Old 03-23-2010, 07:16 PM   #1
fdbdw
fdbdw's Avatar
lovin Lukas oil
Ive had a noisy rocker from the time of my rebuild 1,500mi ago, after a valve adjustment it was still there, I was starting to worry that I had wipped a lobe. Did a oil change yesterday and added a quart of lucas oil additive, the noise is gone , just like that. Im stoked, thought I would share
fdbdw is offline   Reply With Quote
Old 03-23-2010, 08:23 PM   #2
culp7
HickTown
culp7's Avatar
Re: lovin Lukas oil
i'll have to try some of their products! thanks for the heads up
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 03-23-2010, 08:38 PM   #3
mbgmike
Re: lovin Lukas oil
Yeah we sell and use Lucas oil and gas additives. Great stuff. I use both in my truck. Plus we still have fun with the little gear thingy. Its hard not to crank it once a day.
Its one product I actually have faith in.
mbgmike is offline   Reply With Quote
Old 03-23-2010, 08:41 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: lovin Lukas oil
I agree great stuff but you just covered up a problem with a new motor ..my guess is you have a lazy lifter
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-23-2010, 09:14 PM   #5
fdbdw
fdbdw's Avatar
Re: lovin Lukas oil
Thanks for the rain, ha ha
Old 03-23-2010, 11:17 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Re: lovin Lukas oil
The power steering pump on the 69 big block truck was leaking (external reservoir) so my buddy says "put some Lucas stop leak in it". I'm like, yeah right, but he finally convinced me and I'll be damned if it didn't quit leaking.. Go figure... good stuff.
LockDoc
Leon
Old 03-23-2010, 11:54 PM   #7
Mister laugh
Re: lovin Lukas oil
No to rain on anyones parade here, but next time you go to the parts stores crank one of the gear things for a while. You will notice LOTS of bubbles.......... this isnt good, its airation of the oil. There was a test of the lucas products on bob is the oil guy at one point i cant find it now.
Mister laugh is offline   Reply With Quote
Old 03-24-2010, 12:02 AM   #8
hchad18
hchad18's Avatar
Re: lovin Lukas oil
The transmission additive put a little more life into a slipping turbo 350 in our 83. I'm convinced
hchad18 is offline   Reply With Quote
Old 03-24-2010, 01:04 AM   #9
'72customdeluxe
Re: lovin Lukas oil
from what I've picked up on that site, the oil booster is just thick petroleum stock with no real additives to speak of. Haven't been on bitog in a while, it's always informative
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 03-24-2010, 02:56 AM   #10
70cst
70cst's Avatar
Re: lovin Lukas oil
Interesting info..
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-24-2010, 06:22 AM   #11
vegaschevy
Re: lovin Lukas oil
BTOG i am not a fan of.... they rave about Amsoil and it is some of the worst stuff out their.....
Hell, Amsoil publish tests related to oil that are for the wrong kind of oil, tell you they have oil for this and that such as an Allison tranny in a duramax... when in fact that will void your warranty INSTANTLY by using it.
If the stuff is so great, why does NO manufacture or builder recommend it
vegaschevy is offline   Reply With Quote
Old 03-24-2010, 12:40 PM   #12
69GMCLonghorn
69GMCLonghorn's Avatar
Re: lovin Lukas oil
My thing is, keep your oil and filter changed, use synthetic if you so choose (and can afford it), and you'll have probably hundreds of thousands of miles with no problems related to lubrication. As stated above, if an additive helps a problem, you are putting perfume on a pig. You still have the problem; it's just been masked over. If it plugged a leak, it's going to start leaking again at some point.
Sorry to be skeptical, but I just don't see the need, especially with how relatively good the basic oils on the market are these days. I think they're up to SJ, if I'm not mistaken. Every time they go to the next letter, they've improved something with the oil.
69GMCLonghorn is offline   Reply With Quote
Old 03-24-2010, 03:20 PM   #13
rockc
Re: lovin Lukas oil
Yea a standard quart of oil around here is $2.50 per quart. Then on top of that the syntheyic is double or more.
