Closed Thread
Old 08-30-2012, 04:05 PM   #1
c10327
c10327's Avatar
Re: What did you do to your truck today!
Originally Posted by Big Block 454 View Post
There's two of these threads. Oh well, might as well post in both.
Out with the old, in with the new:
Love that red steering wheel !! were did you get it want one for my 70 c10 ....
c10327 is offline
Old 08-20-2012, 12:58 AM   #2
kingsolver72
10/30/19
kingsolver72's Avatar
The wife and I went for a cruise in the 68. Got the title and vin plate worked out friday. Finally legal.
kingsolver72 is offline
Old 08-20-2012, 08:30 AM   #3
Billett
Billett's Avatar
Took her out to Low Rollers!
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline
Old 08-20-2012, 11:08 AM   #4
Bennett68C10
Bennett68C10's Avatar
Congrats Billet, I miss going to Lowrollers End of Summer, hopefully mine will be done for next years show.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 08-20-2012, 11:22 AM   #5
RexDodge
Just got around to working on the carb yesterday. After changing the oil / filter and also draining enough water to get my anti freeze in, re installed thermostat, made sure block was full as well as the radiator. Started right up after about 1/4 throttle. It seemed sluggish so I advanced the timing a little (started at 12 btdc) and switched my vacuum advance line to the full time vacuum port. Still seemed to want a lot of throttle to start and spit a little till it cleared out. Neighbor stopped by (manages a local garage, good gear head) and said to take a bigger swing at it with a lot more advance. We cranked that sucker around A LOT and wow it sprang to life. Started with just a tap of the throttle, idled great and great throttle response. It seems to want around 18 degrees advance. I need to get a dial back timing light on it. I need to see what my total is. Neighbor said he thinks it is a tooth off. Moved the distributor one tooth clockwise. Tried to start it and noticed the fuel pressure was low...checked the gauge and was out of gas . I will get more fuel today (93 octane) and see what we get. The great thing I found is I seem to have around 10 inches of vacuum at the manifold. There's my update!
RexDodge is offline
Old 08-20-2012, 11:07 PM   #6
longbed67
longbed67's Avatar
Painted the cab!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline
Old 08-21-2012, 01:56 AM   #7
RexDodge
Well we got the timing and carb adjusted. Still a little too much advance but I still have a few things to do. I was able to take it out around the neighborhood tonight. The first time to drive it in 12 years. It felt really good. Everything worked well. Transmission is crisp, brakes are firm, runs on the cool side (even though it is new and tight) and sounds great. I have a couple of rattles to work on, fix a small exhaust leak, check the adjustment on the valves but mechanically I've pretty much got it done. I am just going to fill and seal the seams in the bed sides for now. Lots of work to do on the interior. Should have sound deadener, carpet, stainless sill plates and sound system in this weekend. For those who have access to facebook here is a link to a video
www.facebook.com/groups/Norhtwestc10s/
RexDodge is offline
Old 08-21-2012, 05:45 PM   #8
shopking72
shopking72's Avatar
Took off my grill finally. I am getting new inner and out grills tomorrow from LMC
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 08-21-2012, 07:52 PM   #9
71K20chevy
71K20chevy's Avatar
Painted the hood latch and all sorts of miscellaneous things.
71 K20
64 GMC mud truck
71K20chevy is offline
Old 08-21-2012, 08:07 PM   #10
trev1
Finally got the trim on the cab...Took a different approach to getting them on..Here are some pics.Name:  Dads Pictures 047.jpg
Name:  Dads Pictures 045.jpg
trev1 is offline
Old 08-21-2012, 09:09 PM   #11
mud.man.rj
mud.man.rj's Avatar
Is that screws holding the trim on, not clips.
mud.man.rj is offline
Old 08-21-2012, 10:44 PM   #12
ole dollor
ole dollor's Avatar
well today i sanded, and sanded, and sanded, put # 5 coat of paint on the top, and tail gate, and sanded some more......finished painting inside the cab, finished painting the door panels ,and arm rest, made a new bow tie for the hood, pained sun visor's , and dome light housing.....a few days ago i ordered a bunch of parts from GMC Paul....and then went back to sanding and body work.......
ole dollor is offline
Old 08-22-2012, 06:58 PM   #13
Hotrob72
Hotrob72's Avatar
Or maybe pop rivits ?
