Old 02-22-2010, 02:37 PM   #1
WIDESIDE72
WIDESIDE72's Avatar
72 SWB STEP "Army truck" Budget Build
Here are some pics of a 72 SWB step I picked up a while back for $500(!). No engine/ trans, but the SPID says it was a 350/ TH350, PB, PS no AC truck. I am guessing it was Army originally. The firewall and inside of one fender is still olive drab green. (The other fender has been replaced at sometime.) The interior metal is silver and looks original. The PO had a velour seat, "headliner" (similar to a Cheyenne, but no trim) and door panel inserts made. I am thinkig of painting it a late model dark emrald green metallic, for two reasons. #1 is I have a set of pretty nice green Cheyenne door panels and seat belts that I plan to use. #2 is you don't see many green trucks any more. I plan to make it a driver with a 350/ 700R4 that I have in the barn. I have a tilt and tach for it as well. I found the SPID pretty interesting.
WIDESIDE72 is offline   Reply With Quote
Old 02-22-2010, 02:41 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 72 SWB STEP "Army truck" Budget Build
Superbowl weekend I got the front clip removed and power washed the front frame rails and firewall and the 350 engine I plan to use.
Old 02-22-2010, 02:44 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Pics above are before cleanup. I forgot to take pics after cleanup. I also need to take pics of the freshly resealed and painted engine with front PS pump and alternator brackets mounted and engine attached to the 700r4.
Old 02-22-2010, 02:49 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
The truck that the engine came out of was a 71, but according to the casting #, it is out of a 74 model. The PO installed it using the post 73 LWP and related accessory drive. I have accumulated almost everything to convert back to swp, such as water pump, ps pump and brackets and alt mounts. I forgot that I couldn't run the 8" balancer with the SWP PS pump... Vauto Zone has one for $51...
Old 02-22-2010, 02:55 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
This will be a "budget/ driver build" using as many of the parts that I saved from trucks I have parted out over the last few years. I have a PERFECT ds OEM fender already primed by the PO and a very nice chrome front bumper from of one of the trucks I parted, a very nice ps fender with only a couple of pinholes in the front cup that I bought locally for $75. The radiator support has a few pin holes that I plan to fill with my MIG welder. I also have a very nice "driver" grill surround from my brothers 72 Cheyenne.
Old 02-22-2010, 02:57 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
I am looking for an original "driver quality" or repro chrome rear sport bumper. I can buy on at the Decatur swap meet for $149, but if someone has one for less than that locally, or will ship one for less, please let me know.
Old 02-22-2010, 03:03 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
For the time being, I plan to paint the firewall and inside the front fenders whatever color I decide to go with, install them and get the truck road worthy. About the only body work I see so far is installing new rockers and repairing a dent in the top of the cab. I have an almost new windsheld with stainless trim, and a rear sliding window with new rubber from a truck I parted out. I plan to pull the glass when I paint the truck, buy a new windshield rubber with groove for stainless trim and install the glass and trim after paint.
I recruited my dad to cut the boards for the bed using his table saw, and reuse he stock strips if possible.
Old 02-22-2010, 03:08 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
The main "out of pocket"expense I see so far:
Dark green& white Cheyenne Super Houndstooth seat cover $325
Dark green dash pad $65
Dark green arm rests $40
Paint supplys (eventually) $500 (+?)
Currently, the dash is silver, and appears original. I plan to paint it the same green as the exterior.
The truck will be a little odd with the blue exterior and green interior... but "oh well"...
Old 02-22-2010, 03:10 PM   #9
WIDESIDE72
WIDESIDE72's Avatar
This weekend I also pulled the aftermarket outside mirrors. It looks better already. I have a pair of "driver" sport mirrors off my dad's 71 GMC that we pulled. I also pulled the LWP PS pump that was still attached as well.
Old 02-22-2010, 03:31 PM   #10
Hook'em
Hook'em's Avatar
I live just down the road on 1431. Can't wait to see the truck running around town.
