Old 07-10-2010, 04:02 PM   #1
Puglia10
Frustrated! trying to get bushings out of control arms
hey everyone, replacing all my bushings, trying to get them out of the bigger(lower?) control arms. got them out with an air chisel in the smaller a-arms, but dont know how to get these big ones out, is there a trick!? press? heat and chisel? someone help me please, its been a long day
1979 c30 3+3 dually
1946 GMC
Puglia10 is offline   Reply With Quote
Old 07-10-2010, 06:16 PM   #2
jmedero
jmedero's Avatar
Re: Frustrated! trying to get bushings out of control arms
I torched mine up and they came right out.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-10-2010, 06:28 PM   #3
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
X2...only took about 5min. With a torch and a long flathead screwdriver...just hose off the bushings after their out cause they will stay on fire for a long time
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 07-10-2010, 07:31 PM   #4
LONGHAIR
Pressing is the proper way....you do still need to get them back in. The press does that for you too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-10-2010, 10:19 PM   #5
chevymotocross
chevymotocross's Avatar
I'm not sure if the control arms are much different, but I recently put all new bushings in my leaf springs. I burned out the old rubbers. Then I took a sawzall to slot the old sleeve. Took an air hammer and got those out. Used a regular bench vise, and pressed the new bushings in. Quite easy to do. I would assume the control arms would be the same concept.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 07-11-2010, 02:41 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
controls arms probably arnt going to fit in a vice i say press
John
1999 Toyota Tacoma 4x4
Old 07-11-2010, 02:45 PM   #7
Cherub
Cherub's Avatar
I just used a heat gun and air chisle and they came out fairly easy.
Cherub is offline   Reply With Quote
Old 07-12-2010, 01:00 PM   #8
Puglia10
man, i wish mine came out easily! had torches, air chisel, a press...they gave me a fit, but they came out! thanks everyone
1979 c30 3+3 dually
1946 GMC
Old 12-03-2010, 08:22 AM   #9
Gordonr1973
Home Built '87
Gordonr1973's Avatar
This is how I got out my bushings....5 minutes in the fire and then sawzall'ed the ring, then air chiseled them out.
Am going to use a press to get the new ones in this weekend. Will get my brother hopefully to help me hold the leaf spring / control arms when doing it.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 12-03-2010, 12:07 PM   #10
62 Bowtie
62 Bowtie's Avatar
Gonna do mine soon I was thinking just go to a shop and have em pressed out and replaced
62 Bowtie is offline   Reply With Quote
Old 12-03-2010, 02:39 PM   #11
raycow
I like the idea of using fire to get the bushings out. It just seems to fulfill some kind of primal urge <ducking>......
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-03-2010, 02:39 PM   #12
Clyde65
Clyde65's Avatar
That is what I did Raycow.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-03-2010, 03:27 PM   #13
Shane
Shane's Avatar
it's like a beavis and butthead convention around here with all the talk of fire ...
Shane is offline   Reply With Quote
Old 12-03-2010, 05:45 PM   #14
LONGHAIR
And you don't think that this fire has some negative effect on the steel? A legit cutting torch is a much more concentrated heat source, which could be directed at the bushings....but I am not a fan of either.
Old 12-04-2010, 02:52 AM   #15
ozman3803
Sorry but I agree that may take some integrity and strength from the metal. Torch would be ideal but press was better
ozman3803 is offline   Reply With Quote
Old 12-04-2010, 08:42 AM   #16
Gordonr1973
Home Built '87
The idea of using a hole saw to cut the rubber bushings to create a bit of room then using a press would be easiest.
I have a press, air chisel, vice --- but no torch and nothing was working for me...so fire it was.
As for metal integrity, time will tell. I'm not an engineer but IMHO 5 minutes in an open fire while the outside air temperature is -20'C is not the same amount of heat compared to seeing a burned out vehicle at a wreckers with warped metal.
So it's up to you if you are reading this thread to decide whether you will "try this at home".
Gordon
Old 12-04-2010, 01:10 PM   #17
Puglia10
i used a torch, hopefully it wont affect the metal. Hey GORDONR, do you have any more pics of the lowers? I need some of the bumpstop area you can see in the pic you posted, (mine are crushed and i need to fab up some new ones, but i dont know what theyre supposed to look like) any better pics of it would be AWESOME! Ive been searching forever, thanks!
1979 c30 3+3 dually
1946 GMC
Old 12-04-2010, 01:44 PM   #18
69 longhorn
Here in Illinois, everything is rusty! Fire is my best freind I have always "cherried" the outer ring of the bushing with my torch, & left the a arm outside to burn the rubber off. After that, I carefully cut the outer shells (also with a torch), let the arms cool & just tap em out with a small hammer. With a combo of the proper sized pcs of pipe (or sockets), you can press the 1st bushing in a bench vice. Add the cross shaft & the 2nd bushing, then cut a lenght of angle iron to fit tween the inside of the arm (bottom side for support), & you can use your pcs of pipe to drive the 2nd bushing with a hammer. Dont forget the support tween the inside of the arm, or YOU WILL BEND THE CHIT out of the arm! This has never caused me a problem(not the fire , or the hammer), if done carefully crazyAl
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 12-04-2010, 03:22 PM   #19
Gordonr1973
Home Built '87
These are the best ones I have. I'll try to take some tomorrow, PM me to remind me if I forget!
Gordon
Old 12-05-2010, 10:53 PM   #20
D.FENS
I use a propane bottle torch to burn bushings out. Not as hot as an oxy-acytelene rig and doesn't heat up the surrounding metal as much.
Takes a little longer but I don't like to hurry working on stuff like that anyway.
D.FENS is offline   Reply With Quote
Old 12-06-2010, 01:32 AM   #21
Gordonr1973
Home Built '87
Here are the pics....
Gordon
Old 12-06-2010, 12:47 PM   #22
Puglia10
Thank you so much for the pictures!! I appreciate it! Now I just gotta make something similar, haha. Anyone know what the drilled hole on the right is for? I know the left slit is for the bumpstop
1979 c30 3+3 dually
1946 GMC
Old 12-08-2010, 12:41 PM   #23
62 Bowtie
62 Bowtie's Avatar
so by burning your only removing the rubber part right? can i replace the rubber part only? the pic at Orileys auto shows the rubber only no sleeve or should i order elsewhere a kit that has the sleeves thanks, Tony
Old 12-09-2010, 01:35 AM   #24
Gordonr1973
Home Built '87
With mine the rubber burned out on it's own. The metal sleeve that touches the control arm stayed intact and inplace (until I hammered it out of there)--- mainly because it was rusted in there.
I heard you can buy just the inside rubber bushings on its own and press it into the old sleeve....I went with a one piece Energy bushing set myself and btw, am having alot of problems getting them into the openings....will need to take them into a shop to get installed.
Gordon
Old 01-20-2011, 02:18 PM   #25
Puglia10
bumping this because the new ones are pressed in but the bump stop area is still crushed. Is that all necessary? The slit for the bump stop on the left, then the right side has a hole drilled (whats that for?) and then the piece sticking out from that, is that the steering stop? Has anyone else had crushed ones, what are my options? It seems impossible to recreate that perfectly as I dont have measurements from a good one or anything. Thanks
1979 c30 3+3 dually
1946 GMC
