10-12-2010, 12:01 AM | #1 |
Grandpa in the rustmobile...
Please show me your fuel lines with edelbrock carberators
I want a cleaner way to route my fuel line to my edelbrock carb on a sbc 350. I want metal line all the way WITH a filter, I want it to be clean with little (prefer no) rubber lines, anywhere, this is what I have now, it works but not very sexy lol
I want it to be clean, and prefer all metal lines thanks! now post your pictures and ideas! (maybe this will enocourage folks with 5' rubber lines to go metal too!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-12-2010, 01:31 AM | #2 |
Re: Please show me your fuel lines with edelbrock carberators
No pic but my in line filter is before the fuel pump, i think thats really important to keep dirt and other garbage out of the pump diaphram....
My steel line leaves straight out the side of the carb and bends down toward the manafold and valve cover junction, and then bends foward about 1/2' above the valley of the manafold and valve cover, at the front of the head it bends down at about a 45 degree angle outward and down and is bolted via clamp to the front head bolt, just past the bolt it again bends straight down toward the pump. i was cheap and just used a rubble hose to connect the line to the pump.. EDIT: Um..... Doesn't it get cold in Tennessee???
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 10-12-2010 at 01:33 AM. |
10-12-2010, 09:32 AM | #3 |
You should be running a regulator with that edelbrock.
I mounted a regulator on the passenger fender and routed my hard lines directly to the carb from the regulator. I dont have any pics and i dont run the edelbrock anymore. |
10-12-2010, 09:48 AM | #4 |
Yes lol
This pic was before I re routed my heater lines etc and got new heater core, im going junkyarding with the gf (waho) to get heater controls today lol Ive always heard you run the filter after the man. pump because it puts excess strain on the pump?.. Try to get pics swamp rat, id be interested if ya could,thanks bud
10-12-2010, 01:04 PM | #5 |
I dont have a pic of my set up on my Chevelle but it has a steel line from the fuel pump to an in-line filter and banjo set up on the carb. The banjo set-up and in line filter are Edelbrock parts bought at Summit Racing at the same time I bought the carb. The fuel line was a custom bent piece from the local auto parts store. This set up looks like GM put it there.
10-12-2010, 04:39 PM | #6 |
could ya get pics flashed? im thinking just steel fuel line from parts store come off of carb bend it down to run between valve cover/intake and a screw in filter somewhere, then down to pump running beside waterpump..idk yet pics folks pictures please
10-12-2010, 04:49 PM | #7 |
http://www.summitracing.com/search/?...=edl8134&dds=1
This is what i used with stainless braided hose and an fittings
Fuzzy |
10-12-2010, 04:53 PM | #8 |
Insert Title Here
Not the greatest angle, but heres mine
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << Last edited by 1LoC10; 10-12-2010 at 05:00 PM. |
10-12-2010, 06:17 PM | #9 |
Sofa King Crazy!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
10-12-2010, 07:53 PM | #10 |
Slick67's line is a lot like mine. Ya know i cant remember if the edelbrock has a filter at the carb inlet on the 1406 or not, i thought it did tho but maybe i'm thinking the Quadrajet..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-12-2010, 09:28 PM | #11 |
AMBITION
thats all i could find but ill take a better one tomorrow
10-12-2010, 09:31 PM | #12 |
my 600 1405 has a screen...
I like slick's alot, I wanna see yours swamp rat lol thanks guys keep it comming i'll get some line next time I get the chance any idea how long (sell by 10' increments)
10-12-2010, 10:48 PM | #13 |
That dont look too bad jesse what kinda carb is that? holly? yeah if you get the chance in the next few days get a closer pic, thanks alot man!
10-12-2010, 11:00 PM | #14 |
Ok, I was indisposed today before work with a Dr appt, so i'll try and snap a pic tomorrow, its nothing fancy.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 10-12-2010 at 11:00 PM. |
10-13-2010, 10:21 AM | #15 |
I ran braided fuel line to mine, but Im using a electric pump mounted on the frame, and not the mechanical pump on the block.
However, this guy does the absolute best custom plumbing I have ever seen. Amazing work, and attention to detail. Check out some of his projects and maybe get some ideas. Bent Custom and Performance Here are a few pictures I found on his website that apply more to your request: Last edited by colin_havens; 10-13-2010 at 10:30 AM. |
10-13-2010, 12:36 PM | #16 |
Mine looks just like JesseH13 's above except it is either chrome or stainless ,not colored .Sorry I dont have pics or know how to post them if I did.
10-13-2010, 01:05 PM | #17 |
Never Ending Projects
Here's the best pic I have of my '69 Camaro I built.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-13-2010, 04:09 PM | #18 |
OK here it is, keep in mine my rebuild happened 15 years ago, it looked a lot better then!
10-13-2010, 08:36 PM | #19 |
AMBITION
better pics
10-13-2010, 09:58 PM | #20 |
Ok thanks Ive got a few ideas..
Could I get steel line at parts store to thread into the edelbrock carb? And could I get the L shaped edelbrock (or similar, aftermarket lines locally at an autoparts store?) Thanks guys lots of great ideas!
10-14-2010, 12:50 AM | #21 |
here she is
this was before I installed her, notice I added a gauge in these vids you can see the fuel line as well Last edited by AustinScott; 10-14-2010 at 12:51 AM. Reason: spelling |
10-14-2010, 09:06 AM | #22 |
MR. Gasket makes a set up I think.
10-14-2010, 10:07 AM | #23 |
is it gonna be crappy though? Chrome comming off in matter of days etc? And are these AN or standard, or optional?
10-24-2010, 12:53 AM | #24 |
Was kinda embarrast to post the pic of my engine after 15 years of work and no polish so i dug up the old snaps of it right after i rebuilt it..
08-20-2011, 10:48 AM | #25 |
Debating wheter I hsould buy the made to fit edelbrock line or make my own
i wanan run a regulator, and a fuel filter between pump and carb.... need help 1-Fab my own setup completely from 3/8 brake line 2-Buy pre made line and fab the rest myself HELP! Id like to use little rubber as possible, maybe none at all (stee fittings at the filter etc)