Hook'em
Hook'em is offline   Reply With Quote
Old 02-22-2010, 03:39 PM   #11
lax54650
good start
lax54650 is offline   Reply With Quote
Old 02-22-2010, 04:23 PM   #12
lks dcvn
lks dcvn's Avatar
I was going to wait every 5 mins for a new post - figured the truck would be done by then.
Does it have the "Govt VIN thing" on the door frame - in another build thread - somebody showed a picture of the 'Air Force' badging on the truck.
lks dcvn is offline   Reply With Quote
Old 02-22-2010, 05:34 PM   #13
fishingjred73
fishingjred73's Avatar
Looks like a good solid truck Steve!
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is online now   Reply With Quote
Old 02-22-2010, 05:48 PM   #14
WIDESIDE72
WIDESIDE72's Avatar
Not much progress, yet...I will post some pics of the engine soo. It is nothing special...
No govt tag on this one anywhere I can see.
Old 02-22-2010, 09:30 PM   #15
NateK4340
NateK4340's Avatar
Cool truck! Can't wait to see more progress.
"Only two defining forces have ever offered to die for you:
1. Jesus Christ. 2. The American Soldier, One died for your soul, the other for your Freedom. "
In the Garage:
'02 Silverado Ext. Cab Z71 5.3l
'70 C20 Longstep 402BB
NateK4340 is offline   Reply With Quote
Old 02-22-2010, 10:47 PM   #16
arkie726
arkie726's Avatar
She's a beauty!
arkie726 is offline   Reply With Quote
Old 02-23-2010, 09:27 AM   #17
lks dcvn
lks dcvn's Avatar
The U.S Army Marketing option on the SPID is good enough to document it...I will see if I can locate a picture of the other one I saw - might have been an air force truck - if I recall correctly.
Old 02-23-2010, 11:09 AM   #18
HuggerCST
HuggerCST's Avatar
Nice truck! Especially for that price. I had one very similar to yours that was also a Army truck. I sold it to my brother in law, who is a Army vet. He painted it drab green inside & out. I've never seen some of those options, Chipflyer may want to see that.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-23-2010, 08:58 PM   #19
WIDESIDE72
WIDESIDE72's Avatar
I find the listing of a cigarette lighter twice and the coolant overflow very intersting. I have been researching the overflow, but not the lighters.
Old 02-23-2010, 10:49 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
We had SNOW in austin today! Luckily there was not any ice on the roads (YET)...
Old 02-23-2010, 10:54 PM   #21
WIDESIDE72
WIDESIDE72's Avatar
One of these days I will wise up and quit fooling with these trucks and build a garage. I have a "barn" that is about 12'x30' that I need to get all of the clutter out of...The pad where the truck is sitting was intended for a 32'x 60' pole barn. I have the posts and trusses. In the Spring, I am going to contact a few companies about putting it up with a roof. With 12' high sides and no walls, it will be a welcome addition in the Texas heat. Here a a couple of pics of the engine/ trans. Nothing special.
Old 02-23-2010, 10:57 PM   #22
WIDESIDE72
WIDESIDE72's Avatar
I wasn't working on the truck out in the snow, BTW. I just had time to uncover the engine and take a few pics of it and the truck with snow before it got dark. Right now, due to the fact that I get home around 5:30, I'm not able to work on it except for the weekends. A shop would fix tha as well. Not sure how the wife would like that, though.
Old 02-23-2010, 11:00 PM   #23
AustinScott
AustinScott's Avatar
wow, nice man... and so many people so close to me, I live off the 1431 as well, we should get together sometime.
AustinScott is offline   Reply With Quote
Old 02-28-2010, 07:46 PM   #24
WIDESIDE72
WIDESIDE72's Avatar
I finished cleaning the engine compartment frame section and firewall Saturday. I rattle can painted the frame semi gloss black and the firewall olive drab green today. It was a little windy for painting. I probably lost as much as what stuck! I also pulled the trans crossmember to clean it up. I figured since I was going to have to take all 8 bolts out to slide it back for the 700r4, I might as well take it out, clean it up and paint it.
Old 02-28-2010, 07:47 PM   #25
WIDESIDE72
WIDESIDE72's Avatar
I plan to order some of the goldish/ silver paint from Eastwood for the PB booster.
