02-04-2010, 04:21 PM | #1 | ||
"I ain't nobody, dork."
Creeping Death
1972 GMC 1500 Super Custom... yarded out of a field in Snohomish WA. Here is the way it looked when I brought it home...
Gary
02-04-2010, 04:23 PM | #2 | ||
Re: Creeping Death
Then I shoved it into the tiny garage in the dump I was living in at the time...
02-04-2010, 04:25 PM | #3 | ||
Re: Creeping Death
Then commenced to tear it apart from the firewall forward...
02-04-2010, 04:27 PM | #4 | ||
Re: Creeping Death
My old man gave me some cool ET 5-window slots to put on the truck... they cleaned up nice!
02-04-2010, 04:29 PM | #5 | ||
Re: Creeping Death
More... in the tny garage...
02-04-2010, 04:31 PM | #6 | ||
Re: Creeping Death
Engine and tranny out... tore engine down...
02-04-2010, 04:33 PM | #7 | ||
Re: Creeping Death
Transmission... before and after rebuild...
02-04-2010, 04:35 PM | #8 | ||
Re: Creeping Death
Engine goes back together...
02-04-2010, 04:35 PM | #9 | ||
Re: Creeping Death
More...
02-04-2010, 04:36 PM | #10 | ||
Re: Creeping Death
Engine all purty...
02-04-2010, 04:39 PM | #11 | ||
Re: Creeping Death
Removed heater box, and cleaned it up and reinstalled it with new gaskets and new heater core...
02-04-2010, 04:40 PM | #12 | ||
Re: Creeping Death
Cleaned up firewall, degreased and repainted front clip. I purposely left the firewall with the overspray from the undercaoting and such...
02-04-2010, 04:43 PM | #13 | ||
Re: Creeping Death
Engine and tranny go back in...
02-04-2010, 04:45 PM | #14 | ||
Re: Creeping Death
Some painting and a new aluminum radiator... also cleaned up and painted the original power brake booster... new master cylinder.
02-04-2010, 04:49 PM | #15 | ||
Re: Creeping Death
Carb, plug wires, and distributor go in... I now have an MSD Pro Billet HEI in it... but this got me by for awhile...
02-04-2010, 04:51 PM | #16 | ||
Re: Creeping Death
New hoses, belts, new engine wire harness, and new front end wire harness. Headers installed. Also installed new plastic harness channels... inner and outer fenders (replaced pass side inner with aftermarket), and new battery tray and battery
02-04-2010, 04:54 PM | #17 | ||
Re: Creeping Death
BFG Radial T/A's on old school ET 5-window slots...
02-04-2010, 04:55 PM | #18 | ||
Re: Creeping Death
Old school lookin' Sunpro Tach...
02-04-2010, 04:58 PM | #19 | ||
Re: Creeping Death
Here is how it looked the day I drove it out of the garage... just goes to show, you can clean up an old farm truck, and make it turn heads... even with limited space in a super tiny garage, and on a tight budget...
I've done more to it now... still need to lower it, and put a decent exhaust on it... but this thing hauls... and has been a fun project over the last 4 years... My shop buddy... my 12 year old Chocolate Lab... Yukon. He worked hard on this project too! Gary
02-04-2010, 10:21 PM | #20 |
Re: Creeping Death
That has to be the quickest build I've every seen
Looks great! |
02-04-2010, 11:00 PM | #21 |
Grandpa in the rustmobile...
Re: Creeping Death
Looks like dangit in the 1st pic comepared to after shot..
That engine bay looks KILLER wat paint did ya use? Any specs on the motor? That looks GREAT!!!!!!! Good job!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
02-05-2010, 12:16 AM | #22 | |||
Re: Creeping Death
Thanks! It actually took about 4 years...
Engine is the original 1972 4-bolt main 350 (.030 over), stock crank and rods with Speed-pro 10:1 Hyper flattop pistons, Stock 2.02 heads (with some mild porting), Lunati 292 Bracketmaster cam and Lunati lifters, Roller rockers, Cloyes double roller timing chain, Heddman Headers, Edelbrock RPM air-gap, Holley 3310 (750cfm) blueprinted and benchflowed by Lyle Winters racing in Tacoma, WA. There is a stock HEI ignition in it in the pictures... but there is an MSD Pro-billet HEI with rev limiter in it now...Roughly makes 400 hp around 5,600 RPM's. I rebuilt the TH350 myself, and installed a B&M shift kit in it. 2,800 RPM stall converter. Goes pretty quick for a truck. The best part about it is when people hear it they want to see the engine. When I open the hood... people aren't prepared to see an engine that clean in an old work truck... Which is exacxtly the look I was going for. It's one of those projects that will be forever ongoing... always tinkering with it. One of my buddies gave it the nickname "Creeping Death"... after a Metallica song. Thanks for the comments guys... Gary
02-05-2010, 12:41 AM | #23 |
Re: Creeping Death
That is a gorgeous truck, great looking, original, but powerful, i like how you did it.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
02-05-2010, 04:48 AM | #24 |
Re: Creeping Death
Your rims look great, what did you clean them up with?
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
02-05-2010, 01:39 PM | #25 |
Tot Roddin'
Re: Creeping Death
Nice work, turned out really nice!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
