Old 11-08-2010, 04:22 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
bout to go look at a 82 6.2 diesel
I found a motor on craigslist, I talked to the owner on the phone. The motor has already been pulled. I want to make sure it's complete. what all should I be looking for? Also my truck has a manual transmission with a mechanical clutch linkage, it's got a 350 with rams horns, clearance for the linkage is pretty tight already, and with rear dump manifolds like I believe the 6.2 has I don't think it would fit. Would the rams horns fit on the 6.2? Thanks yall!
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 11-08-2010, 09:27 PM   #2
Re: bout to go look at a 82 6.2 diesel
I think the exhaust can be bent to clear clutch linkage.GM didn't go to hydraulic linkage until '86.The 6.2 has nothing in common with the gas motors.No swapping manifolds.That block will be red if it's an '82.That was the first and best year...higher nickle block.Just be sure the injector lines are all there,the pulleys & brackets,flywheel,and the fuel filter from the firewall.
Old 11-09-2010, 12:45 AM   #3
1968CHEVYC10
Thanks Special-k, he still had all the accessories an pulleys. The guy did say that he thought the block was a 350 olds, thinking the motor was one of the early conversions gm did, he said it was because of something around the crankcase although it did have factory "GM 6.2" stickers on the valve covers which has me thinking it's a 6.2. It came out of an '82 k10.
