this... hey im 45 and am willing to learn anytime.. there was no sarcasm at all in my post
Bob
I hate cancer!!
Old 10-03-2009, 12:27 PM   #16
pokethesmot
Re: brake bleeding
welp it looks like ima go out side and try brake bleeding again lol
Old 10-03-2009, 02:37 PM   #17
pokethesmot
Re: brake bleeding
yeah ima have to get some one to do it that has a vacuum bleeder cuz the only thing that looks like its workin is gravity bleeding and i sat out there for an our with tons of bubbles and still no progress
Old 10-03-2009, 02:45 PM   #18
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: brake bleeding
Make sure you have the rear brakes adjusted up also,that will affect pedal height
powerdriver 1958 is offline   Reply With Quote
Old 10-03-2009, 06:59 PM   #19
donut
donut's Avatar
Re: brake bleeding
You can also get a little 1 man brake bleeder setup (I think it's in the HELP section @ most chain parts stores) Teeny little bottle with a hose, same principle as Prerunner mentioned. Saved me a lot of hassle when I did a caliper, brake lines, and wheel cylinders in one shot. I also took my time doing it. I did all four corners, topped off the fluid, waited a few hours, did it again. (my thinking on waiting was for the smaller bubbles settle out.)
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-03-2009, 08:12 PM   #20
pokethesmot
Re: brake bleeding
how do i do that lol
Old 10-03-2009, 09:06 PM   #21
powerdriver 1958
Kid's Mechanic
Re: brake bleeding
Sorry that should have been make sure the REAR brakes are adjusted up snug
Old 10-03-2009, 09:19 PM   #22
powerdriver 1958
Kid's Mechanic
Re: brake bleeding
Poke,the best way for you to do it is pull the rear drum off and turn the adjuster a couple of clicks then slide the drum back on.do that until the drum has a real small drag on it.you will be some what close
Old 10-03-2009, 10:40 PM   #23
pokethesmot
Re: brake bleeding
thanks every one for the help and i should have my brakes bleed soon cuz i got a guy with a vacuum bleeder thats gunna do it lol and i think i probly should adjust my rear brakes cuz when im in 4lo my back wheel spins lol
Old 10-04-2009, 05:22 PM   #24
pokethesmot
Re: brake bleeding
well i tightened up one wheel and wow what a difference thanks again everyone ima be doin the other one in just a little bit
Old 10-04-2009, 05:37 PM   #25
74 C-30
Dually Pride
74 C-30's Avatar
Re: brake bleeding
just a trick to share if youre having issues bleeding brakes, or if you cant get the bleeders open, take the cap off the master cylinder and with your hand, ease the brake pedal to the floor, then jerk it back up quickly. thats how I did mine thanks to years of new england rust raising hell with the bleeders and brake lines
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
