11-22-2009, 07:08 PM | #1 |
FS '67 Power assist.
Power assist from 1967, C10 Custom. Pump, hoses, cylinder, cylinder mount brackets, hose brackets. I have everything from steering box to idler arm; I saved everything I could nuts, bolts and washers. The engine was not in the truck when I got it but, I was told it was a 327 the truck did however, have the correct 64 – 67, 400 turbo. $150.00 plus shipping or best offer, I will trade, what you got?
Please reply in this thread to reduce confusion and maintain the integrity of this forum. I’m headed to “grandmother’s house” for Thanksgiving; if you're anywhere in North Carolina, South Carolina, Georgia, eastern Tennessee or Alabama, I’ll bring this to you. Dasani |
11-22-2009, 07:17 PM | #2 | |
Re: FS '67 Power assist.
11-22-2009, 07:22 PM | #3 |
11-22-2009, 08:21 PM | #4 |
I'm interested this will work on 67 with no power steering -?
Thanks |
11-22-2009, 08:35 PM | #5 |
Yes, but if you're not a purest you can use a later pump and box (which I have) if you have the clearance “divit” in your frame.
11-22-2009, 08:58 PM | #6 |
Dasani,
I'd like to be first in line pending more pictures, Thanks |
11-22-2009, 09:00 PM | #7 |
11-23-2009, 09:28 AM | #8 |
bump
11-23-2009, 11:18 PM | #9 |
11-23-2009, 11:24 PM | #10 |
Thanks will check now,
11-24-2009, 12:02 AM | #11 |
Tom,
I checked my frame and don’t see indentation, I forwarded you some pics, I guess it won’t work? If so, I will have to pass on it for now until I figure out how to make it work. Thanks |
11-24-2009, 02:13 AM | #12 |
I Like Mine With No Shine!
All you need it some spacers...ie washers to make it work on your frame. Or you could heat and beat the indents in. Or you could buy an aftermarket adapter kit to make it work. Just FYI mike1234.
Michael 1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day) 2006 GMC Sierra Crew Cab 4x4 1969 Lincoln Continental Coupe Project FOR SALE http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 1981 Honda CM400 C Bobber SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
11-24-2009, 06:48 PM | #13 |
Thanks for info, Michael
Tom I will have to pass on the power steering assembly, something came up financially and won’t be able to purchase. Luis |
11-24-2009, 08:32 PM | #14 |
11-28-2009, 06:20 AM | #15 |
bump
11-28-2009, 10:51 AM | #16 |
Dasani, I think you have some conflicting info in this thread. To run this style of power steering on a 67, you do not need the frame indentation right? This power steering setup if for a stock 67, which does not require any modifications to the original frame.
If you are running the later style, then you do need the indentation.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
11-28-2009, 01:06 PM | #17 | |
Sorry for any confusion this might have caused.
You are correct, this uses the manual steering box therefore, does not require the indentation in the frame rail. This is a bolt in for those early ’67 frames which did not have the indentation. Quote:
12-01-2009, 09:27 PM | #18 |
12-02-2009, 01:06 AM | #19 |
Dasani, Where is Grandmothers' house?
12-02-2009, 11:23 AM | #20 |
12-02-2009, 12:40 PM | #21 |
Lincoln, kewl. i was just curious. i am in south Alabama...
i am sure someone will need this 67 Power Assist.... ttt for ya.
12-02-2009, 01:20 PM | #22 |
12-02-2009, 03:04 PM | #23 |
hard to tell from the pics but how does this attach to the steering linkage?
thanks
1963 C10 swb fleetside 1966 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
12-02-2009, 03:37 PM | #24 |
12-02-2009, 03:51 PM | #25 |
thanks, sending a pm rather than fill up your thread.
Scott
