Old 06-08-2010, 02:49 AM   #1
ANDREW
Ok guys new idea... EFI need help
Ok guy so i need some help im workin on my truck and i get 10 mpg i was looking around and i think i want to swap over to efi what do you guys think its going on a 1983 chevy c20 5.7l 350 the kit that i was lookin at was the EZ EFI http://www.summitracing.com/parts/FST-30227-KIT/
and then just swaping out my intake and clean up the engine a little bit .. is there a better way is this kit hard to install has anyone had experience with this kit.. how long does it take to install.. sorry for all of the questions
thanks so much
Drew
ANDREW is offline   Reply With Quote
Old 06-08-2010, 03:59 AM   #2
draggin86
draggin86's Avatar
Re: Ok guys new idea... EFI need help
you could get yourself a 5.3 with tranny and harness for that much my friend that would be a nice motor with aluminum heads and 4 speed tranny cant beat that... right and you get like 22MPG!
draggin86 is offline   Reply With Quote
Old 06-08-2010, 02:57 PM   #3
ANDREW
Yea but thats a whole engine swap alot more work than the kit anyother options
Old 06-08-2010, 03:06 PM   #4
JNJchev77
Registered Cruiser
JNJchev77's Avatar
IMO I don't think you will get the results you want out of that kit... Search around on CL, you can find a low mileage LS motor and trans for less that the kit, and this may be a better "long term" option.
I hear those kits are decent, but if you have the time and some help think about doing the swap
JNJchev77 is offline   Reply With Quote
Old 06-08-2010, 03:28 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I helped a friend install one and he never was happy with it. We then swapped in a 4.8 and 4l60e and he gets about 24MPG on the Hwy.!!!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-08-2010, 03:43 PM   #6
rfmaster
rfmaster's Avatar
thanks so much
Drew
Do not waist your money on this kit (if your engine stock or even if you have RV cam) when it can be done for a lot less with OE GM parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=352321
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 06-08-2010, 03:48 PM   #7
78BO
78BO's Avatar
I was looking at that same kit last night. I don't think you'll get better MPG out of FI. If you do it'd be small and the cost would out weight the gains. The reason I was thinking about it was the performance part of it. For me, it'd be alot easier to tune. I don't know carbs, I know more about FI. And it looks cool. But I got to thinking it'd be a lot cheaper to just buy a FI system off of a older IROC Z. I'm running a 383 with vortec heads so work.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 06-08-2010, 07:57 PM   #8
ANDREW
Ok guys the engine swap sounds nice but i dont think it will be practical for me but.. the oe tbi sounds nice anyinfo on tht maybe i should get a new intake and carb ??
Old 06-08-2010, 08:18 PM   #9
ANDREW
ok guys i like the engine idea but i dont think it is practical right now i do like the sound of the OE efi conversion idk theres alot of ideas up in the air or should i just swap new intake manifold nd carb?
Old 06-08-2010, 08:33 PM   #10
tucsonjwt
I have owned both 1/2 ton and 3/4 ton Chevy pickups - old and new, straight 6, V6, V8 (350, 454, 4.8, 5.3, etc.). Best gas mileage I got was on the 4.3L V6 - 20 city/23 hwy. in a 2000 1/2 ton long bed.
You have a 3/4 ton pickup, so you are hauling around another 1000 lbs. more than a 1/2 ton - that tends to kill gas mileage, regardless of your engine (unless some diesel setups.)
I assume that you want better gas mileage to reduce cash out of pocket expense. I would do a simple calculation:
Miles driven per year / 10 mpg avg. = gallons per year consumed.
Miles driven per year / ? mpg expected on new set up = gallons consumed.
Difference in gallons consumed X $ per gallon cost = $ saved per year.
My V8 1/2 tons got 17mpg city/21 mpg hwy - best case, driven like grandpa.
Most people I know average 14-15 mpg. overall with their new/newer 4.8 or 5.3 1/2 ton pickups - but they drive "normally".
I think if you do the calculation above you will find it makes no economic sense to try to improve gas mileage with a new fuel injection system or new engine/trans combo. If gas were $25 per gallon - maybe.
I currently have a 83 C20 454 granny 4 speed and I only drive it in the city - I get 10 city/13 hwy.
