06-18-2010, 09:55 PM | #1 |
driving is in my blood
Why can't they set my caster to spec?
I had my alingment done today. Spec for caster is 2.8-4.8*, They set left to 5.0* and right to 5.7* Cross caster was in spec at .7*. Why would the two sides be off like this?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-19-2010, 08:38 AM | #2 | |
Re: Why can't they set my caster to spec?
What kind of truck? how much lowering? with what method?.....we are not mind readers
The difference from side to side is to compensate for the crown of the road, but why they left it with so much is hard to say. Did they say that this was as close as they could get?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-19-2010, 02:07 PM | #3 |
Sorry I relized it as soon as I wasen't near a computer. Its on my 98 gmc 1/2ton. It is lowerd with 2" belltech spindles and 3" western chassie springs. I didn't get a chance to talk to them [had brother do it while I was working] but the before and after specs are both above the max factory spec and the previous alingment was a different shop so Im assuming its the best they can do.
06-19-2010, 05:18 PM | #4 |
you need special longer bolts to attach the upper aframe crosshaft and spacers when using those shorty springs
some slignment shops have them
06-21-2010, 12:19 AM | #5 |
Can't find anyone around here who knows what Im talking about. Anywhere I can order these pieces online so I can install them myself?
06-21-2010, 12:48 PM | #6 |
Active Member
The suspension gained caster as soon as the rear was no longer higher than the front. You may be out of adjustment range.
Caster is an imaginery line from the center of the pivots between the upper and lower balljoints measured to verticle. So lowering the back several degrees to make the truck sit level increased the caster by several degrees. If the front springs are any shorter than new OE length then you would have increased caster again. This because of the anti-dive geometry, it increases caster as the suspension is compressed. All this extra caster will do is make the truck want to drive straight. it will take more effort to turn. If you can turn OK then I would not worry about how hi or low the number is. Danny Nix CPP |
06-21-2010, 02:47 PM | #7 |
I'm just glad to be here!
That is the same thing I was thinking when I read thru this thread...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-21-2010, 07:38 PM | #8 | |
That is true mostly.....an extreme amount of caster causes "camber gain". Meaning that the wheel "tilts" more as it is turned. This puts more pressure on the edges of the tread. This accelerates tire wear and higher in-put effort as well.
06-21-2010, 09:52 PM | #9 | |
I've been trying to get rid of a pull to the right and vibration, 2 alingments and 2 sets of tires hasen't done it so I was thinking perhaps the caster was the cause. I won't worry about it from now on. Thanks
06-22-2010, 01:01 PM | #10 |
TNT-MOTORSPORTS
One thing I am curious about and saw no mention of is did they knock out the plugs in the upper control arm mounts for the upper control arm eccentric bolts. This gives it alot more adjustability. My crew cab 1-ton converted to 1/2 ton with belltech spindles and springs is dead in spec and has excellent tire wear and drives excellent ,it is down about 5" in the front. As for your vibration that may be a case of diagnosis by elimination, lowered trucks I have seen vibrations (shudder) caused by pinion angle, loose u-joints , tight u-joints ( have to remove driveshaft to find this one) etc....just throwin some ideas out there...!!!!!!!!
