Old 06-27-2010, 10:55 PM   #1
Kmart2352
Kmart2352's Avatar
TBI bogging?
I have an 87 GMC 350 TBI. I recently just put a mild cam in it. The first day after putting in the cam it ran great and did not hesitate at all. Now about 3 days later the truck is bogging when you accelerate and it has a pop and or skip in it.
The timming is right on 0. and i just put new spark plugs in it today. The other plugs were very black.
anyone have any ideas to fix this?
87 2wd GMC Sierra Classic.
86 4wd GMC Sierra Classic.
95 2wd GMC Sierra.
96 2wd Chevrolet S-10.
Kmart2352 is offline   Reply With Quote
Old 06-28-2010, 12:32 AM   #2
jake wells
Re: TBI bogging?
try advancing the timing a few degrees
-Jake
jake wells is offline   Reply With Quote
Old 06-28-2010, 08:24 AM   #3
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
I had the timming advanced and it did the same thing.
95 2wd GMC Sierra.
Old 06-28-2010, 09:54 AM   #4
Jonboy
Slots go on anything!
Re: TBI bogging?
Check the TPS.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 06-28-2010, 12:20 PM   #5
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
What is the tps?
95 2wd GMC Sierra.
Old 06-28-2010, 01:11 PM   #6
bigarmzz
bigarmzz's Avatar
Re: TBI bogging?
Originally Posted by Kmart2352 View Post
What is the tps?
throttle position sensor
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 06-28-2010, 02:11 PM   #7
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
where is that sensor located?
95 2wd GMC Sierra.
Old 06-28-2010, 11:42 PM   #8
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
Now when you hit the throttle at all the truck just pops and skips and sometimes backfires.
95 2wd GMC Sierra.
Old 06-28-2010, 11:51 PM   #9
chevymotocross
chevymotocross's Avatar
Re: TBI bogging?
Is it throwing a code? What's your fuel pressure? I know you stated it ran fine when you first ran it, but how big of a cam is this? Did you get a new chip burnt for running this cam?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 06-29-2010, 07:25 AM   #10
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
it is not showing a code, and i am not sure what the fuel pressure is. But the cam is a .444 intake and .466 exhaust over a duration of .50, it is a mild cam. the truck is already chiped but not for this cam.
95 2wd GMC Sierra.
Old 06-29-2010, 02:45 PM   #11
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
Today i am going to adjust the lifters yo see if that doe anything.
95 2wd GMC Sierra.
Old 06-29-2010, 07:31 PM   #12
Trick76
Living la vida broka
Trick76's Avatar
Re: TBI bogging?
when you set the timing did you disconnect the brown timing wire?? I know on my '88 it ran like poop until we did that.
1976 C10 Longbed lowered 5/7, hot 355/TH350. ~ SOLD
1974 C10 Shortbed Stepside 350/Saginaw ~ SOLD
1984 C10 Longbed 6.2l diesel 700r4. ~SOLD
1985 GMC C20 350 700r4, ~under the knife
Trick76 is offline   Reply With Quote
Old 06-29-2010, 09:22 PM   #13
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
What do you do with that wire and where is it located? Someone told me today that there is something that i have to do before I time it, but he told me that it has to do with the OBD I and not a wire
95 2wd GMC Sierra.
Old 06-29-2010, 09:35 PM   #14
joe231
joe231's Avatar
Re: TBI bogging?
there is a brown (I believe) wire between the brake booster and bulkhead connector that needs to be unplugged before you set timing. that takes the timing control away from the computer
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-29-2010, 09:52 PM   #15
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
I just looked and the only brown wire that i saw was in a connector of two of them. Would that be the right one? because it is between the booster and the motor. And what is the bulkhead exactly?
95 2wd GMC Sierra.
Old 06-29-2010, 10:07 PM   #16
joe231
joe231's Avatar
Re: TBI bogging?
The bulkhead connector is where the wires go through the firwall to the fuse block.
Should only be one wire. Might be tan instead of brown.
CHEVY ONLY
Old 06-29-2010, 10:15 PM   #17
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
Alright tomorrow I am going to try to find it and time it the right way
95 2wd GMC Sierra.
Old 06-29-2010, 10:30 PM   #18
joe231
joe231's Avatar
Re: TBI bogging?
I found this on here....
White arrow is pointing to the connector. Tan wire with a black stripe
CHEVY ONLY
Old 06-29-2010, 10:33 PM   #19
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
Thank you. hopefully i can get to it tomorrow. That picture really helps.
95 2wd GMC Sierra.
Old 06-29-2010, 11:09 PM   #20
joe231
joe231's Avatar
Re: TBI bogging?
no problem
CHEVY ONLY
Old 06-30-2010, 10:30 AM   #21
chevymotocross
Re: TBI bogging?
Not pulling that wire before setting timing will definitely cause wrong timing! Of course remember to hook it back up after timing it. Shut the truck off though before you re-connect or disconnect that wire, atleast that's what I do.
Old 06-30-2010, 11:59 AM   #22
Kmart2352
Kmart2352's Avatar
Re: TBI bogging?
well hopefully that whats happening right now. tonite i am going to try to fix it along with the tps and the temp sensor. thank you for the help. i will post what happens tonight.
95 2wd GMC Sierra.
Old 06-30-2010, 12:21 PM   #23
Desert1957
Desert1957's Avatar
Re: TBI bogging?
HEY! That picture looks familiar?
Desert1957 is offline   Reply With Quote
Old 06-30-2010, 05:55 PM   #24
joe231
joe231's Avatar
Re: TBI bogging?
somebody stole it!
CHEVY ONLY
Old 06-30-2010, 07:55 PM   #25
Trick76
Trick76's Avatar
Re: TBI bogging?
on my 88 you had to remove a plastic cover over the fuseblock and there was a tan wire with a connector, running toward the brake booster. disconnect it, time the truck, restart and voila!! yeah its like 15-20 degrees retarded if you dont do that, even worse with a cam, lol.
Derek