But each to his or her own. Good luck.
tucsonjwt is offline   Reply With Quote
Old 06-08-2010, 08:57 PM   #11
78BO
78BO's Avatar
What are your plans? Why do you want to do this? If you have the money and you're building a rod then hell yea go for it.
Old 06-08-2010, 09:09 PM   #12
ANDREW
i want it to be reliable the carb i have on there now isnt nd it sucks up alot of gas its the 800cfm quadrajet my motors stock but headers and an exhust system i just want to get a little more mpg than 10.. its my daily driver
Old 06-08-2010, 09:28 PM   #13
78BO
78BO's Avatar
OMG, pardon me, but that's your problem. That carb is WAY to big for a stock engine. The heads on that thing can possibly flow enough to process that much fuel. You're just dumping gas out the pipe. Save all your money, buy you a nice 600 cfm Edl/Holley carb and upgrade the ignition (hot coil, plugs, wires, cap and rotor). That will cost around 3-400 bucks and you'll think you have a hole new truck.
Old 06-08-2010, 11:30 PM   #14
ANDREW
Along with that 600cfm carb im going to do a new intake manifold (any recomendations) and i was also thinking my uncle has a set of camel hump heads can i put thoes on too
Old 06-08-2010, 11:49 PM   #15
deepnsteep
You could try this engine computer. You would have tons of options for sensors, injectors, throttle bodies, etc....
You can buy them as a kit to assemble or already built.
http://www.msefi.com/index.php
deepnsteep is offline   Reply With Quote
Old 06-08-2010, 11:55 PM   #16
71swb4x4
71swb4x4's Avatar
If fuel economy is your main goal swapping in a 700r4 would be your best bet.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-09-2010, 01:58 AM   #17
ANDREW
It has the 700r4
Old 06-09-2010, 02:21 AM   #18
355bullet
355bullet's Avatar
have u tried this one?....friend of mine converted his jeep to GM TBI..he highly recommends this place
www.affordable-fuel-injection.com
355bullet is offline   Reply With Quote
Old 06-09-2010, 02:42 AM   #19
ANDREW
ok so i think im just going to stick with a carb its cheaper .. what im thinking of doing is getting a new carb a new intake manifold and my uncle is giving me a set of camel hump heads that will be going to the machine shop for a freshing up and a valve job i think it will be more responsive and it will get a little better mpg instead of that big carb i have now? any tips on what carb and what manifold will thoes heads be good
Old 06-09-2010, 08:08 AM   #20
tucsonjwt
Just curious:
What mpg are you expecting to achieve? That will determine what you should do.
Old 06-09-2010, 08:49 AM   #21
78BO
78BO's Avatar
It depends on what valves they have and how much you want to spend. If it were me I'd have the heads worked first. But if you do that why not a new cam? Buy then that 600 would be too small and you'd need a 750.
So you really need to figure out what you are going to want. These pushrod v8s just aren't going to get good gas mileage if you start making more power. If you have a few grand to throw at it I’d spend some money on a top end kit like this one (http://www.jegs.com/i/Edelbrock/350/...oductId=760264) and I’d keep the 800. You just need to find someone that really knows how to build them. Rochesters aren’t bad, they’re just tricky.
Anyways, like I said you just really need to know what your future plans are for it. If it’s just a work truck daily driver and you want reliability and drivability I’d go with the 600 and ignition system, and save up for a 4 speed and gears.
Old 06-09-2010, 02:03 PM   #22
ANDREW
ok i think im going to just do the intake carb and the heads from my uncle there 202 camel hump heads.. i am going to have them sent to the machine shop to get a full valve job
Old 06-09-2010, 03:27 PM   #23
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I can get 15 MPG in the city with my 355 HP motor. A tuned carb makes a difference. However, it's a truck.
Use a dual plane intake. An Edelbrock performer works great on a stock motor. Drop the carb down to less than 650 CFM.
If you are interested in stock GM tbi FI read this article: http://users.sfo.com/~eagle/howell.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-09-2010, 04:01 PM   #24
78BO
78BO's Avatar
But don't you have a 4speed? I thought you had a 700r4? Gears make a big difference.
Old 06-09-2010, 04:55 PM   #25
ANDREW
ok so im thinking about this intake
http://www.summitracing.com/parts/EDL-27011/
this carb
http://www.summitracing.com/parts/EDL-1406/?rtype=10
and the camel hump heads from my uncle
is the intake and carb a good choice or is there something better you guys recomend
