10-18-2010, 12:41 AM | #1 |
12 bolt questions
I was looking at strange engineerings website and i was wondering if any one has used the 33 spline carrier and the s/s series 33 spline axels. my other question is can an aftermarket carrier and aftermarket 30 spline setup withstand 500rwhp
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted 1997 C3500 DRW Ext cab. 454, 4L80E daily driver |
10-18-2010, 08:15 AM | #2 |
Re: 12 bolt questions
Several guys here have upgraded 12 bolts but I would buy a 9 inch.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-18-2010, 09:54 AM | #3 |
I can't answer your question concerning the 33-spline stuff, but I can tell you that I'm running a set of Moser 30-spline axles and spool and this stuff has lived in my 4000+ lb. truck for at least 12 years dealing with the kind of power numbers you're looking at ( and then some with the spray). Like Kevin said, though, if you can afford to make the switch, a 9" is an attractive option.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
10-18-2010, 12:29 PM | #4 |
Boosted Member
I've been running right around that power level for two years on the street, with a couple trips to the track...M/T drag radials the whole time on stock 30 spline axles, and an Auburn diff.....zero problems. FWIW.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
