Old 04-20-2013, 01:18 PM   #1
Scottshotrods
Re: Extreme Powder Coating '65 C-10 Shop Truck
Originally Posted by kart34 View Post
Justin, Do you have the Calipers in stock?
Yes we do have Black or Red in stock.Will need to know on your front rotors if you are running a 1 1/4 thick rotor or a 1 inch thick rotor.If you would like to place a order call us at the shop at (805)485-0382
Justin
Scottshotrods is offline   Reply With Quote
Old 04-20-2013, 03:35 PM   #2
jimmydean
jimmydean's Avatar
It's a shame you can't see those calipers, but I wouldn't change those wheels, either.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-07-2013, 04:52 PM   #3
kart34
Happy birthday DELMO!!!
edited by staff
kart34 is offline   Reply With Quote
Old 05-22-2013, 03:03 PM   #4
kart34
Wilwood D52 on NO PAINT
edited by staff
Old 05-24-2013, 10:58 AM   #5
creep
Registered Loser
creep's Avatar
Your frame and suspension are entirely too clean. You are obviously not driving it enough.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-24-2013, 12:26 PM   #6
Stickman
Stickman's Avatar
Just went through the thread and the truck is awesome but the Lark is just over the top. I have a soft spot for the Buicks
Stickman is offline   Reply With Quote
Old 05-24-2013, 04:40 PM   #7
coulter
coulter's Avatar
nice calipers!!!! i got the same ones!! i dont have the baller rotors though ;/
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 05-25-2013, 03:13 PM   #8
gofastnut
gofastnut's Avatar
Just read through the entire post and I have this to say:
Kart, I am SOOO glad you're dad is cancer free!
No Paint looks awesome! My head is still spinning from all the ideas of seeing super cool stuff. You do seriously nice work, great attention to detail!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 05-26-2013, 09:15 AM   #9
kart34
Thanks Guys.. Creep only have 150 miles on it... still de- bugging it... updates Tuesday... been working on it all week... next show BilletProof Minnesota... June 8th
edited by staff
Old 05-29-2013, 08:15 PM   #10
groundbound64
Subscribed
64 C10 Stepside 350/4psd Driver/Project on air.
Dom bags, Dual Viair and AccuAir
08 Ford F150 Limited- F-word ! Daily Driver
.......................____
..........._______l/ \____
...........|_/(0)\_ll____/(0)_l.
groundbound64 is offline   Reply With Quote
Old 05-30-2013, 11:59 PM   #11
Dinos63
chevy only
Dinos63's Avatar
nice stoppers!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-01-2013, 03:11 PM   #12
kart34
Well Guys... After 4 different carbs... and a smaller bank account... We have determined that we have an issue with the fuel system... "No paint" will only run off of the front Moon Style tanks.. The Mustang tank located behind the rear axle will not flow fuel... zero fuel pressure... we are using 2 in line filters -6an and -8 an for lines...
How are you guys running your fuel lines? Do I need an electric pump? Also had a Billet Holley HP performer pump on it.. same issues... We have not installed fuel flow check valves in the system... but we have the parts to install.... any ideas guys... currently we have the "New Street Demon" carb built by Holley.. similar to the Q-Jet / Edelbrock carb...
edited by staff
Old 06-02-2013, 09:38 AM   #13
kart34
Question Re: Extreme Powder Coating '65 C-10 Shop Truck
Holley ultra mech fuel pump... any ideas guys about my fuel issue... How are guys running there fuel lines with the Porterbuilt notch?
edited by staff
Old 06-02-2013, 06:49 PM   #14
gimmy 64
do you have a roll over valve and is it vented? no vent the tank will build up pressure and won't draw fuel
gimmy 64 is offline   Reply With Quote
Old 06-02-2013, 07:31 PM   #15
kart34
No roll over vent installed... Is that the issue ? I will call Tanks Monday AM.. Thanks...
edited by staff
Old 06-03-2013, 11:48 AM   #16
kart34
This shows how the fuel lines are routed....any more ideas fellas??
edited by staff
Old 06-03-2013, 03:48 PM   #17
kart34
Well, We had our head ace mechanic here for 3 hours today , We found a few issues.
1) 1 bad Russell fuel shut off valve which would back feed fuel from the small 3.5 gallon tanks mounted in the box.
2) Installed Russell back flow check valves in main fuel line from back tank and also in the front tanks.
3) Re-installed Holley HP Billet fuel pump 7.5 psi pressure all good BUT... after 45 min. run time .. NO FUEL PRESSURE Again...... rear lines are Aeroquip -8 an lines / Moon Style tanks are all -6 AN Aeroquip lines also...
4) Also FYI... the tanks are vented and also replaced the TANKS Mustang style tank in the rear also... the 1st tank the pick up tube broke off in assembly ... man am I frustrated .... are the Aeroquip lines collapsing ??
edited by staff
Old 06-03-2013, 07:39 PM   #18
kart34
Thumbs down Re: Extreme Powder Coating '65 C-10 Shop Truck
We are about out of ideas on this fuel issue?
edited by staff
Old 06-03-2013, 08:47 PM   #19
kart34
edited by staff
Old 06-04-2013, 07:53 AM   #20
cAlvis165
cAlvis165's Avatar
Sorry I can't think of any ideas (3 tanks is a little above my pay grade). For troubleshooting, you could grab a bunch of cheap rubber fuel line and just run a temporary line from the tank to the fuel pump and see if that fixes it.
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill
DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans
Project Dooley One-Ton 4x4 on 38.5s Corn-binder build
cAlvis165 is offline   Reply With Quote
Old 06-04-2013, 10:55 AM   #21
65 wonton
Great thread and great build.
I'm no fuel expert, but I agree with cAlvis165.
I would also separate the three tanks for testing. 1 at a time with temp lines, then hard lines. Then add one at a time 'till all three are working or the problem is isolated to one system.
Please excuse me if you've already done this.
Dave.
65 wonton is offline   Reply With Quote
Old 06-04-2013, 03:39 PM   #22
kart34
Thanks guys.. It maybe an issue with the 18 foot on fuel line we have routed in this truck.. calling Holley tech. line guy today
edited by staff
Old 06-07-2013, 07:05 PM   #23
cAlvis165
cAlvis165's Avatar
You get it figured out, man?
Old 06-08-2013, 06:53 AM   #24
kart34
It is boiling the fuel after the pump... our new crappy gas with boil at 90 degrees .. fuel temp was 166 ... moving a coolant line and re-routing a fuel line
edited by staff
Old 06-08-2013, 07:27 AM   #25
coulter
coulter's Avatar
dang i never would have guessed that.. what is heating it up so bad? exhaust, compressors?
'65, c-10, carter hickman designs, extreme powder coating
