Old 01-11-2010, 02:47 PM   #1
justpball
justpball's Avatar
chopped x member!
got it put in this weekend! top picture is before and the next one is after...it is perfect! sits aired out with just a little rake to it!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 01-11-2010, 03:50 PM   #2
BGRAFX
Re: chopped x member!
Looks good!
BGRAFX is offline   Reply With Quote
Old 01-11-2010, 04:20 PM   #3
stevieB
stevieB's Avatar
thats awesome!
stevieB is offline   Reply With Quote
Old 01-11-2010, 04:33 PM   #4
justpball
justpball's Avatar
it was an easy swap, the steering issues are the only real prob, i may swap to a rack setup anyway.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-11-2010, 09:22 PM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Man that thing looks sick! Do you have any pics of what you did to it? and did you cut the floor out in the back for the C?
tvblazer78 is offline   Reply With Quote
Old 01-11-2010, 11:57 PM   #6
justpball
justpball's Avatar
Yea I will post some tomorrow of what I did, I did not cut into the interior at all,it is all under stock floor
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-12-2010, 12:02 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Subscribing,...
It just keeps getting better.
lolife99 is online now   Reply With Quote
Old 01-12-2010, 12:09 AM   #8
cochino12
It followed me home?
cochino12's Avatar
sits perfect, makes me want a suburban
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-12-2010, 12:18 AM   #9
menace121978
menace121978's Avatar
makes me want one too!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-12-2010, 11:38 PM   #10
texassquarebodies
Truck Nut
texassquarebodies's Avatar
*****in!!!!!
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 01-13-2010, 12:17 AM   #11
mullit
mullit's Avatar
did you swap the crossmember and just raise the engine up with a hoist? Kick azz burb, i'll be tearing into mine soon.
mullit is offline   Reply With Quote
Old 01-13-2010, 01:03 AM   #12
justpball
justpball's Avatar
You do not have to remove the engine at all, if you look at the frame mounts for the engine, there are two bolts on the top of the frame leave those hooked up and you can remove the x member, you just remove the bolts from the bottom of the bracket that bolts to the x member and when you slide the member back in the holes should line back up.... I had to drill my back 2 out just a little.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-13-2010, 11:52 AM   #13
justpball
justpball's Avatar
as promised here are some pics of the work...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-13-2010, 12:32 PM   #14
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Ummmm wait!!! you rock!!! I finally see how these DM's are cut....hmmmmmm...I can do that and I have a spare X memeber...nice work any hints
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 01-13-2010, 01:47 PM   #15
tvblazer78
Low & Fast!
tvblazer78's Avatar
Nice jod! This has me thinking now and thats not good..
Old 01-13-2010, 01:50 PM   #16
justpball
justpball's Avatar
yea having a spare xmember is nice, thats what I did, got it all ready to go in then just pulled mine and put the chopped one in. took about 6hrs...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-13-2010, 05:47 PM   #17
jmedero
jmedero's Avatar
Nice work bro! I need to make that short drive over and say hey! Still working on getting my parts together. How did the steering go back together?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 01-13-2010, 07:03 PM   #18
justpball
justpball's Avatar
good it was not hard at all, got it all back together. Working on the inter fenders and i think i am close to being done for now...yea right. I am going to take it over to the bay front, and the burger king on 9mile soon.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-13-2010, 07:26 PM   #19
stevieB
stevieB's Avatar
so you didnt cut the rear floor, how did you run your bags and lines?
Also are those 20s or 22s?
Old 01-13-2010, 08:02 PM   #20
Hottrucks
Hottrucks's Avatar
how about a pic of the steering shaft issue....
Old 01-14-2010, 10:40 AM   #21
justpball
justpball's Avatar
here is the steering stuff...
and here is what i did.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-14-2010, 12:32 PM   #22
Hottrucks
Hottrucks's Avatar
Nice!! my thoughts exactly....I would even consider a small c notch in the a arm..yea I know let the flaming begin!!
Old 01-14-2010, 04:31 PM   #23
justpball
justpball's Avatar
^yea I thought about that, but had the other stuff laying around so just used it...LOL
stevieb I didnt cut the rear floor at all but, I am going to have to to get it any lower. I will take some pics tonight of my rear setup.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 01-14-2010, 04:40 PM   #24
stevieB
stevieB's Avatar
Cool thanks, I'm just racking my brain about what to do, so far what I have going on is gonna be...
adjustable behind the axle bag mounts with top cross bar mounts.
4 link with the top bars attached to the frame not a cross member and the bottom bars mounted in the exsisting front perches.
the front...
after seeing what you have I think I will go that route...LOL
thank for the inspiration!
Old 01-14-2010, 04:52 PM   #25
mullit
mullit's Avatar
thanks for the pictures.i've got one of Nates Dropmembers and im gonna attempt it with the motor in. gonna do the same thing by leaving the original motor mounts in untill ive got the old crossmember ready to come out then hook up the engine hoist to raise the motor enough to get the DM and then the new motor mounts in. only thing is i'll be doing it on jackstands. Your burb has realy given me the inspiaration to get into my burb again and get it on the road
