Old 11-11-2010, 09:06 PM   #1
kgmunro
57 cab removal help
I am almost ready to pull the cab off my 57 gmc but have a few questions. How does the column disconnect from the steering box? I also want to pull the motor and trans...are there just 2 bolts on the mounts on the sides of the trans or am I missing any...thanks for any help you can give me....
kgmunro is offline   Reply With Quote
Old 11-11-2010, 10:59 PM   #2
drivea55
drivea55's Avatar
Re: 57 cab removal help
+2 on how to disconnect the column...
please, anybody... do tell and thanks!
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 11-11-2010, 11:04 PM   #3
magicoolbus
magicoolbus's Avatar
If the steering column on a GMC is anything like a chevy of same era, the column and the gearbox are integral and must come out together.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 11-11-2010, 11:49 PM   #4
kgmunro
So I can't use that column with a camaro subframe then?? How about a column from a mid 70's chevy van??
Old 11-12-2010, 01:15 AM   #5
OrrieG
OrrieG's Avatar
Steering column comes out by removing the steering wheel, bracket under the dash, cover at the floor, column shift handle (if 3 on tree), pull the pitman arm, unbolt the steering box from the frame and pull it out of the frame, pull the box and column out thru the firewall from the firewall side.
You can use the stock column by cutting it loose from the box and adding a bearing at the bottom (available online from vendors). The bottom of the shaft needs modified too I think. There have been a couple of threads on here with pictures, a search should find them.
Old 11-12-2010, 06:55 AM   #6
kgmunro
Right on!! Thanks OrrieG
Old 11-12-2010, 12:35 PM   #7
Spackle100
Hey Orrie, I remember seeing that bearing for sale somewhere but can't remember where. Do you know who sells it?
Thanks!
Spackle100 is offline   Reply With Quote
Old 11-12-2010, 01:48 PM   #8
OrrieG
OrrieG's Avatar
Thanks!
No, I have not used it but it should show up with a google search or someone here will chime in.
Old 11-13-2010, 01:12 AM   #9
Red Foreman
Red Foreman's Avatar
Thanks!
Try this link, new at this hopefully works?
http://www.classicparts.com/1947-59-Steering-Coloum-Conversion-Lower-Bearing/productinfo/76-987/[/URL]
Red Foreman is offline   Reply With Quote
Old 11-13-2010, 08:54 AM   #10
Russell Ashley
Russell Ashley's Avatar
I got mine from Tucker's. They called it a Column Saver kit when I bought it.
Russell Ashley is offline   Reply With Quote
