10-25-2009, 05:31 PM | #1 |
Old School, New Style
Re: Project: Agent Orange
Might be time to just sit down for that one. Bonus it keeps the ladies happy
The Good: - 72 GMC Jimmy 4x4 - 307 cid / 350 th - 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th - 96 Chevy Impala SS - mainly stock - 98 Chevy Tahoe LT 4x4 - all stock The Bad: - 86 Chevy Suburban 1/2T 4x4 - winter beater The Ugly: - 72 Chevy Suburban 1/2T 2wd - parts truck |
10-25-2009, 06:06 PM | #2 |
11-01-2009, 08:01 PM | #3 |
I just now noticed that you have two flavors of Lizard skin....sound control and ceramic insulation. What's the order? CI, then SC? Or can you mix them?
11-01-2009, 08:16 PM | #4 | |
Thanks, any progress over the weekend?
Thanks, anything new up your way? Quote:
They say the ceramic coating is thinner and lays down better, supposed to fill some of the pockets...so they say. Sprayed the 2nd coat HEAVY, might be thick enough now. Hope so, getting up under that dash just isn't all that much fun at all. |
11-01-2009, 10:50 PM | #5 |
11-01-2009, 11:41 PM | #6 |
GEARHEAD
The masking would probably be easier if you used plastic sheet instead of newspaper. I'm not saying, just saying, ya know...
Looks like a good result though, the name definitely fits the finish.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
11-02-2009, 12:17 AM | #7 |
SWB 4x4 Collector
Plastic sheets are not the best for using as a masking barrier. Paint can "sit" on top of it unlike a paper barrier where it absorbs and dries. When you go to pull plastic off you can leave paint chips or even paint that isn't dry onto your new paint job. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
11-01-2009, 08:05 PM | #8 |
lookin good ive always wanted a cali top blazer
Built not Bought |
11-01-2009, 08:29 PM | #9 |
"something witty here"
subscribed love these blazers to death! that lizard skin looks great too! What are you goin to do for a tranny transfer crossmember? I ask because I found a good 700r4 and 241 and Im not to sure what to use...
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
11-01-2009, 08:32 PM | #10 | |
Lizardskin is looking good. A little more cottage cheese than I expected though. |
11-01-2009, 08:55 PM | #11 |
I wasnt sure if it would line up, the crossmember on the burb its in right now is different then how ours looks so I just wasnt sure if I needed a new one, thanks AJ
11-01-2009, 11:17 PM | #12 |
VA72C10
In
Looks like a cool project and great work so far!
Looking for a 67-72 swb or blazer project in or around VA. |
11-02-2009, 09:09 AM | #13 |
I feel sorry for the guy that has to scrape that off, in 100 years!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
11-02-2009, 09:35 AM | #14 | |
With luck, it'll be one of my great grand kids! Never thought I'd do this to a truck but in this case, it made good sense for the intended use & abuse it's going to see. Build em to drive em baby! |
11-02-2009, 09:38 AM | #15 |
Looks good! What is the cure time on that stuff - does it need heat to dry out - since it isn't that warm here (or there) much longer -
11-02-2009, 09:57 AM | #16 | |
First coat seemed to dry enough to spray over in a couple hours, heat was @ 65 degrees in the shop. I used a heat gun a little bit to help it along so I could spray the 2nd coat before ending my day in the shop, only had to hit the nooks & crannies. the flats were dry. I applied the 2nd coat really heavy and there's still a couple places were it hasn't dried yet and I kept the shop @ 60 degrees all night. Going to leave the heat @ 60 with hopes of being able to apply the ceramic layer tonight after work. Haven't decided if I'm going to apply color to this section while it's masked off or whether I'll continue onto the bed area with the liner, at least spray color on the firewall & under the dash to avoid over-spray later I'm thinking. Last edited by vtblazer; 11-02-2009 at 09:58 AM. |
11-02-2009, 10:33 AM | #17 |
Does that stuff come in colors or is it only gray? Looks good VT!
11-02-2009, 09:32 AM | #18 |
That is a big difference. Looks smoother.
11-02-2009, 09:37 AM | #19 |
11-02-2009, 11:13 AM | #20 |
The thing that turned me off about the lizards skin is the fact that it is sandable. That just makes it sound like it wont last as long as bed liner.
11-02-2009, 06:11 PM | #21 |
Whats the surface like after it dried? Is it hard, or more soft and rubber like?
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
11-02-2009, 07:36 PM | #22 |
That really looks good dude!
11-02-2009, 10:57 PM | #23 |
Junior Member
Looks good.
1967 Camaro (in pieces) 1972 Chevrolet K/5 Blazer 1969 Chevrolet K/5 Blazer 2000 Chevrolet K2500 Crew Cab 454 1999 Chevrolet Blazer 2008 Polaris Ranger XP Orange Crush |
11-03-2009, 01:05 PM | #24 |
Some how seems brighter in the shop now...
Base coat, still wet but ya can get the idea. |
11-03-2009, 01:39 PM | #25 |
Had to air out the shop...
