6 cylinder engine swap
Thinking about buying a 51 chevrolet truck, the truck has a 235. I have a mid 70's model 250 inline 6, how difficult would it be to convert from the 235 to the 250?? (any bell housing issues, transmission, etc)
70 Chevy C10, LT1, T5, "Blue Beast" |
Re: 6 cylinder engine swap
It's a pretty big job considering they are 2 different animals, but it is done frequently. You will need a cross member under the bell housing from a 54. You need a bell housing from a 55-67 V-8 or a 63-67. 68 to 72 will work if they used a 6 cyl. You will need to fab clutch linkage, exhaust, & electrical. You will need an engine mount kit.
im running a nice 250 with a turbo 350 combo
Another question, does anyone know of a bolt on front end clip for a 51 or a 58 pickup??
ttt
im gettin ready to put a 250 in as well, i had to track down a bell housing to fit since i am keeping the 3 speed.
53 Chevy 3100 1/2 ton 1st Armored Division, OIF Veteran ![]() |
carburetor linkage, column shift linkage, exhaust, wiring, clutch plate size, transmission crossmember, engine mounts, all have to me modified or fabricated.
