Closed Thread
Old 12-23-2013, 02:23 PM   #1
legotech7
legotech7's Avatar
Re: What did you do to your truck today!
Maybe some of you can do some video's on the metal work you do on your trucks, so the rest of us novices might learn something... Nice work......
legotech7 is offline
Old 12-23-2013, 05:28 PM   #2
Rylie
Rylie's Avatar
Blasted, Primed, Sprayed with 2 coats of 2k epoxy bedliner. Made good progress today.
Rylie is offline
Old 12-24-2013, 12:34 PM   #3
67Slider
67Slider's Avatar
Took the ol truck and my little girl out this morning for breakfast. It is her 11th birthday and we have a tradition of going out for breakfast just the two of us. She still giggles when I punch the gas and the truck takes off. Good memories. Merry Christmas.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 12-24-2013, 06:46 PM   #4
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today!
GOOD DADDY ! .
Keep this up and you'll reap huge dividends in another 20 years.....
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 12-27-2013, 12:30 PM   #5
Prematuregrey
Prematuregrey's Avatar
Santa brought me some R&M wire looms. Nothing fancy but helped with routing a bunch.
Went from
To this
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline
Old 12-27-2013, 01:16 PM   #6
VWNate1
VWNate1's Avatar
Question Re : Accessory Oil Filler Extension
@ Prematuregrey ;
Where did you buy that oil filler extension ? .
I need one for my old GM Hearse and no one seems to carry them anymore .
TIA ,
-Nate
Went from
To this
VWNate1 is offline
Old 12-27-2013, 01:03 PM   #7
sboris
sboris's Avatar
Every little bit helps, ^^^looks good.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline
Old 12-27-2013, 02:30 PM   #8
Prematuregrey
Came on the truck. No telling where it came from. The engine has been in since the 80's.
Old 12-27-2013, 02:58 PM   #9
mud.man.rj
mud.man.rj's Avatar
Big block. mmmm ya.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 12-27-2013, 07:16 PM   #10
R.L.
R.L.'s Avatar
Installed my clutch petal getting ready for my auto to manual trans swap.
R.L. is offline
Old 12-27-2013, 09:02 PM   #11
69vetteside
69vetteside's Avatar
VWNATE1 ,trickflow make an oil extension ,i have one on my engine .makes filling the oil easy.got it from summit
69vetteside is offline
Old 12-27-2013, 09:23 PM   #12
texjake
texjake's Avatar
Since it was warm here today & no wind blowing, I spray painted my visors black.
texjake is offline
Old 12-27-2013, 09:38 PM   #13
midniteblues
midniteblues's Avatar
blasted some more parts today.
got my hinges put together and finished up.
and finally finished fabbing my trans c member it was also blasted and primed today.
i put a frosty beer can on my ta. c member before it was fully cured you can see the can ring right by the ece logo this was done a week or two ago oh well.
tomarrow lube finished parts and paint c member.
and reblast my f'ed up blackend door parts.
and prepare to FINALLY PERMENETLY! after one year mount my cab
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 12-27-2013, 09:47 PM   #14
alloutpro
Mailed out my application for my 60's plates drove her 2 hours and got some Moto seat time in...bought some new belts for her.....stopped only 4 times for gas....ahhhhhh
Roll Tide!
'69 C20 Longhorn 396
alloutpro is offline
Old 12-27-2013, 10:26 PM   #15
Lanman1972
Lanman1972's Avatar
Installed new window regulators. Finally after owning the truck for 2 weeks I can roll the windows up and down. Thanks to the help from the Forum it was an easy fix. Thanks Guys.
Lanman1972 is offline
Old 12-28-2013, 02:26 PM   #16
In The Ten Ring
Yesterday I received my weatherstrip order from WES at Classic Heartbeat.
I also picked up my Craftsman Double Angle Flare Kit at SEARS last week.
I'm very eager for spring to arrive so I can get back on my truck!
In The Ten Ring is offline
Old 12-28-2013, 06:06 PM   #17
jayman68
Fun Stuff
jayman68's Avatar
I designed a marker light cover plate that allows the deluxe lens to be mounted from the back, only the reflector part shows through. I think it is going to be cool.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 12-28-2013, 06:19 PM   #18
Sicklajoie
The Niner
Sicklajoie's Avatar
Cleaned up a lot of the stains on my intake with Freon tf solvent. I'm pretty happy with the results.