72 chevy 3/4 ton 4X4
rockc is offline   Reply With Quote
Old 03-24-2010, 04:12 PM   #14
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Exclamation Re: lovin Lukas oil
X2!!
Could not agree more with this statement.
Oil additives only mask a hidden problem. But hey if it works for you and your older engine or whatever application you have then by all means go for it.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 03-24-2010, 05:01 PM   #15
BluTrukker
BOHICA
BluTrukker's Avatar
Re: lovin Lukas oil
I drive a 92 toyota Paseo 1.5L for my daily work beater. It has 265,000 miles on it and runs like a top. I run lucas in it, and heres why. My last beater was a 91 tercel, it started losing a little comp. an burning some oil around 250,000 miles. I started adding 1/2 quart of lucas at every oil change and the oil burning stopped and compression evened out. Sold that one at almost 300K 3 yrs ago, and its still out there running. Lipstick on a pig or not, the problems never returned.
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 03-24-2010, 05:10 PM   #16
'72customdeluxe
Re: lovin Lukas oil
I'm not sure if you've been on there recently, most of the amsoil nutswinging has subsided. I don't listen to peoples butt dyno results for different types of oil, because you really can't tell. I just look at the oil analysis tests. Also, recommended oil (like mobil 1 stickers on vettes) comes to the highest bidder
Old 03-24-2010, 05:14 PM   #17
'72customdeluxe
Re: lovin Lukas oil
Current oil is sm, it's also terrible for flat tappet cams. Rotella and other hdeo is rated sm but still has enough zddp. It is also way higher quality for the money (12$ a gallon) and cleans better than passenger car oil
Old 03-24-2010, 10:16 PM   #18
Ticker
Re: lovin Lukas oil
Might want to take a look at the sticky at the top of the Engines and Drivetrain section for the facts regarding API/ILSAC specs and flat-tappet cams...
http://67-72chevytrucks.com/vboard/s...d.php?t=381780
Ticker is offline   Reply With Quote
Old 03-25-2010, 03:45 PM   #19
67chevemall
67chevemall's Avatar
Re: lovin Lukas oil
Lucas oil additive is great stuff! I put it in my old Yota beater and 5 drops in my dirt bike.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-25-2010, 04:05 PM   #20
tasian
tasian's Avatar
Re: lovin Lukas oil
i love lucas but not because of fixing anything i just like to change my oil alot and it seems to hold up alot better with lucas in it
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 03-25-2010, 06:22 PM   #21
leddzepp
Moderator
leddzepp's Avatar
Re: lovin Lukas oil
I am sold on Lucas products as well. Always work for me.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-25-2010, 11:05 PM   #22
chas350
Re: lovin Lukas oil
It seams that it is pretty much the only additive company (Lucas) out there that is recommended by mechanics as worth using/trying. I have had good results with it also.
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 03-26-2010, 10:24 AM   #23
DT1
DT1's Avatar
Re: lovin Lukas oil
I have a 99 Tacoma with a 2.4L. I have always run the cheapest Dino oil I can find in it. I don't run additives of any kind in it but I do change the oil every 3,000 mi. (105 changes to date) The truck now has 320,000 miles on it and it runs like the day I bought it. Never burned a drop of oil and nothing has ever broken.
DT1 is offline   Reply With Quote
Old 03-26-2010, 10:50 AM   #24
LockDoc
LockDoc's Avatar
Re: lovin Lukas oil
I don't use AMSOIL, or any synthetic for that matter, but I'm pretty sure that none of the manufacturers are going to recommend a certain oil unless they are getting some kind of payment or deep discount on the products they purchase from them. Maybe AMSOIL just won't play their game??
It almost sounds like you have an axe to grind with AMSOIL... Just an observation.
LockDoc
Leon
Old 03-26-2010, 01:23 PM   #25
mbgmike
Re: lovin Lukas oil
Actually not a real indication of anything except that a higher vicosity oil will retain more bubbles. The regular oil has bubbles also. The gears on a gear pump will cause that when exposed to the open air. Your pump on your motor will be submerged. Same thing which causes a belt drive to whine. Squishing the air between the gears.The little model means nothing in real world applications
