Old 06-05-2010, 10:53 PM   #1
dbmx66
finally some updates! motor, trans, tubbed. lots of pictures
title says it all
i made the door panels, the ingnition box panel, the lock things, and heater hose separator
dbmx66 is offline   Reply With Quote
Old 06-05-2010, 10:55 PM   #2
dbmx66
Re: finally some updates! motor, trans, tubbed. lots of pictures
more
Old 06-05-2010, 10:57 PM   #3
westofb
I really hate wet sanding!
westofb's Avatar
Nice work!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 06-05-2010, 10:57 PM   #4
dbmx66
even more
Old 06-05-2010, 10:58 PM   #5
dbmx66
more more more
Old 06-05-2010, 10:59 PM   #6
dbmx66
Originally Posted by westofb View Post
Nice work!
thank you sir
Old 06-05-2010, 11:19 PM   #7
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Dam....I love some pro street...Looking good
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 06-05-2010, 11:25 PM   #8
f.monroe
f.monroe's Avatar
That look still looks right on our trucks . I like the skinnies up front . They appear to be dual car pattern wheels so how did you get them to fit the truck ? Re-drill the front rotors ,modify the wheel ,or adapters?
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 06-05-2010, 11:31 PM   #9
dbmx66
thanks
Old 06-05-2010, 11:33 PM   #10
dbmx66
Frank
thanks, they make drag lites in 5x5s but the rears are 5x4.75 because there are custom moser axles in the rear
Old 06-06-2010, 01:12 AM   #11
team39763
Just awesome bro. Are those the stock framerails in the rear?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 06-06-2010, 06:35 AM   #12
dbmx66
stock, but the c-notches are welded on, everythings gusseted, plus the the ladder bar cross member, and the upper shock mount crossmember.
Old 06-06-2010, 10:13 AM   #13
68 TT
Still plays with trucks
68 TT's Avatar
Looks great but don't forget to put a grommet around the hole through the bed where the fuel lines pass through. It will cut the hose pretty quickly and the tech inspector will fail you for it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-06-2010, 10:48 AM   #14
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Nice looking truck.
Those are Heddmans; I have the same set (for sbc) in my basement. Can you snap a pic of the wire routing?
Thanks-
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 06-06-2010, 03:22 PM   #15
dbmx66
Originally Posted by PhilaTruck View Post
Nice looking truck.
Thanks-
ill snap one later tonight, ill send it to you then
Old 06-06-2010, 06:02 PM   #16
qu1cks1lver56
qu1cks1lver56's Avatar
Very nice.
qu1cks1lver56 is offline   Reply With Quote
Old 06-06-2010, 07:56 PM   #17
CoggedBelt75
CoggedBelt75's Avatar
Your truck is coming along quite nicely and in a relatively short time frame!! Good to see you chose this route. Keep the pics coming as you progress.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 06-06-2010, 10:55 PM   #18
trixter99
I have no time for this
trixter99's Avatar
How wide is your rear end from axle to axle?
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 06-06-2010, 11:00 PM   #19
slugish
Slugish
She sho looks *****in --Is her performance gonna match up to her looks --Im guessing yes. Awesome truck --love the squares done prostreet
slugish is offline   Reply With Quote
Old 06-06-2010, 11:14 PM   #20
dbmx66
i definatley will, thanks.
Old 06-06-2010, 11:16 PM   #21
dbmx66
right around 50 inches from axle to axle.
Old 06-06-2010, 11:17 PM   #22
dbmx66
hopefully itll be making a good amount of power, and thanks, right wen i bought it (going on 2 years ago) i wanted to tub it out. and thanks
Old 06-07-2010, 12:26 AM   #23
BruthaMan
US Army Veteran
BruthaMan's Avatar
Looking real nice! Every pic, I see $$ signs and lots of labor!
BruthaMan is offline   Reply With Quote
Old 06-07-2010, 03:18 PM   #24
dbmx66
thats very true, thanks man
Old 06-10-2010, 02:22 PM   #25
team39763
What are you doing as far as tubs? I've been thinking about redoing my bedfloor with thin aluminum sheets and prefabbed aluminum tubs(38 or 40").
