#1 | |
Still plays with trucks
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Run the seat mount studs from the donor through the flat bar and up into the cab so the stock locking nuts can be used too. Stitch weld the flat bar to the bottom of the floor pan to secure it in place and seam seal the rest of the edge to keep moisture out.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#2 | |
Lucky Teter at the wheel
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
Moving on, we must be able to stop. I had a spare brake assembly that I stole a linkage from to help mate old to new. I cut off the new rod and welded the old threaded rod to it. Then I threaded the cutoff - half on the old threaded rod, half on the new shaft that was a tiny bit smaller diameter. This was my reinforcing sleeve over my welded rods. Then I had to make the center hole much bigger and relocate the holes for the studs on the new booster to fit inside the cab. I took out the studs on the 72 brake mount and later drilled it out to line up with the new studs.
#4 | |
If you weld the bolt heads to the plate before you paint it they will stick up through the floor and act like mounting studs that one person can deal with without someone under the truck too.
Ok looking through your build and it is a sweet truck, but I was wondering what is the dimensions of your rear door? I am thinking that the rear seat will be tight for leg room. I have been looking at several different trucks like this over the years and all were tight for leg room in the back. Just kind of wondering because I am looking to do something similar to my 70, but still a sweet build.
![]() ![]() ![]() 67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
#6 | |
#7 | |
#8 | |
I'll be needing this this weekend. 1972 Chevrolet truck medium blue.
#10 | |
To clarify - I was comparing my new 1972 Crew to my 2002 parts truck Silverado.
![]() Join Date: Jul 2010
Nice..i might of missed, but are you running ABS...Not like you need more wires to deal with...lol
Yes - ABS.
dang you're flying man, if I could do things as fast as you I'd be done,
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
VA72C10
![]() Join Date: Mar 2008
It's the piece shown with the big arrow B pointing to it (note the three bolts)
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 03-16-2011 at 12:23 AM. |
#15 |
You could get a lower profile reservoir for you brakes to free up some clearance.
#16 |
Now you tell me!!! Where were you yesterday?
#17 |
I was lurking around...haha I probably have one that would work for you. Give me a measurment of the height of yours and the distance between where it plugs in the master and I will check.
#18 |
It's done now, but thanks for the offer...... until I can't shut my hood.
#19 |
A few more pics from last night showing my reinforcing sleeve and a shot of my seat fully back in relation to my steering wheel. The eyelet end piece is the old trucks mount that connects to the brake pedal arm. It is threaded for adjustment and here I have it turned out about 1 turn.
I went out to my current driver truck and I have the seat adjusted a few inches forward of where this picture is showing. I'm 5-10 so any 6 foot plus guy should fit in here no problem.
#20 |
67cheby
![]() Join Date: Sep 2008
Looks like plenty of room !!!
#21 | |
"Oh well, it's a driver."
This build is just unreal -- you are really moving on this thing. In one day, there were two pages of updates! So are you planning medium blue/white two tone?
- JB - '93 C1500 SHORT/FLEET SILVERADO, 350/4L60E ![]() Quote:
#22 |
VA72C10
Definitely going to be a looker
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#23 |
VA72C10
Here's the piece you need from teeitup's KS new thread spring 2011 thread...I think he has 1 or two...
#24 | |
Oh yeah, I remember seeing that piece. I have a feeling I'm going to be a little lost on reassembly. Better push my completion date back!!
#25 |
Local Redneck Authority
Very cool that you're keeping the stock filler neck location! Have you shown detail of the filler on the inside of the cab that I missed?
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
