front coil help
so i put my stock suspension back on rear was flipped and the front had drop coils i got the back done to day but it sits really high i know that the rear from factory was higher my question is how much to i have to raise the front to level it out im putting my stock coils back but i know that wont cut it
Happy to be here
![]() Join Date: Mar 2000
Re: front coil help
Try a set of C20 coils. They might get you close to level.
Re: front coil help
sorry for got to mention my truck is a 1983 chevy c20 2wd
Happy to be here
Re: front coil help
Hmm, maybe a C30 coil then. I'm not much of an expert on lifting them. Ask me how to lower and I got ya covered.
Re: front coil help
i just want to level things out front and rear
Re: front coil help
anyone know what i should do?
BAD BOW-Silverado XST
Re: front coil help
Install a 2" shackel. The rear is 2" higher from the factory. Shackels are cheap. You could also flip the front hanger. Flipping the front hanger may drop it more than 2".
Re: front coil help
so if i install a front 2" coil spacer id be good too
Re: front coil help
I think a 1ton/diesel front coils would bring the front up if you have a gas 350..
My 1/2ton 2wd sat level with only 1ton front coils. Also... you do not want to put a 2" spacer on the front coils. Due to geometry all you need is about a 3/4"-1" spacer to get 2-2.5" of lift.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Re: front coil help
No drop the rear. It's easier.
Re: front coil help
No.... lift it it looks better.
Re: front coil help
ok guys i only wanna do this once how much of a lift spacer with my stock spring do i need to level it out
Re: front coil help
put heavy duty 1 ton coil springs with a 1 inch spacer. worse case scenario you need to add a block in back...
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
Re: front coil help
i just want to get a coil spacer just dont know witch size
#15 |
Re: front coil help
Bump
#16 |
Re: front coil help
than i would say 2 inch spacer. make sure your balljoints are in good shape.
#17 |
6.0 powered square
Re: front coil help
2" drop shackles
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#18 |
Re: front coil help
Ok so im going to get a 2" coil spacer for the front any heads up while installing my old coils back
#19 |
Re: front coil help
to be honest just buy 1 ton coils while you have the springs out.... still put the spacer in, besides that just be careful with coil springs.
#20 |
Re: front coil help
why get 1 ton coils ?
#21 |
Re: front coil help
because they have a higher spring rate and it will make the truck sit taller.
#22 |
Re: front coil help
well if i only need 2" and im putting 2" coil spacers if i put the 1 ton springs id be to tall
#23 | |
Re: front coil help
"Lifting" a 2wd truck is not as easy as it has been made to sound. There is only so much "droop" travel in the front suspension to begin with and adding coils spacers w/o taking this travel limit into account is a problem. I wouldn't bet on the 1 ton springs doing much more than making the ride unbearable.
You really are better off to lower the rear to match the front with the new "stock" coils up front.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#24 |
Re: front coil help
ok guys so i dropped the lower control arm and i compressed the spring and tryed to shove the spring in but it just seems i cant compress the spring enough im stuck and need some help any one have tips and even if i do compress the spring enough i just cant get the compressor out
#25 |
Re: front coil help
anyone i need help guys