First pic is before, the last 2 are after.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline
Old 12-28-2013, 06:17 PM   #19
legotech7
legotech7's Avatar
Well the other day I noticed that my volt meter was reading a little under 12 volts,so I look under the hood and noticed that the bolt that holds the bracket under neath the alternator broke to where its bolted to the passenger side of the head on the engine..So I attempt to tap out the broken piece left in the head. I drilled a hole in to the broken bolt. ( That was no fun ) I tried to use an extractor to get the piece out, but I needed to drill the hole in further so I could tap in the extractor. I could get to go in as soon as I turned the the extractor it would just pop out. I tried to drill the hole another size bigger, but still I couldn't get it to come out. Anyone have any other Ideas as to how I can remedy this? It seemed so simple...but.... no.... Is there another type of bracket I can use that can mount else where? The alt. is mounted on the passenger side of the engine.
The top pic is where my head ache is.. And the bottom pic is the bracket that is on there now. Maybe some can tell me how to use a different mounting point... Thanks one and all.......
Old 12-28-2013, 07:55 PM   #20
frednoah
86 Scottsdale
Get a carbide cutter for a dremel, and take it slowly. I had a cheap extractor break off in a bolt like yours one time. I used a carbide bit with a ball tip like this one to bore a hole through the extractor and bolt. Once I did that I slowly took the bolt apart by making the hole in the center larger. When I got close to the threads I was able to use a larger extractor and it slid right out.
Note: Keep a magnet handy if you're going to do this with the head on the vehicle to try and corral all the shavings you can. I'd probably suggest pulling the head if that isn't a blind hole so you don't introduce fine metal to your engine/cooling system.
frednoah is offline
Old 12-28-2013, 10:29 PM   #21
jayman68
Fun Stuff
jayman68's Avatar
How deep did you drill? The threads probably go in about 3/4". It looks like you were off center to begin with, which only compounds the problem. (You probably already figured that out, sorry) You need to somehow get it back to center. Frednoah's suggestion would work great, just take it slow and easy. If the drilling goes too far and messes up the threads you can install a Heli-coil to restore the threads. If all else fails you could switch sides with the heads, then you would have a brand new hole to work with. (that's a lot of work)
Jay
68 C10(project)
88 Honda Accord(DD)
jayman68 is offline
Old 12-28-2013, 11:57 PM   #22
texjake
texjake's Avatar
There are a few different things you can try, the one from frednoah its a good one & get a torch & heat it up cherry red & let it cool down to room temp, the heat will take the hardness out of the bolt. Or you can try to chisel or use a punch out the extractor, even thou its harden steel it's brittle & you can chip it easier than drilling it out. Or you could try welding a grade 5 or 8 bolt to the broken bolt and if the weld is a great weld & it holds you could try to ease it out that way & work it while its hot. But that's only only after getting the extractor out first. Use a wax candle around the broken bolt after you heat it up, it will melt into the threads & acts as a lubricant. And/or get yourself a left hand drill bit and drill the broken bolt out. Use lots of heat to start with and it should come right out. Yes you have to run the drill in REVERSE, but this will work after you get the extractor out. Use a gas torch setup to get it hot before you use the drill bit on it & GO SLOW. Hope one of those works, not sure how far that extractor maybe into the threads on the head since it looks a bit off center. Other than taking the head off & taking it to the machine shop. Anything worth trying before having to pull the intake & head off & going to the machine shop.
texjake is offline
Old 12-30-2013, 07:28 PM   #23
legotech7
legotech7's Avatar
Well guys, I appreciate all your suggestions, and I will further to try tomorrow. In another forum I found a lot information and found another way to mount the alternator. They suggest I use a different mounting brackets you can mount at mid point on the passenger side with a special lower bracket that mounts to the back of the alternator that mount off the water pump. They use these brackets with engines that don't have the drilled holes in the heads. I just might do that instead. I figured out why the bolt broke in the first place. the PO put a different engine in the truck and sort of slapped it together. It didn't have the bottom bracket that goes off the water pump, so more or less the alternator was just hanging off the top bracket and created tension and that top bolt snapped, so I will get the bottom bracket and will probably get that med point bracket and be done with it.
I will post my results either way in case anyone else gets in the same situation.
Thanks again one and all.. Great forum.......
Old 12-29-2013, 09:31 AM   #24
dirtyjim
dirtyjim's Avatar
i installed my used cpp rear coilovers
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline
Old 12-30-2013, 06:24 PM   #25
NobleSix
i finally re-installed the defrost hoses and vents! picked up the 2 1/2 diameter flexible kind from autozone. so much nicer on those cold mornings
'69 c10 longbed granny 4spd 292 "Behemoth"
'67 c10 longbed granny 4spd 292 "Burzum"
some pictures of my work in progresshttp://photobucket.com/zaeea
R.I.P. Corey "Flattus Maximus" Smoot 11/3/11
You will be missed. Your sound lives on.
NobleSix is offline
Closed Thread
