Old 09-10-2010, 09:17 AM   #1
BamaDave
Score at pick n pull, now need help.
I have been looking for one of these for a really long time! Needless to say I am stoked to find one. I got it out of a 82 Blazer. I wish it was in better shape but at least I have the essentials. I plan on using parts off of my current cluster to replace the lens, and probably the housing. The printed circuit board has one spot on one of the blinker bulb connections that has come apart. I am goning to try and use epoxy and some super glue to fix that. Copper is still good, just the laminated part has come apart. I have a 86 Sierra Classic. If I am not mistaken, this should be a plug and play. Let me know if I am wrong. I got this thing with the tach harness(wire) for 50 bones! I have seen them going on ebay recently for upwards of 250-275, although they were in better shape. What do you guys think?
*UPDATE* I hope this will fix some of the problems that were discussed on here. Thanks c10sport! See my last post for the pic.
BamaDave is offline   Reply With Quote
Old 09-10-2010, 09:45 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Score at pick n pull, now need help.
Wanna double your money?
Awesome find!
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-10-2010, 12:31 PM   #3
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
Fantastic find!
I'm nearly certain it will plug and play in your '86.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 09-10-2010, 05:28 PM   #4
pugs
pugs's Avatar
wires going into the plug will more like be in the wrong position to match up to the printed circuit board on the back of the cluster
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 09-10-2010, 07:01 PM   #5
b454rat
It will be a plug and play, just need to wire the tach. I did a couple tach dash swaps, no issues.
Oh and I wish they were selling for that much, I just picked up one like that from an 83 C60, only diff is no unleaded fuel only on the gas gauge, got that for $20. Makes 3 of these now. Actually free, didn't pay for it yet...
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 09-10-2010, 09:01 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
Looks like a nice score to me too! Way to go.
Old 09-10-2010, 09:31 PM   #7
Critter
Future TOTM Winner
Critter's Avatar
I don't think it's plug-and-play if your 86 has the VSS box (most all 86s did). Also you cannot swap housings if by "housing" you mean the lime green plastic part that everything goes into. The tach housing is different from the regular housing. Lots of good info at the link I posted below.
By the way I just swapped an 80 tach into my 78, it was plug-and-play functionally but the gauges look a little different.
http://www.73-87.com/7387garage/inte...achometers.htm
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 09-10-2010, 10:01 PM   #8
RandyP
RandyP's Avatar
It will be impossible to make work with your 86, no matter what. I offer you double your $$ to solve your dilemma.
You will have to use the housing you got with the tach, probably have to swap your speedo over, maybe mod the housing a hair to get your VSS to plug in, maybe rewire your main connection in to the cluster. All fairly simple stuff and tons of information here and on 73-87. Is easy to repin the connector on your harness.
Old 09-10-2010, 11:40 PM   #9
mcbassin
Still Learning
mcbassin's Avatar
I wasn't aware that the 86 had vss at all, good information, I thought that started in 87.
I am dealing with retro fitting an electronic speedo on an 86 it has been a learning experience for sure.
Old 09-11-2010, 01:03 AM   #10
DBLSPRT68
DBLSPRT68's Avatar
Great score!!!! The 80's version are harder to find, because they made less of them. If you pull your cluster out and it has the vss attached to the speedo; just swap speedo's! I would swap all the guages over anyway; water, oil, speed. Clean it up, hook it up and try it out
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 09-11-2010, 02:24 AM   #11
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
You want a learning experience? check out my cluster mod! Now THAT WAS A CHALLENGE! BTW it's still going strong too.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-12-2010, 11:22 AM   #12
BamaDave
Thanks guys for all the response! Some info on here I really hadn't thought about. It sounds like a little more than plug-n-play, but I think I will be able to make the small changes to make it work out.
Old 09-12-2010, 09:28 PM   #13
55chevy
Car Truck Bike Nut
55chevy's Avatar
I like how the speedo goes from 75 to 35, that's a hell of a governor
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
Old 09-12-2010, 09:59 PM   #14
87 chevy silverado
didnt even notice that
87 chevy silverado is offline   Reply With Quote
Old 09-13-2010, 11:06 AM   #15
Chlsnk
Chlsnk's Avatar
Now thats funny.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 09-13-2010, 11:58 AM   #16
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
I wonder why that is, Ive never seen such a thing could the 8 be dirty
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
1996 Dodge Intreped ES Nice car great on gas
1993 Jeep Cherokee.
Looking for a swb chevy 73-87
lvschevytrucks is offline   Reply With Quote
Old 09-14-2010, 12:57 AM   #17
BamaDave
Just had some dirt over the eight...lol.
Old 09-14-2010, 01:55 AM   #18
drizzydrakerodgers
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Last edited by oldiron; 09-14-2010 at 03:55 AM. Reason: for sale by non-subscriber
drizzydrakerodgers is offline   Reply With Quote
Old 09-14-2010, 02:02 AM   #19
nbpro
Guidlines and Rules http://67-72chevytrucks.com/vboard/a...nt.php?f=4&a=9
nbpro is offline   Reply With Quote
Old 09-14-2010, 03:54 AM   #20
BamaDave
Just realized part of the housing was broke. I have never had any experience with these so I have a question about the part that is broke. I circled the part in question. It appears that what is missing is needed for the shift indicator to work properly, am I right or wrong?
Old 09-14-2010, 04:22 AM   #21
c10sport
c10sport's Avatar
Your left side tab is broken too.
it's worthless and you should send it to me for proper disposal.
Kidding aside, with some careful cutting of the plastic from another cluster and some epoxy or glue may save it. And yes, it's the guide for the shift indicator cable.
c10sport is offline   Reply With Quote
Old 09-14-2010, 04:26 AM   #22
BamaDave
LOL, thanks, I guess I will have to put the ziz-wheel to use here.
Old 09-14-2010, 08:43 AM   #23
mcbassin
Still Learning
mcbassin's Avatar
Couldn't you put all the guts and printed circuit from this cluster in another one that isn't broken?
Old 09-14-2010, 10:16 AM   #24
RandyP
RandyP's Avatar
The gauge cluster holder is unique as well, since the gas gauge is moved and the hole for the tach is different, etc. Might be able to mod one that had a clock in it and make it work, who knows.
Old 09-14-2010, 11:08 AM   #25
mcbassin
Still Learning
mcbassin's Avatar
I thought the housing was the same though?
