Electric Wiper Conversion on the cheap
Here are the details of my recent conversion from Vacuum to Electric wipers on the Cheap! The idea was to convert from vacuum to electric wipers on my 48 Chevy without breaking the bank. Here are several pictures that show the process. I did it all for $20.50.
Here is a picture of a rear wiper motor from a 93 S10 blazer and switch, paid $20.00 ![]() Here is the brace that goes from the dash to the firewall, mine had 2 holes drilled in it already that would end up working well to mount my bracket. ![]() This is a picture of the bracket I made out of some scrap and how I mounted it on the motor. I put rubber washers behind the bracket on the bolts to keep the noise down ![]() Then I cut a piece of 1/2 wide steel and drilled some holes in it to run bolts through that would adapt to the wiper mechanism. I would suggest slotting the holes or drilling several as you will need to adjust and tweek when mounted to get the correct wiper sweep on your windshield. I got a nylon bushing at the hardware store for .50cents and cut it in half to make a bushing that fit nicely in the wiper arm so that it would all pretty well copy the original design ![]() Then cut the end of the windsheild wiper off so that I had the knurled end to fit on the Blazer wiper motor. I beveled the piece with a file and drilled a hole it it to hold the actuator. The bevel helped recess the 1/2" steel so it could not move once bolted on ![]() ![]() Then put the assembled wiper motor with bracket on the brace under the dash, marked the holes where to drill in the bracket. I used the existing holes in brace on the dash so I did not even have to drill into the truck at all. I would suggest you slot the mounting holes in the bracket as well. Makes adjusting everything easier once you get the linkage all hooked up ![]() I put rubber washers under the bracket as well to keep any noise down. And here is pretty much the finished product. Mounted and very quite. ![]() Hope this helps any of you interested. |
Re: Electric Wiper Conversion on the cheap
Good write up with good pictures. One question. Does the cut wiper arm mount on the motor shaft with a friction fit? Or is there a set screw that does not show up on the pictures?
This model pretty well had a friction fit, I may put a set screw in it or a little Loctite.
![]() Join Date: Oct 2007
finally a great alternative to buying a kit. i love the fab you own on the cheap. great write up. i will be doing this as soon as i get a day off work to go to the junkyard and get a motor.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
Registered Chevy Owner
Glad to see some one did a write up on this. I've been wondering how to do it for a while. Thanks!
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
I gotta agree with others, thanks for the write up.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
The high dollar aftermarket guys are going to start getting cranky about these cheap fixes, first one piece windows, now this. Sort of like the beginning in the 50's when everyone had to improvise.
#8 | |
amen to that. i'm with nickp51chevy on that!
I agree nice pictures. How did you get the length between the 2 connectors, was there a lot of trial and error?
I tried to copy the distance on the original vacuum motor. I would suggest either a couple holes in each side of the arm as you do have to tweek and adjust some to get the strokes about right. Thanks all
I see this and I have a 200+ dollar kit sitting under the bench that isn't completely installed yet.
I beat my head against the wall 30 years ago trying to make something work and never did but this is so simple and the parts are easy to find. Last edited by mr48chev; 12-13-2009 at 03:26 AM. |
#13 | |
Here's my version with a basic S-10 Blazer rear window wiper motor. Kinda like the one above only different.
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#15 |
Wow, what a frustrating day! When I first started working on the wiper design back in April, I figured the twist in my design was too thin of steel on my bracket. When I had my friend cut it out for me, I had him make it the way I originally designed and make it without the side reliefs to bolt a possible brace to. Well I had to go with the latter! I bolted up the one in the upper pics and it put just enough twist (those little motors are really torquey!) that I realized that heavier bracket wasn't going to work either. Thank goodness I'd had him make the other bracket too.
#16 |
You guys ROCK !
Thanks for the information
#17 |
Very cool.
1971 C-20 2wd, LB, white/copper 1964 Impala conv. 1957 Bel Air Wagon 1948 Chev 3100 1930 model A coupe 1929 model A speedster pickup |
#18 |
After fighting the passenger side wiper, I realized there was way to much flex in the factory bar/rod that runs from the motor to the wiper itself. With all the extra movement, I couldn't get it to be as stable as the drivers side. I'm now making a non-flex set of rods for BOTH sides to try and get this setup to work correctly!
#19 |
Interesting, mine seems to work fine. I did have to adjust the motor placement and the position of the wiper rods on the actuator, but I never had any rods flexing. Good luck
#20 |
Anyone know if there are differences between the OBS wiper motor (pre 95) vs. the newer body style (95 up)? Older ones seem to be harder to find around here.
Edit: Just did a cross reference on rockauto.com, it's not the same. Looks like these are from 1989-1994 s-blazers.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler Last edited by BlueJeep; 01-08-2010 at 06:24 PM. |
#21 |
OK, picked up my 93 blazer wiper motor today. You guys who have done this, does this motor self-park? Does the indexing of the wiper arm thing on the motor matter? Can it be run in intermittent-mode? I haven't researched it much yet, but I know the Newport ones use the switch to gain the intermittent functionality.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#22 |
The indexing is important, you can fool around with it and get it right. I have mine all torn apart right now as I just painted my truck, so I don't remember exactly about the switch wiring. I think it has 3 wires and it does not self return stop unless you wire the third wire correctly the best I recall. I will be doing this again in a few months and will probably figure it out again, I just don't remember right now. If you figure it out first, let us know.
#23 |
i used the set up out of a 60's chevy truck i my 57 wil see if i can find pics later
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
#24 |
There are 3 wires, black, orange and brown. Black is ground of course. Orange is wipers on power, take your hot off that and touch it to the brown and it will go back to center.
#25 |
Awesome!
I have to get this done on my '52 truck with the wipers that go in opposite directions. But the long story short is that most rear window wiper motors are what to use as they don't go 360* but back and forth? Then it's a question of figuring out the geometry of arms in relation to wiper motor sweep etc. etc. And if I want interval source a rear wiper motor of a vehicle equipped with interval obviously... any reason you guys are using S10 motors? Or simply because they're there? Thanks! |
Tags |
electric wipers |
