![]() Join Date: Jul 2009
72 jimmy to 67 chevy blazer
well I am going to get started parts are coming in started to take apart 67 lets see if I can load pic?
![]() Last edited by ClifBlazer; 10-21-2009 at 01:14 PM. Reason: add pic. |
Re: 72 jimmy to 67 chevy blazer
got bed off by my self a challang to say the least
heres the plain take 67 truck and remove body clean up frame change brakes and drive train put jimmy tube on after body work here pic. of jimmy its in a barn with suff stacked all around it.well I quess not won't load?
67-72 parts collector,…
![]() Join Date: Nov 2002
Are you putting a Jimmy tub on a 2wd shortbed frame?
I assume you know the wheelbase is different?
11'' shorter in between cab and wheel well not shore where to cut out figered I'd find out when tube and frame meet
![]() Last edited by ClifBlazer; 10-22-2009 at 02:50 AM. |
looking forward to seeing this you should be able to sell the bed try puting it up on craigslist
70 SWB STEPSIDE 70 BLAZER 09 challenger |
lolife have you done this frame cut or have you seen a thread that shows it
![]() Last edited by ClifBlazer; 10-23-2009 at 04:08 AM. |
more pic. of jimmy have to reduce them to fit
No, I haven't seen this done. All the body mounts will have to be moved on the new frame.
I think it would be easier to add 2wd front suspenion to the original blazer frame. Many people have done this "conversion".
any body seen a p/s pump like this?
Too Dumb To Know Better
Good grief, how many mirrors did that blazer have?
SO WHAT DO YOU THINK Ive had this 72 blazer 4wd one owner truck thats tub is les than all there, no rocker box d/p side ,floor pans = to most I see ,supports half there so tube is ruff .
#15 |
And
#16 |
Don't cut the short wheelbase frame.
Find another 4x4 blazer frame to convert. I wish I had something to trade for your stepside. I have complete disc brake front crossmembers if you need one for your conversion. Also trailing arms and crossmembers. Do yourself a favor,... and find another blazer frame.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-25-2009 at 09:28 AM. |
#17 |
Thanks for input lolife you have good point swb frame is much better THan cutting down a lwb Besides the cab isnt so bad but the roof and drip rail are going to need work po did floors but didn't do kicks with the floors WHY do they do what they do? Your there and not do all thats needed done
#18 |
floors buy the p/o
#19 |
not going to cut swb frame may destroy 4x4 and make it a coil over frame. if I cant find one thats more in line to use ( broken axal bad t case or just a good deal) watchin C L
#20 |
HERES A THREAD I FOUND ON ADDING TRAILING ARMS TO A 4WD BLAZER FRAME YOU MAY BE INTERESTED http://67-72chevytrucks.com/vboard/s...d.php?t=218156 I GOT A 70 BLAZER IM DOING LIKE THIS
#21 |
thanks I think I got a frame Oboy
#22 |
Im going to get the frame from teeitup tommrow 72 jimmy 4x4 so know cutting swb truck [dont worry I have planes for it ]pics will come with frame
![]() Last edited by ClifBlazer; 11-13-2009 at 08:02 PM. |
#23 |
well parts shopers build for blazer is on hold so short bed has been getting some atinchin
#24 |
found rust in coul lets start cuting it out
#25 |
and windshild frame
