Old 08-20-2010, 03:19 PM   #1
HSkinner
96 Caprice (COP CAR) rear axle with disc brakes
I just picked up a rear axle with disc brakes out af an older caprice. Anybody know how the width will match up. Already did my 5 lug conversion on the fron end to a mid 80's chevy truck. Thanks
HSkinner is offline   Reply With Quote
Old 08-20-2010, 03:38 PM   #2
p_rubottom
p_rubottom's Avatar
Re: 96 Caprice (COP CAR) rear axle with disc brakes
Does the cop car have a ten bolt like the SS impala? Regular Caprices have eight bolts, i was told they wont work.
p_rubottom is offline   Reply With Quote
Old 08-20-2010, 04:51 PM   #3
HSkinner
its a ten bolt.
Old 08-20-2010, 09:47 PM   #4
65 on 24's
65 on 24's's Avatar
i put that in my 65 its like a 1 1/2 shorter on each side, if u want to see pic's go to myspace.com/vcofmemphis and there pics of it, it help we out cuz my wheels r so wide, it tucked them in some,
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 08-20-2010, 11:23 PM   #5
sshockr
Everything is 10 bolt on caprices. The difference is the 4.3L cars generally had 7.5" rears and the 5.7L cars had 8.5" And unfortunately Cop Car does not guarantee 5.7L, many were ordered with the 4.3L for fuel economy. Cop Rears are wider than Impalas. I can't remember the actual dimensions off the top of my head though.
I've got the 8.5" with 4.10's and an Eaton Posi in my Impala and it seems to take whatever punishment I can throw at it.
-Brian
1963 Long Bed C10 - LT1/4L60E Swap in Progress. Blew up the straight six and happened to have the engine trans combo on hand already.
1995 Impala SS - LT1/T56 Combo. This is my 1st priority project.
sshockr is offline   Reply With Quote
Old 08-21-2010, 12:10 AM   #6
Captainfab
60-66 Nut
I don't know just how wide they are, but it seems that someone here has done that swap, I just don't know who.
Since you have it there, I would just throw a tape on it and measure it. Your original truck rear end measures 62" WMS to WMS. That will give you a measurement to compare to.
Old 08-21-2010, 01:03 AM   #7
nomrlz
nomrlz's Avatar
here is a complete lineup of these rear-ends. i've had good luck with the stock rear in my wagon and it pulls 1.69 sixty foots at 4700+lbs
Chevy
91-92 sedan
1566mm - narrow (all)
93-96 sedan
1566mm - narrow (9C1 - disc & drum & some other drum applications)
1598mm - wide (Impala SS - disc & B4U - drum)
Buick 91-96 & Fleetwood 93-96 sedans
NOTE: Fleetwood housing is unique to the application - 4-channel ABS provisions
91-96 wagon, all
1642.5mm
All 93-96 7.625" (ring gear) housings are 1598mm wide (Chevy sedan only)
Sedan housings, in both widths, have the same lower control arm bracket location/spread distance, and will fit any other sedan frame. Wagons have a wider spread distance (approx. 2") between lower control arm brackets on housing, and corresponding wider frame lower control arm mounts.
nomrlz is offline   Reply With Quote
Old 08-21-2010, 06:37 PM   #8
65 on 24's
65 on 24's's Avatar
i just looked mine is 57in from backin plate to backin plate, and mine had 3.23 grears, and it came out of a caprice.
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 08-22-2010, 12:25 AM   #9
Captainfab
60-66 Nut
Measuring backing plate to backing plate is inaccurate and not the correct way to measure the width of a differential. You need to measure wheel mounting surface to wheel mounting surface (WMS to WMS) as this determines the location of the wheels.
Old 08-22-2010, 01:29 AM   #10
chevyguys
I Got it BAD!
chevyguys's Avatar
My buddy put a 94 caprice cop car rear in his.. Here is the thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=358328
Fit's perfect. The only problem he has been having is trying to find the shoes for the emergency brake. I guess they are not available anymore. They look like small version of normal brake shoes.
