Closed Thread
Old 09-15-2013, 09:58 PM   #1
Chevy Fleetside
Chevy Fleetside's Avatar
Re: What did you do to your truck today?
today I drove up the shop and grabbed the carb off the other truck and put it on my 65. The one I had on there i got at 1/2 price day at pick and pull, it seemed to be a rebuilt carb since it was clean and had a tag on it. Well it was giving me nothhing but trouble so I swapped it out to the one I knew was good and it runs good. Just need to do alot of small adjustments to it. Well after that I drove it around the block.. oh yeah more then once.. Looks like with the BB in there I have more rake now.. I think I like it as a Fleetside instead. The pic of it being a stepper is with a SB in it. I didn't change the stance at all.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 09-15-2013, 10:47 PM   #2
niterider65
niterider65's Avatar
Cool Re: What did you do to your truck today?
spent some time in shop and dang guess H E double tooth pick must have froze over . i got 2 things done . primed the frame and painted it .I must be sick . dang what next put it back to gether
niterider65 is offline
Old 09-15-2013, 11:45 PM   #3
DexterDog
DexterDog's Avatar
Damn double post.
DexterDog is offline
Old 09-15-2013, 11:52 PM   #4
DexterDog
DexterDog's Avatar
Today, I flipped my whites out and repainted the wheels. Best $10 spent so far.
BEFORE
AFTER
[/URL]
Old 09-17-2013, 12:55 PM   #5
gmcdeadhead
gmcdeadhead's Avatar
finished up the power steering and front end conversion. 100% better stopping and steering. capt fabs brackets were the best. [IMG][/IMG]
gmcdeadhead is offline
Old 09-19-2013, 01:43 AM   #6
donthekawguy
donthekawguy's Avatar
I went out to put the center wood pieces in my bed today only to find out that they were too wide. Grrrrrrrr I cut them to the width listed on GMC Pauls website. I ripped them down and put on more urethane. Then the rain started so I will have to wait till tomorrow to put it together. My son is coming to help so it should go pretty fast. My plan is to get the wood in loosely tip it back up on end, make sure it's square then tighten it all down while my son feeds the bolts through from the other side. I'm still going to have the bolts that hold the bed to the frame hidden. I want to be driving it by tomorrow night!
66 shorty
donthekawguy is offline
Old 09-19-2013, 07:58 AM   #7
robber grin
Jim - motor looks bad-@$$!
I too used those dimensions and I was wondering if the chatter I had heard from time to time about final fit had any merit - now I am concerned it did.
Going to do a dry-run with un-finished boards and go from there...
I'm still doing body-work on my much abused cab roof panel.
Ray and I went to welding supply yesterday since he needed a chipping hammer for tech-ed and filled all the bottles, got the hammer, then putted over to pick up some white single-stage enamel and odds and ends at the paint supply. Costs are getting sick...
dexter - I'm LOVIN your truck! Thanks for posting pics. Fun times for sure.
back to the truck -
rg & ray~ray
robber grin is offline
Old 09-20-2013, 02:05 PM   #8
donthekawguy
back to the truck -
rg & ray~ray
If I was going to do it again I would cut the boards to length, rip them to width, put them in place with the strips on and a few bolts through the holes and make sure the widths were correct. Then I would mark all of the lengths with a penic for the dado cuts. Another problem I'm having is the dado's are too far in so the strips don't fit right. I got most of them to fit right but a couple are noticeable. The 3 rd board from the right is the worst one. I might have to redo it.
66 shorty
Old 09-20-2013, 05:08 PM   #9
mud.man.rj
mud.man.rj's Avatar
Have never installed a wood bed floor, sounds tricky for sure, like need a lot of patience.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 09-20-2013, 06:16 PM   #10
donthekawguy
It's really time consuming but not real bad. I'm stuck where I'm at now due to needing help and everyone is at work. lol
66 shorty
Old 09-20-2013, 09:52 PM   #11
jayoldschool
Moderator
Step or fleet? I used their Fleetside dimensions, and they were right on.
jayoldschool is offline
Old 09-20-2013, 10:30 PM   #12
donthekawguy
I have a fleet. I'm sure I used the right ones but my bed is all messed up so who knows. I put it back on yesterday and two of the holes didn't even come close to lining up even though it's straight and square on the frame. I just drilled out new holes and said to hell with it.
