Point to HEI - Plug Gap?
When you change from a points distributor to an HEI do you have to change the gap of the plugs?
250 straight six - they are currently gapped at .035. Will I need to open that with the HEI or leave them as they are? |
Re: Point to HEI - Plug Gap?
I did this swap on the 6 that was in my 68 & set the gap @ .045.
20' Daredevil (Ret)
![]() Join Date: May 2003
Yup -- points .035, HEI .045
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