Build Thread: http://www.chevyguys.com
chevyguys is offline   Reply With Quote
Old 08-22-2010, 02:16 PM   #11
HSkinner
is there any draw back to a 4 link set up as opposed to the factory set up? my intention is to bag it and get it as low as possible.
Old 08-22-2010, 09:21 PM   #12
creep
Registered Loser
creep's Avatar
A triangulated 4 link will eliminate the side to side travel of the axle caused by the panhard bar.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 08-27-2010, 01:05 AM   #13
chopper john
chopper john's Avatar
1996 chevy caprice with disc brakes. it was perfect on steel wheels. but i pulled the rear fenders a little so i can clear reversed wheels
chopper john is offline   Reply With Quote
Old 01-28-2011, 12:39 PM   #14
jimmydean
jimmydean's Avatar
I just found a '94 Impala SS rear locally and am thinking of getting it for mine.
Captainfab, can the Camaro calipers be used in place of the Impala's? Don't the Camaro's use a built in e-brake in stead of the crazy mini-drum thing? I have to have an e-brake, but if the price is right, I wanted to see if swapping calipers would be an option.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-28-2011, 01:13 PM   #15
no moa
no moa's Avatar
-Brian
Impala rears are wider than the 9c1 rears. The 9c1 rears were narrowed for the use of tire chains on the police packages.
I have only 2 4.3 police cars, the other 9 are all lt1 5.7 cars. And all 9c1 4.3 L99 cars came with the 8.5 rear. GM did not use the 7.5 ring for any poice cars. They would not hold up. Soi have found anyway.
93-96 sedan
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 01-29-2011, 01:40 AM   #16
Captainfab
60-66 Nut
The Camaro caliper mounting brackets (Factory part) that the actual caliper mounts in is different than with the Impala SS calipers. I can check tomorrow and see if the calipers themselves will interchange in the factory brackets.
Old 01-30-2011, 01:42 AM   #17
Captainfab
60-66 Nut
Sorry to say that the '93-'97 Camaro rear calipers will not fit onto the '94-'96 Impala factory caliper brackets (cages).
Old 02-01-2011, 06:31 PM   #18
jimmydean
jimmydean's Avatar
I'm not finding a whole lot of info on this swap.
So with the Impala SS rear, do I need to do anything with the driveline or yoke? Are the axle tubes the same size as the C10? So I just need to weld on the perches and bolt it in?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-01-2011, 11:28 PM   #19
pmkrew
Pretty much a weld in deal make sure to set your pinion angle...
pmkrew is offline   Reply With Quote
Old 02-02-2011, 01:13 AM   #20
Captainfab
60-66 Nut
Since chopper john put one under his truck, you might send him a PM and see what he has to say.
Old 02-02-2011, 01:32 AM   #21
jimmydean
jimmydean's Avatar
I did, but hadn't heard back from him yet. Sounds pretty basic, not unlike most everything else on these rigs.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-02-2011, 02:10 AM   #22
Captainfab
60-66 Nut
I haven't installed one of these differentials, but it shouldn't be any different than any other differential swap.
You'll have to remove all unnecessary factory brackets from the new differential. Then you will need to weld trailing arm mounts to the new differential in the correct position. This includes the side to side angle for the trailing arms as well as the corrrect pinion angle. Then you will have to fabricate or install a kit to mount the panhard bar on the new differential. The it's just a matter of hooking up the e-brake cables and brake lines.
Old 02-02-2011, 02:35 AM   #23
chopper john
jimmy dean pm sent. i also had to shorten the drive shaft a little, and maybe change the rear u joint
Old 02-02-2011, 08:36 AM   #24
lakeroadster
That's pretty much a show stopper.
lakeroadster is offline   Reply With Quote
Old 08-27-2011, 04:20 PM   #25
jimmydean
jimmydean's Avatar
Took a while, but CL came through. $50!
94 Caprice 3.08 open gears. I wanted a posi unit, but $50 was too good
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
