Old 11-20-2010, 02:37 PM   #1
kcfirstbuild
Factory markings
Well not sure if anyone can help me out or not. My 68 had factory markings on the fire wall until I scrubbed them off with the scotch bright pad. I do have one picture of the engine bay but i cant make out the numbers or letters. If i zoom in it gets blurry.
From what I hear its better to have the markings but back on the truck after its been painted. So in case i cant figure out what my original markings were. Can i just make up some markings ?
kcfirstbuild is offline   Reply With Quote
Old 11-20-2010, 03:10 PM   #2
bruceman1968
bruceman1968's Avatar
Re: Factory markings
KC, I think the model number is on the firewall in grease pencil, passenger side. There are other numbers/letters also but I don't what they are. Here's a good Thread that has some good info and should get ya pointed in the right direction. Hope this helps. http://67-72chevytrucks.com/vboard/s...d.php?t=371947
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 11-20-2010, 03:23 PM   #3
They were assembly line build markings...notations.It's neat to find them still there,because it shows originality of the truck.To put them back on is neat,but does nothing to indicate originality.To put just anything on there would be just silly,IMO.I had them on the cab I'm using on project "Poor Boy".I'm not going with the color on the cab so I stripped them and primed over the cowl.
Old 11-20-2010, 04:27 PM   #4
kcfirstbuild
Any one with a 68 have a picture of their Factory markings on the fire wall ?
Old 11-20-2010, 05:43 PM   #5
swamp rat
swamp rat's Avatar
No but heres the marking on the front of my pickup bed..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-20-2010, 06:07 PM   #6
kcfirstbuild
Still have those on the bed and wont make the mistake of scrubbing them off like the ones on the fire wall.
Old 11-20-2010, 06:22 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
There's a whole plethora of people who get so into the restoration of their vehicle that there is also an aftermarket of tags/stickers/etc. for those people to attach to their coil springs, for instance. Markings on anything that would be pertinent or appropriate for the given make/model are part of that scene. Add to that, creating overspray on places that would have had it, as well as other items of detailing, and you have the restoration crowd wondering....is it original or is it a restoration?
Member Nr. 2770
Old 11-20-2010, 07:46 PM   #8
hugger6933
I have some markins on my 68 gmc . They are over the booster on the drivers side . They say 3001 among other things. I will try to get pics on monday when I go to the shop. Jim
hugger6933 is offline   Reply With Quote
Old 11-20-2010, 07:58 PM   #9
kcfirstbuild
ok great thanks
Old 11-20-2010, 08:08 PM   #10
nyncompute
nyncompute's Avatar
Mine has " 3- TONE" with a circle around the 3. Just has to do with the paint scheme . Nothing about serial numbers . I think the markings differed from place to place, and time.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 11-20-2010, 10:01 PM   #11
71 super
71 super's Avatar
My 68 has some of the original markings on the firewall 821 I think. One of the typical marks is the model # on cowl area passenger side. Typically on driver's side there is a unit number of some type typically a three digit #, on my 71 it is the paint code a "460" which is black and white deluxe two tone. It also has A50 on the core support for bucket seats, it has 118 under the driver's seat which I have no clue and it also has engine L47 and the trans code. On the 4x4 it had "john" written in grease pencil on the gas tank, a stencil code on the frame and on the rear drive shaft, model code on cowl, 880 on firewall as well as the option code for 4 speed trans and the option code for the 350. It had YE9 on the head gate of the bed and the model number on the rear cross member just in front of the rear bumper. I tell you this because it represents the info as the truck passed down the line, a check list of materials complete etc. if I had to guess. In the case of "john" it went back as did everything else I found because it is cool. If john thought enough of himself the sign the tank, I figure he should stay. For a full custom do away with them, for anything else I feel they are a part of the truck and should stay if possible, they give them personality.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-20-2010, 10:26 PM   #12
swamp rat
swamp rat's Avatar
Great post and info! Now i want to go look my truck over closer!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-21-2010, 02:07 PM   #13
kcfirstbuild
ok so model # of the truck on the passenger side, check Ill put that back on when I get it painted. Then kind of number is on the drivers side and behind the motor?
Old 11-21-2010, 03:26 PM   #14
19553100
19553100's Avatar
Pics of the factory line markings on my '67
One number "754" centered on the firewall and the front
center under the hood.
Hope this helps.
Wayne
Wayne
Sunny Rust-free Southern California
19553100 is offline   Reply With Quote
Old 11-21-2010, 04:53 PM   #15
kcfirstbuild
Great thanks wayne for the picture, do you think that matches up with your Paint code ?
Old 11-22-2010, 11:41 PM   #16
hugger6933
Took some pics but it did not turn out legible. Sorry Jim
Old 11-23-2010, 01:27 AM   #17
tim21391
tim21391's Avatar
i had them going across my whole firewall.. whats those mean. sorry to ask on your thread hope its ok
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 11-23-2010, 09:40 AM   #18
kcfirstbuild
Not a problem. I'm looking for pictures now so i can put some back on after I scrubbed them off. I still cant figure out what the Drivers side left numbers meant.
Old 11-23-2010, 10:16 AM   #19
arkansas
There was a number on the last crossmember on my frame too. It was upside down. It could be read if standing on your head behind the truck. Seems like it matched the firewall numbers over the heater box. I'll have to dig out some pics. There was also a three digit number on the cowl vent box on the driver side. There was nothing in the hump area of the firewall directly behind the engine on mine. Don't remember anything on the bed front panel either. I took pics of pretty well all the writing I found on mine.
arkansas is offline   Reply With Quote
Old 11-23-2010, 10:29 AM   #20
yote1234
yote1234's Avatar
here ya go.. before and after...
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 11-23-2010, 10:33 AM   #21
Keith Seymore
Keith Seymore's Avatar
All - as you have probably already surmised, the numbers pertain to model codes, option content and the build sequence number.
They can also be signed love notes, "running the numbers" (ie, gambling) and lunch tab calculations (...I'm serious...).
They do vary from plant to plant, shift to shift and even between individual operators.
By the way, my truck was build sequence number "87".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-23-2010, 10:36 AM   #22
Keith Seymore
That's because when the frame is set it is built upside down.
It is flipped right side up after the front and rear suspension are added and secured.
K
1979-1986
1986 - 2019
Old 11-23-2010, 11:50 AM   #23
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Okay, from what Kieth says....these markings could be a way to pass love notes between folks like they did in school. Whodathunkit? Then, my experience in an industrial environment says that people write on "things" for several reasons. I guess that having a continually-changing "tablet" would be a good reason to voice your opinions, etc.
Member Nr. 2770
Old 11-23-2010, 12:41 PM   #24
Keith Seymore
The cute girls always worked in the Trim shop....
In the Pontiac community, there is a lady named "Linda" that signed a bunch of glovebox doors than she built (we've discovered probably half dozen or so).
1979-1986
1986 - 2019
Old 11-23-2010, 01:45 PM   #25
swamp rat
swamp rat's Avatar
Did the love notes allways start with the number '69' ??
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
