09-03-2011, 10:44 AM | #1 | |
Re: 1st Project: 71 C10 SWB
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, |
09-24-2011, 09:24 AM | #2 |
Just checking up on any progress or to see if you made it back from Japan,still helping my friend with his S-10 flame.We got the rear in & some welding done.Here's a side shot of his truck.Hope to see progress on your truck soon.Keep on Truckin'
10-08-2011, 11:42 AM | #3 |
Hey RCbowtie69, just getting back to working on the truck this weekend. Modifying the frame center brace to allow for the exhaust to go through then body work on the cab. Will get some pics up soon. Your buddies truck is looking good as well.
Posted via Mobile Device Posted via Mobile Device
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
10-09-2011, 11:34 AM | #4 |
Hey chevy71c10,gald you made it back safe,hope to see some pictures soon.I'm still buying parts,brought a 700r4 trans from Classic Muslcle that was rebuilt by Performance Automatic Street Smart Systems.Hope to be installing drive train soon if money and my roof on my garage holds out.Keep on Truckin'
10-10-2011, 09:24 PM | #5 |
Here are a couple other descriptions and pictures of the door skin replacement.
1st shows the edge of the door where I ground the skin flange to separate the skin from the flange of spot welds. 2nd shows the spot weld flange that requires removal. I used hammer/chisel and grinder to remove excess metal to expose only spot welds.
10-12-2011, 11:56 PM | #6 |
This weekend I modified the carrier bearing brace to allow the exhaust to pass through without having to route below the frame. I forgot to get a pic before I started, however here are some during and finished. I cut a 4.5" hole on each side and had made some wedges to weld in to provide support back to the brace. I wire-wheeled it clean and treated it with the Eastwood frame conditioning kit.
Next up: floorpans, A-pillars, kick panel, cab corners, B-pillars & cab supports.
10-13-2011, 12:00 AM | #7 |
Looks good....keep with it...
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
10-20-2011, 09:55 AM | #8 |
Crossmember looks good.
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
10-20-2011, 10:34 PM | #9 |
Thanks guys! Last few days I have been working cab repair. Removed rocker panel and cut out both rusted front cab supports and front floor area. Really nervous about trying to to get the cab support, floor, kick panel & A-pillar all to match up like before. I'll keep you posted....
Thanks, Justin
10-20-2011, 10:43 PM | #10 |
Still Learning
That cross member looks great! Super clean mod. The cab has your work cut out for you.
10-20-2011, 11:20 PM | #11 |
Thanks mcbassin! Yea, i'm thinking the cab may take me for 15 rounds, but hopefully I win in the end.
10-21-2011, 12:09 AM | #12 |
LOL!!! Only 15 rounds? I wounldn't last the first round. I can unbolt and bolt parts but coming to body work I am lost. Thats why I searched so long to find one that had little to no rust. But, I am sure you will be able to handle it. Will be watching the progress, good luck.
10-21-2011, 08:28 PM | #13 | |
Justin
10-23-2011, 09:37 AM | #14 |
Hey chevy71c10, like the progress you are making.Keep up the hard work,is that 5 speed trans or 6 speed ?Keep the pictures coming & keep on truckin'
10-24-2011, 11:02 PM | #15 | |
Thanks again,
10-29-2011, 10:36 AM | #16 |
Cool,hope to see your progress soon chevy71c10,keep the hard work going & pictures coming.
11-07-2011, 10:09 PM | #17 |
Today I was able to get the right front floor pan, kick panel & cab support trimmed and ready to weld in. Tomorrow I will get those welded in and replace the A-pillar.
11-08-2011, 01:16 AM | #18 |
Still Learning
That transmission is gonna be bad A! Looks like a bunch of $$$$
Nice work on the floor. I like the idea of leaving the tab to hold it in place. I will use that on my next one. |
10-25-2011, 12:19 AM | #19 |
That tranny is going to be nice to drive and lots of fun for play time.
11-08-2011, 01:21 AM | #20 |
Looks like a perfect fit....good work!
01-05-2012, 11:19 PM | #21 |
Nice looking work!
11-08-2011, 08:49 PM | #22 |
Hey chevy71c10,just check your progress on your floor & it's looking good.Keep up the hard work & pictures coming.Keep on Truckin'
11-09-2011, 01:27 AM | #23 | ||
Thanks. Quote:
11-20-2011, 09:29 PM | #24 |
Hey chevy71c10,how the weather down there,it's starting cool down up here.Just checking up on your progress,hope to see your pictures of your progess.I'm still buying parts & still trying to decide which headers to buy.I'm still helping my friend on his 50 chevy truck using a S-10 frame.I found him a LS-1 to rebuild for $200.00,it had low oil pressure when my friend pull it out of his work truck.I hope to start working to put my motor in soon.My friend with 50 truck just brought a engine hoist.I check back soon on your build & keep on truckin'
11-23-2011, 01:33 PM | #25 | |