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline
Old 08-22-2012, 09:21 AM   #14
DevilDog Aggie
DevilDog Aggie's Avatar
Redid the rear drums. Have I mentioned how much I HATE drum brakes!!!!! Disc's I can do in my sleep, but drums whoop my ass!!! I put Reveille up on jacks Monday night so I could work on her as soon as I got home on Tuesday. The local PD saw fit to mark her as abandoned!!! REALLY?????!!!!!! Today's plan after work is to finish the front brakes and get her rolling again. Motor/Tranny is in good shape, runs great, just have to get her stopped! LOL!
Rob
'72 Chevy C-10 - 350-5.7/TH350/PS/PB/AC
Build Thread - http://67-72chevytrucks.com/vboard/s...87#post5503187
Semper Fi and Gig'em Aggies!
DevilDog Aggie is offline
Old 08-22-2012, 09:58 PM   #15
Boog
laying low
Boog's Avatar
Rob, man. That's pretty low down to slap a warning on your truck after one day on jack stands. And gives you 2 days to make it operable or it may be removed by the city. At your expense for sure. I don't even know you and it makes me mad. Popos don't do this without someone making the complaint. Have you been crossways with one particular neighbor? You know if their car ended up one night with the wheels removed and it sitting on blocks it might could be called in as "abondoned" ..... just sayin.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 08-22-2012, 10:31 PM   #16
Jarwood
Jarwood's Avatar
Cleaned under the hood and painted my grill.
Jarwood is offline
Old 08-22-2012, 11:00 PM   #17
VDOG
Grand PooBaa Member
VDOG's Avatar
Just when I was about to change my GMC frontend to a 67-68 chevy, you paint the grill and now im hooked. Great job.
VDOG is offline
Old 08-24-2012, 12:22 PM   #18
DevilDog Aggie
None that I know of. Have a feeling I know who it was and I have never met him or had any dealings with him. While I was working on it Wednesday afternoon, a guy down the street came up and said that the police were out again that morning looking at it. It is moved now though.
Rob
Old 08-24-2012, 12:38 PM   #19
1955 mancave
1955 mancave's Avatar
well today hung the hyd jack on the crane and fabricated a a rest for the boom to sit on, just sucks i cant weld so now i wait untill i can get one of my friends over.
1955 mancave is offline
Old 08-31-2012, 10:23 PM   #20
Southern Shaker
hahahahaahaha hey bud i know officer foster! i know the whole department an all thats crazy never thought id see that gave me a chuckle let me know if ya need help with the law
Southern Shaker is offline
Old 08-22-2012, 09:34 AM   #21
Billett
Billett's Avatar
that's crazy! where was it parked?
Will
2024 Toyota Sienna
Billett is offline
Old 08-22-2012, 09:39 AM   #22
VWNate1
VWNate1's Avatar
Exclamation Re : Curbside Auto Repair
The Gendarme's always hate this , or maybe one of your snoopy neighbors called them to complain .
I have a crazy drunken b*tch next door to me who's pi$$ed off I won't service her after my divorce so she calls the Police and Code Enfocement constantly , they go to my house and call me asking : ' where is this oil you dumped in the street ? everything looks nice and tidy here.... ' .
Snoopy old ladies and holier than thou Po-Po are a right pain in the bum .
Drum brakes are dead simple and easier than discs , once you have the cheap tool that makes those crazy springs easy to take off and on again .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-22-2012, 09:42 AM   #23
bgwss
bgwss's Avatar
Re: Re : Curbside Auto Repair
What is the easy tool, by chance?
1967 custom 351E V6 3/4 long bed
bgwss is offline
Old 08-22-2012, 09:51 AM   #24
NINERS1
NINERS1's Avatar
Installed my new dakota digital vhs guages! and they are nice! got the carbon fibre with blue lighting.
71 chevy cheyenne lwb
http://s321.photobucket.com/albums/n..._tab_my_albums
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!
NINERS1 is offline
Old 08-22-2012, 09:52 AM   #25
VWNate1
VWNate1's Avatar
Post Re : Brake Spring Pliers
Here ya go : http://search.yahoo.com/search?ei=ut...20pliers&type=
One picture shows how to use them.
Sears , Kragen , Shuck's , Pep Boys and your local Pawn Shop all have them , no need to buy the $nap - On ones .
There's another tool to remove the hold down springs easily , it looks like a screwdriver but with a round tip to hold the hold down spring as you twist it 90 degrees .
I'm sure you know to never , EVER take apart both sides at the same time ! therin lies madness .
Work carefully & safeley , support the truck on jack stands or an old stump , NO CINDER BLOCKS ! slide the rmoved wheel up under the chassis as a secondary safety support just in case .
-Nate
Geezer
VWNate1 is offline
Closed Thread
