#51 | |
DON'T TREAD ON ME
![]() Join Date: May 2005
Re: Engine Starves for Fuel When I Hit Second Gear
![]() TTT, but I've got three sets of fouled plugs to show for it. BTW, I've been looking on the net for a Holley fuel pump rebuild kit and found one place that sells it. The reassembly instructions I posted earlier are for a totally different designed pump from Edlebrock. If you are supposed to do the same thing to the Holley it Pisses Me Off that they don't tell you about that in the technical information on the Holley website.
Old Yeller |
#52 |
the idle deal could be a timing/carb issue. but thats the least of your worries right now. better to knock out one thing at a time. I just searched around and cant find any kind of info on that holley but the edelbrock and holley are almost identical very very similar design i would assume the procedure should be the same. found this on holleys website http://www.holley.com/data/Products/.../199R10478.pdf
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#53 |
DON'T TREAD ON ME
I took the plug out of cylinder number one, had someone turn the engine over till the compression blew my finger off, dropped the dizzy in where it pointed at cylinder one. Timing should be correct.
Old Yeller Last edited by Old Yeller 1970; 10-19-2009 at 09:38 PM. |
#54 |
theres one problem. you need to set timing with a light thats why it wont idle below 1k rpm. probably dont have near enough advance at idle.
#55 |
![]() Join Date: Jul 2008
What cam is it and what jets are in the carb front and back?
Built chevy tuff! ![]() Last edited by Rodms; 10-20-2009 at 12:01 AM. Reason: spell |
#56 | |
DON'T TREAD ON ME
What cam is it? It's all in the sig and in previous posts but here it is again. It's a Competition Cam 280 Magnum ground on a 114 LSA. 230@.5" Jets are the factory setting. I don't remember exactly at the moment but it's available on BG's website.
Old Yeller |
#57 | |
Built chevy tuff! ![]() Last edited by Rodms; 10-20-2009 at 12:37 AM. Reason: question |
#58 |
DON'T TREAD ON ME
Yep, me too. I had the engine built and fired the first time 4 years ago. I ran it altogether for about 1-2 hours. While it was being painted and other wise sitting in limbo waiting for more time, money and other parts, I learned about cams being wiped out because the govt made the oil companies take out zinc. I bought a bottle of the additive and put it in. There's not much I can do now. If the cam is going bad it's going bad. The only way to find out is to run it.
The springs in the heads are plenty stout.
Old Yeller |
#59 |
Yeah but can be to stout!
Built chevy tuff! ![]() |
#60 | |
DON'T TREAD ON ME
In an earlier post I stated:
Old Yeller |
#61 |
DON'T TREAD ON ME
Finally got it running yesterday. Dang these projects take forever. I bought a rebuilt Holley 4160 - VS 750 CFM. I got the manual choke installed too. Now it will crank and idle even when it's 25F. It idles at about 700 RPMs now too.
So what happened in second gear, you ask? Power, lots of head snapping power. There's no stumble, no bog or anything. It hits hard and keeps right on pulling. It also pulls a few more RPMs on the top end. I think the larger carb is letting the engine breath a little better. Power off the line is great too. Everything hooks up good and runs out hard. I definitely enjoyed some adrenaline last night. ![]() PS: I bought the carb off ebay from musclecarexpress for $169 + shipping. If anyone else is looking for a good deal on a carb, I'd recommend their services.
Old Yeller |
#62 |
motor exploder
Glad to see you got it all together and singing the same tune!
so, uh, where's the burnout video???? ![]()
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
#63 |
DON'T TREAD ON ME
Old Yeller |
