Re: Project: Recycle
I started making the inner boxing plate trying to keep the gaps as consistent as possible. One thing I didn't like was putting the plate against the frame 'as is' would not allow it to be square. I wanted the boxing plate in square, so that required trimming the bottom lip of the frame rail slightly.
I also had to figure a way to do the bed mounts. I considered welding them in place but ultimately decided to weld some nuts in place under the frame....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-18-2010 at 12:08 AM. |
