Re: Auto trans test plug????
There is a scanguage called the Aeroforce Interceptor ( http://www.aeroforcetech.com/ ) that can monitor anything that the PCM sees, and it also reads and cleares DTC's and it can do some performance monitoring. I have one in my 2003 Bonneville SSEi, and it works great. It shows Transmission Temp, along with tons of other information. That would be a better investment than a Trans. Temp gauge, as you now have a scanner/code reader to boot.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
