Desert Dweller
Re: My 66 GMC LWB
I got my cam and lifters swapped out yesterday and just finished breaking it in. I used the original valve springs for the break in, so now I just need to swap them out with the new ones when the engine cools down
![]() Once this is done, I moving on to the gas tank relo project ![]() Tony Posted via Mobile Device Last edited by AZ66GMC; 04-17-2011 at 02:18 PM. |
Desert Dweller
Re: My 66 GMC LWB
I got my cam, lifters, springs and chain swapped out last weekend
![]() I made a video of it running... It's nothing too special, just a Comp Cams High Energy 268. It sounds good enough for me and has more power ![]() http://youtu.be/HkW7C-UOOMA Tony Last edited by AZ66GMC; 04-26-2011 at 09:36 PM. |
SSN 706
Re: My 66 GMC LWB
Very nice. You make me want to go work on my engine.
The 60-66 GMC/Pontiac guy....
Re: My 66 GMC LWB
CRAP! I thought the GCC thing was this coming weekend... Rats!
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#5 | |
Desert Dweller
Re: My 66 GMC LWB
![]() Tony |
Desert Dweller
Re: My 66 GMC LWB
Hey, guess what???
I finally finished my valve cover install... Only took 5 months... ![]() ![]() ![]() ![]() . |
Re: My 66 GMC LWB
What year truck did that brake booster and master cylinder come off of? How hard was it to install beside getting the mounting bracket?
#8 | |
Desert Dweller
Re: My 66 GMC LWB
I got them from the local "pick-n-pull" from a 83 Chevy 4x4. I grabbed the brake lines and proportioning valve along with the pedal rod. I went on a 50% off sale and paid $30 for everything. It bolted up to the 2 factory M/C holes with out any additional brackets. I drilled out the firewall for the bottom 2 holes on the newer M/C. You can see the top 2 holes were not used (has a total of 6 mounting holes). I used my original pedal rod and cut/welded it to the new rod which kept the adjustability by retaining the original threaded part. It took about 4 hours to install it and then a couple more reworking the brake lines. BIG difference compared to the original single pot M/C... It will put you into the dash if your not wearing the seat belt when you slam on the brakes... Takes some get'n used too... ![]() . Posted via Mobile Device |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: My 66 GMC LWB
Nice and tidy. Looking good!
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Desert Dweller
Re: My 66 GMC LWB
Thanks Shaky ![]() ![]() . Posted via Mobile Device |
Re: My 66 GMC LWB
Great truck. Thanks for sharing your updates.
Desert Dweller
Re: My 66 GMC LWB
Thanks Zane ![]() I installed my rubber bed mat that I got for Xmas. It's for a '73-86 long bed Chevy/GMC. It's not exact, but it covers 99% of the wood ![]() ![]() ![]() ![]() ![]() ![]() . |
Desert Dweller
Re: My 66 GMC LWB
I also filled my dash so that I can install my Vintage Air controls and A/C vents. Since the PO butchered the radio slot, I figured that I might as well cut it all out and fill it solid, then go back and cut out what I need...
![]() Before; ![]() Cut, cut away.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() . |
Re: My 66 GMC LWB
Very clean nice looking patch repair on the dash. Thanks for the info on the brake booster. I went to LKQ this past weekend and they had the 50% off sale going on. I couldnt find a decent looking booster to get. Everything was already about stripped to the bones.
#15 |
chevy only
![]() Join Date: Sep 2006
Re: My 66 GMC LWB
nice work!!
CHEVY ONLY... Nothin Else ! |
#16 | ||
Desert Dweller
Re: My 66 GMC LWB
![]() ![]() ![]() Thanks Dino! I gotta get ready for the next Dino's shing ding ![]() ![]() Thanks Captainfab ![]() ![]() Quote:
![]() ![]() ![]() The clamps are from Eastwood. I got (8) for $17 shipped on their last sale before Xmas. They work awesome ![]() You can find them here http://www.eastwood.com/intergrip-pa...-set-of-4.html I'm working on a photoshop project that I will request everyone's input for my dash layout. Hope to have it done tonight and will post it on the 60-66 main board for your input. ![]() Thanks ![]() ![]() . |
#17 |
1 thing at a time is progress.
Re: My 66 GMC LWB
Checking in on you. Nice work. You did a nice job on the dash.
![]() Posted via Mobile Device
Alan
Philippians 2:14-16 |
#18 | |
Desert Dweller
Re: My 66 GMC LWB
![]() ![]() I posted a new thread requesting everyone's opinion on a few dash layouts. Please check it out and give me some feedback ![]() http://67-72chevytrucks.com/vboard/s...83#post5102483 Thank you! |
#19 |
Re: My 66 GMC LWB
Great truck and you have done some awesome upgrades on it...Keep it up and thanks for sharing your work and updates with us.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
#20 |
Desert Dweller
Re: My 66 GMC LWB
LOL, thanks guys
![]() How's the weather in Alaska at this time? We are in the upper 70's right now, but are suppose to cool off to the 60's soon... I want to take a family trip to Alaska soon before I can't afford it... ![]() . |
#21 |
Re: My 66 GMC LWB
We are rocking 4 hours of daylight per day, and it is currently -19* out there as I type this. I am in the interior/central Alaska though. Not sure how things are in the coastal towns....
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#22 | |
Desert Dweller
Re: My 66 GMC LWB
![]() ![]() ![]() Stay warm! . |
#23 |
Re: My 66 GMC LWB
We are at -24 and it was -34 yesterday morning.... wind chill is another thing all together...still staying warm though.
#24 | |
Desert Dweller
Re: My 66 GMC LWB
![]() now that's too cold... I remember a few sub-zero days in Chicago when I was 8 or 9 years old. I couldn't imagine -34, of coarse I know a few people that couldn't imagine +120 which I have worked outside in... ![]() I'd love to experience it on like a vacation though... There is hope that I will take a trip in the next few years, but most likely will go in the spring. . |
#25 | |
Re: My 66 GMC LWB
If you come up here they have a place that has a display they keep at -60 for tourists to experience the winters up here. So far it has only dipped to -40 this winter, but the cold months are ahead of us yet. You should come in Spring!! It is really beautiful up here for that season and it lasts until September when the snow starts falling again ..... The four seasons up here are 1. Winter 2. Not Winter 3. Dark 4. No so dark there you have it !!
