Old 05-13-2010, 10:48 AM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
1970 steering column
I bought a 1970 steering column off of a truck
do I need to buy a u-joint or anyother product
for this instalation
Sick5 is offline   Reply With Quote
Old 05-13-2010, 01:26 PM   #2
Joemomma1
Joemomma1's Avatar
Re: 1970 steering column
no.
Just messin around. I think you can grab the lower section of a mid 70 chevy truck column and bolt it up.
Joemomma1 is offline   Reply With Quote
Old 05-13-2010, 01:49 PM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
That would be the lower part were the bar hooks up to the gear box under the fender
Would it be easer to buy a u-joint and if so wich one
Old 05-13-2010, 03:32 PM   #4
DPowers
One foot in front of the other
DPowers's Avatar
Do you just have the column or do you also have the lower section with the rag joint that bolts to the gear box?
DPowers is offline   Reply With Quote
Old 05-13-2010, 03:38 PM   #5
dallas71
dallas71's Avatar
I you have the upper and lower shaft all you have to do (maybe) is to drill out the bin and collapse the shaft a little and it should bolt right up to you steeing box. (that is all i had to do at least)
dallas71 is offline   Reply With Quote
Old 05-13-2010, 03:48 PM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
All i have is just the top portion of the culomn
Old 05-13-2010, 09:15 PM   #7
63 & 64 Bowties
and a few others
Sick5, this isn't an "instant message" forum. It may take a couple hours for answers. Bumping and asking the same question over again won't get you an answer any faster.
Be patient, or try dialing 911
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 05-13-2010, 09:24 PM   #8
Rich 5150 69
Rich 5150 69's Avatar
Sick5 you really need the intermediate section with the rag joint to take the vibration out...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-13-2010, 10:43 PM   #9
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
yes MR. Moderator
my double post was an accident that i cannot clear on my cell phone and my bump was clearly a call for help...
AND it looks like the last post was at 12pm almost 8 hours ago .. but im sorry
for trying to push for just a lil info that i could of got if i just SEARCH for
Old 05-14-2010, 10:53 AM   #10
DPowers
DPowers's Avatar
I can tell you what I did. I used the column from a '64 Impala on my '66. I used a Borgeson ujoint coupler that if I remember right got from Jegg's or Summit. Drilled out the plastic rivets and collapsed and repinned a lower section of a later model truck column and installed it with a new rag joint to my ps gearbox. Hope this helps.
Old 05-14-2010, 11:01 PM   #11
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
is that u-joint universal?
Old 05-14-2010, 11:33 PM   #12
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
65$ at the junkyard for the lower part of the steering column
Old 05-15-2010, 02:09 AM   #13
Joemomma1
Joemomma1's Avatar
Those guys are full of $h!t. Thats the price of a complete tilt over here.
Old 05-15-2010, 04:44 AM   #14
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
well maybe pnp has a 70's
Old 05-15-2010, 09:13 AM   #15
DPowers
DPowers's Avatar
http://www.borgeson.com/
They make several types and configurations. I used the one that is splined on the one end and d-shaft on the other.
Old 05-16-2010, 10:26 AM   #16
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
so i have to count the splines for the column and then spline on the bottom connection?
is the bottom connection has splines?
Old 05-16-2010, 10:50 AM   #17
Rich 5150 69
No you won`t have to count splines but it will be sized, 1 inch, or 5/8, I believe, if you get one from a truck it should match up.
Old 05-16-2010, 11:21 AM   #18
Chevy Fleetside
Chevy Fleetside's Avatar
This is a 73 Van column with a lower from a mid 70's Chevy Truck. I cut the original end off of the truck lower because it didn't match up with the van column and I used a 36 spline/DD u joint that was bought at a local speed shop.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-16-2010, 11:53 AM   #19
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
looks good!
i wanted to use less amount of money as possible.
update:
i meet up with 62bowtie he said shorten your lower rod with the rag joint
and buy a u-joint with 36 and 36 spline
looks like next weekend project
3/4 36 spline for the column and whats size for the bottom shaft 13/16
Old 06-10-2010, 02:05 PM   #20
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
i bought a borgeson 3\4 36 and dd
with a shaft dd
using d shaft to replace my ragjoint shaft
I hope a have the right size for the column side
70 culomn. Counted the spline 36 not sure it would be 3/4
Old 06-10-2010, 09:32 PM   #21
DPowers
DPowers's Avatar
Want final install pics when u get it done
Old 06-11-2010, 01:46 AM   #22
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
will do!
ima post some pic of a primer job i just did to day in a min
Old 06-12-2010, 03:38 PM   #23
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
update:
ujoint wont be in till monday
Old 06-14-2010, 09:35 PM   #24
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
well here is the ujoint. looking to get started this weekend
ill have more pic when i get started
Old 06-14-2010, 09:38 PM   #25
Rich 5150 69
They look to be stainless from the pics....?
