04-16-2003, 07:35 PM | #1 |
Fabricate till you "puke"
Heating springs is bad news......the heat changes the properties of the steel(no longer a spring). You will be at risk of breaking the spring, & setting a corner of the truck on the pavement(YIKES!) For your own saftey as well as others.......dont do this! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
