Old 06-02-2010, 09:14 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
NEW Porterbuilt Bolt-in C-notch for mild drop
I thought I would post up some pics of our new two piece bolt-in c-notch. I have been trying to find the time to finalize this thing for quite a while now… finally buttoned it up a couple weeks ago! This notch will be part of a complete mild drop system we will be releasing shortly, or we will be selling it separately for $249. This isn’t just an ordinary bolt-in c-notch… I put lots of thought into its design to ensure strength, and ease of installation. The fit on these notches is the best you can find in a production notch. We use factory frame-rail sections as a fixture to build them. Its two-piece design make installation a breeze. It locates using the two factory shock cross-member rivet holes on the top of the frame-rails, and then several holes are drilled. The first notch section can be used as a template and a support to cut the notch out of the frame-rails…. no more cutting, test fitting, cutting, test fitting, cutting… you get the picture! Once the frame section is removed, the lower notch will bolt in to the side and bottom of the rails. The lower section uses factory rivet locations on the bottom side of the frame, and also incorporates an air bag/spring plate (making it easier to drill the frame for mounting the air spring). The factory spring stiffeners remain in the chassis, keeping this baby as strong as possible. I will post more pics of the notch once I complete the mild drop kit I was referring to. There’s also more pics on my site for those who want to see more.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-02-2010, 09:36 PM   #2
jwalk
What was I thinking?
jwalk's Avatar
Re: NEW Porterbuilt Bolt-in C-notch for mild drop
Sweet!!!
jwalk is offline   Reply With Quote
Old 06-02-2010, 10:01 PM   #3
draggin86
draggin86's Avatar
very nice nate!
draggin86 is offline   Reply With Quote
Old 06-02-2010, 10:26 PM   #4
nds1968
nds1968's Avatar
This is what I've been waiting for. Lets hear more about "This notch will be part of a complete mild drop system we will be releasing shortly"
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 06-02-2010, 10:55 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
more about the mild drop kit..
nice man you put out some very nice products
John
1999 Toyota Tacoma 4x4
Old 06-03-2010, 01:17 AM   #6
noonzor
nice product, looks very simply laid out for install! i know my cpp notch didnt line up quite right when i originially cut, now chose to weld up and fill in for better strength.
as always a nice product nate!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 06-03-2010, 10:29 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Another well thought out product from the fine folks at Porterbuilt. Thanks Nate.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-03-2010, 10:44 AM   #8
Alvin
Never Done?
Alvin's Avatar
Wow, this is a beautiful piece. I don't know when, but I will be buying one!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 06-03-2010, 04:23 PM   #9
54Caddy
GM Addicted
54Caddy's Avatar
what is this mild drop more info nate..
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 06-03-2010, 05:31 PM   #10
SCOTTMO
powdercoater
Very Nice,I was going to ask you about a notch kit,now i don't,i just have to
add it to my list of things to buy from you.
SCOTT
SCOTTMO is offline   Reply With Quote
Old 02-27-2013, 02:00 PM   #11
zook
zook's Avatar
Looks like some good Quality Parts.
zook is offline   Reply With Quote
Old 07-25-2013, 10:12 AM   #12
TypeSL2
Any word on how this notch affects towing/hauling capacities? I want to still be able to use my truck after this kit is installed. Just trying to do my homework. Thanks!
James
TypeSL2 is offline   Reply With Quote
Old 07-25-2013, 12:11 PM   #13
PBFAB.COM
PBFAB.COM's Avatar
James
James-
This notch necessitates the removal of right at 1/2 the original frame width. This significantly decreases the strength of the chassis. Our bolt-in notch is a two-piece design that is stronger than the standard c-notches on the market... but not something I would recommend towing with. It is perfectly suitable for every day driving and light use as a truck is intended to see, but if you are planning to do any towing I would recommend NOT notching the frame.
Let us know if you have any further questions.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-25-2013, 08:43 PM   #14
TypeSL2
Thanks for the quick answer. I was reading some stuff on here, but the thread was started by a guy whose account was suspended, so I didn't know how much truth was behind the theory. I appreciate the honesty and may do business with you on other pieces later.
James
Old 07-28-2013, 11:26 PM   #15
jlaird
jlaird's Avatar
Nice product as always Nate!
jlaird is offline   Reply With Quote
Old 07-29-2013, 08:54 PM   #16
duallyjams
duallyjams's Avatar
Placed my order with Dave today, super easy thanks.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-08-2014, 03:08 PM   #17
smbrouss70
smbrouss70's Avatar
Does this notch allow you to keep the factory shock crossmember in place, or do you have to run the one you provide? I have recently dropped my Blazer and I don't want to have to change shock setups already, but I really like the 2-piece design of this notch over the others available. If (when?) I decide to go lower, I am thinking that I would want to use your mild step notch, would there be any problems changing to that later on down the road?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-15-2016, 07:19 PM   #18
crakarjax
crakarjax's Avatar
Is this the same notch that POL sells? If so they're giving you no credit...
https://www.performanceonline.com/19...-Bolt-in-Type/
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-15-2016, 11:02 PM   #19
Ram-Man
Ram-Man's Avatar
No not at all. The Porterbuilt notch is by far better built and thicker steel. Side by side there is no comparison.
Ram-Man is offline   Reply With Quote
Old 01-16-2016, 01:24 PM   #20
SCOTI
SCOTI's Avatar
Some POL stuff is from CPP.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-16-2016, 03:17 PM   #21
DENALI
Wish someone did this for a 1954 Model
DENALI is offline   Reply With Quote
Old 01-18-2016, 11:15 AM   #22
PBFAB.COM
PBFAB.COM's Avatar
Its a Chinese made knock off.
Good ideas are always copied.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-04-2017, 09:57 AM   #23
misfit0313
Is this still available? I was just browsing the Porterbuilt website and didn't see one for a 67-72.
misfit0313 is offline   Reply With Quote
Old 04-04-2017, 03:57 PM   #24
bbbc10
Diggin The SquareLife
call them or email them
bbbc10 is offline   Reply With Quote
Old 04-04-2017, 04:25 PM   #25
SCOTI
SCOTI's Avatar
Edited....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