66 shorty
Old 09-20-2013, 11:17 PM   #13
jayoldschool
Moderator
Here's how mine turned out:
Old 09-19-2013, 09:39 AM   #14
Woogeroo
Yesterday w/ my '65 c10 :
changed the oil/filter and lubed up everything. changed the air filter out, checked all the fluids and things while I was dirty.
major adventure : old grease gun started leaking the grease out the end, except it was in a liquid-y mess! Never had that issue before, I'm suspecting it's some synthetic-y lube, it's a reddish color... what a mess!
old trucks are fun!
-W
Woogeroo is offline
Old 09-20-2013, 08:05 AM   #15
robber grin
Spread Icing and block-sand.... repeat... spread more Icing and block again... and again... and...
Teaching my son (+ myself) patience - 90% preparation right.
rg
Old 09-20-2013, 08:26 AM   #16
T Smith
T Smith's Avatar
Put my headers on, headed to the muffler shop in the morning. Originally planned to just hook up the existing pipes but think I'm going to have him run all new stuff all the way out.
T Smith is offline
Old 09-20-2013, 11:20 PM   #17
Turtleman
Turtleman's Avatar
WOW... You folks do allot on your trucks..
I just drive mine
Turtleman is offline
Old 09-21-2013, 12:37 PM   #18
robber grin
Turtleman - out of necessity! I can't wait to join you driving mine!
Roof body work is getting there and in primer again.
Windshield is IN!
I still need to find a big back window - mine was wrong...
liv'n the dream
rg & Ray~Ray
Old 09-21-2013, 01:57 PM   #19
Ta2Don
Ta2Don's Avatar
Windshield is IN!
liv'n the dream
rg & Ray~Ray
Looking Great!!!
Do you have a build thread?
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline
Old 09-21-2013, 04:08 PM   #20
robber grin
Hey Don -
I don't have a build thread and sometimes I wonder if I should have started one - but thanks for asking.
Bob / robber grin
Old 09-21-2013, 05:15 PM   #21
mud.man.rj
mud.man.rj's Avatar
nice truck T Smith, you are sure right on the difference from manifolds to headers, sounds so much better plus the HP diff.
5.0 4spd std.
7" lift w 35's.
Old 09-22-2013, 01:03 PM   #22
luvbowties
luvbowties's Avatar
Smile Re: What did you do to your truck today?
Windshield is IN!
liv'n the dream
rg & Ray~Ray
Hey, RG, I'd bet your back glass was too thick!?? I bo't one from an on-line vendor, and it was made from safety glass--that kind that busts into bigger shards when crashed, quite dangerous as they cut easily. I quickly realized it should've been made of much thinner tempered glass--the kind that breaks into tiny little chunks when crashed. These do not cut.
Sam
luvbowties is offline
Old 09-23-2013, 09:56 AM   #23
robber grin
Sam
Hey Sam - my truck's window was shattered before I got it. The guys I got it off of gave me another window for it, but I think it was for 67-72 because the bottom corners were "square" and not rounded. I never even caught it until we went to put it in the 62.
I specialize in doing things that way... "2 forward - 3 back Truck Shop".
bob
Old 09-21-2013, 04:07 PM   #24
donthekawguy
I didn't like how one of the boards looked and fit so I got another one. I got it cut and stained so far and will have it cleared in a bit. It fits alot better and I can live with it. Hopefully my son will be able to come over so I can tighten the rest of the bolts down and get it on the road.
66 shorty
Old 09-21-2013, 01:52 PM   #25
Fastest32
Fastest32's Avatar
20 bucks @ the pick n pull the other day.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline
Closed Thread
