3rd brake light
where would I need to wire a 3rd brake light to? I know it cant be the tail light wires or it would blink with the signals. I am thinking I need to come off of the brake light switch.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club Last edited by Jwill41; 04-18-2003 at 01:52 PM. |
L.E.D. Freak
I make Custom LED Third brake insert with in a brushed aluminum channel. Any # of LEDs or lengths. Also the Cargo third brake insert that will be in production shortly.
Yes you need to ground the third brake to body/chassis, then run a power wire directly off the brake pedal switch.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
Dad's little helper
I wired mine into the brake light switch and it seems to be doing just fine.
kinda gives a unique look to it, doesnt it. ![]() |
L.E.D. Freak
If you jumper it off the regular tail light it will flash with turn signal also.
Dad's little helper
I jumped mine off the brake light switch and that way it does not blink w/ turn signals.
67-72 Addict!
What would be cool is to have half of it blink with the turn signal also. Don't know if that would be legal though.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
L.E.D. Freak
Yeah it's legal. I can make one like that. I was thinking more on the lines of having the last 6 LEDs to the right and left be amber. and the center section just red, with parking/brake function.
