Old 11-28-2009, 08:15 AM   #1
sailed2japan
Jonny
sailed2japan's Avatar
Frame differences
I was woundering if 60-66 trucks had 3 different frames for them like the 73-87 do. I know there are different ones for cab and chassis, too, but I'm just concerned with pick-up frames. I trying to figure out the best thin to hunt down if I ever get my crew cab build off the ground.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-28-2009, 08:35 AM   #2
63 & 64 Bowties
and a few others
Re: Frame differences
The chassis that is under 60 thru 62 pickups is a beefy, x-boxed behemoth that had front torsion bars and ball joints that bolted to the ends of the a-arms. It also used a differential with a drop-out pumpkin.
In 1963, a ladder-style, c-channel chassis was introduced that featured modern-style stamped a-arms with pressed-in ball joints, front coils, and a twelve-bolt rearend.
The exact mounting locations for the cab and bed were changed for 63, but only require some re-drilling to properly fit if you are mix/matching across these model-year lines.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 11-28-2009, 09:08 AM   #3
sailed2japan
Jonny
Good info!
I guess I should have been more specific about exactly what I'm wanting to know. I plan on building off of the 63-66 type frame, but don't know if I should start with a c10, 20, or 30 chassis. I'm looking for something strong, but don't know how strong these frames are to begin with,. If a c10 is good enough I'm going to waste my time hunting down anything else.
Jonny
-AEC Hundley USNR
Old 11-28-2009, 10:06 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I believe the 1-ton trucks came with taller frame rails for the added loads they were expected to carry.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-28-2009, 10:34 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I found a 1 ton frame that is a 133 inch wheelbase that I am going to use.
Old 11-28-2009, 10:51 AM   #6
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Frame differences
This is all the info I have right now.
Still researching to add all the info I can find on this thread.
If anyone like to help me on this they are more than welcome.
1960-66 Chevy/GMC Truck Frame Diagram
http://67-72chevytrucks.com/vboard/s...d.php?t=325736
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 11-28-2009, 11:38 PM   #7
sailed2japan
Jonny
Sweet info, but I didn't see anything in ther about the thickness of the seel the rails are made of or the height of the rails. it looked to be all about were to put the brackets.
-AEC Hundley USNR
Old 11-29-2009, 01:32 AM   #8
Captainfab
60-66 Nut
That is correct. I believe the steel may be slightly thicker also. Additionally the C30's came with leaf springs so consequently the frames are straight from the back of the cab rearward. In other words they don't have the flare outward where the coil springs are on a C10 or C20.
Old 12-13-2009, 05:13 PM   #9
sailed2japan
Jonny
so would a c10 LWB and a c20 have the same frame?
-AEC Hundley USNR
Old 12-13-2009, 05:31 PM   #10
62gmc910
62gmc910's Avatar
I think the C20s were thicker material but the same depth
The '73-87 suburban frame would be a lot better for your application the frame doesnt kick up under the cab like a pickup and I've been told that they are thicker material
BTW what are you building????Oh guess if I read the thread?
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-14-2009, 01:20 AM   #11
Captainfab
60-66 Nut
Basically yes. Like 62gmc910 said, the material is slightly thicker on the C20. Also on the C20's there is a brace that goes from the trailing arm crossmember where the trailing arms attach, over to the frame rail.
