Old 11-25-2010, 10:39 AM   #1
3r!c84
Badass
3r!c84's Avatar
Exclamation How to hook up HEI
Hey I put in a msd box and the fried. So how do I hook it back up the stock way? Little help here
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-25-2010, 11:12 AM   #2
nbpro
Re: How to hook up HEI
http://www.msdignition.com/forum/index.php
nbpro is offline   Reply With Quote
Old 11-25-2010, 11:14 AM   #3
3r!c84
Badass
3r!c84's Avatar
yea i want to get rid of the msd box. we already know its bad.
-00 Saturn 5spd
1/4:13:90
Old 11-25-2010, 11:29 AM   #4
nbpro
yeah i read where you said it was fried. i just thought that would be a good place to start since they made the thing. could be some additional timing settings, and so forth that need to be considered. here's something else i found off that same website.
http://www.msdignition.com/uploadedF...structions.pdf
Old 11-25-2010, 11:46 AM   #5
3r!c84
Badass
3r!c84's Avatar
Yea we where doing the tests yesterday. Came up with nothing. I just need to know how to wire up the stock hei. What do I plug into the B- and c+ plugs and all of that
-00 Saturn 5spd
1/4:13:90
Old 11-25-2010, 12:02 PM   #6
nbpro
just reverse process
Old 11-25-2010, 12:44 PM   #7
PRattenbury
All it needs is the BATT wire hooked up, no?
PRattenbury is offline   Reply With Quote
Old 11-25-2010, 01:07 PM   #8
S10Fan
Old Heap Driver
One is for ignition and the other goes to the tach if equipped.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 11-25-2010, 01:11 PM   #9
3r!c84
Badass
3r!c84's Avatar
thats it? just a 12volt hook up ? where it says batt? what about the c/ground/b hook ups in the back?
and the 2 wire pig tail coming from the bottom of the dist
-00 Saturn 5spd
1/4:13:90
Old 11-25-2010, 01:19 PM   #10
S10Fan
Old Heap Driver
There should be 3 wires (some have 4) coming from the base of the HEI that plugs into the cap. The most outward connectors on the cap are for ignition and the tach.
Bryan
Old 11-25-2010, 01:25 PM   #11
3r!c84
Badass
3r!c84's Avatar
the top
bottom has 2 coming out
-00 Saturn 5spd
1/4:13:90
Old 11-25-2010, 01:29 PM   #12
cableguy0
That distributor was converted. I bet theres no module at all. Those wires coming out are for the magnetic pickup to trigger the msd box. I doubt theres a module inside that distributor. Thats not the normal way to hook up an msd box. Someone went way too far for no reason and it probably has something to do with you cooking the box.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-25-2010, 01:34 PM   #13
63chevyll
gets board easy.......
63chevyll's Avatar
2 common problems i see with HEI's
the groud under the coil and make sure the engine has a good ground
63chevyll is offline   Reply With Quote
Old 11-25-2010, 01:41 PM   #14
S10Fan
Old Heap Driver
I tend to agree.
3r!c84..............Do you have access to an honest to goodness STOCK HEI?
Bryan
Old 11-25-2010, 01:44 PM   #15
3r!c84
Badass
3r!c84's Avatar
I tend to agree.
no i dont. i bet i can hit the junkyard and pull one. or pull parts from one. what do i need to convert this back? or whatever
-00 Saturn 5spd
1/4:13:90
Old 11-25-2010, 01:52 PM   #16
S10Fan
Old Heap Driver
I don't remember if you can just drop in a module with those. I can't remember what the inside looks like.
Bryan
Old 11-25-2010, 02:14 PM   #17
burger
A replacement module from a parts store wouldn't contain the factory harness (the one that plugs between the module and the cap).
Check out this harness/module package from Speedway: clicky.
I would replace the coil & cap as well.
burger is offline   Reply With Quote
Old 11-25-2010, 02:22 PM   #18
S10Fan
Old Heap Driver
Originally Posted by burger View Post
A replacement module from a parts store wouldn't contain the factory harness (the one that plugs between the module and the cap)..
Thanks for the link, that's what I couldn't remember, the "pickup" and plug configuration.
.....and BTW, stock modules are cheap, buy an extra one and throw it in the glove box. While on the side of the road on wet rainy night you'll be glad you have a spare. Plus, having a spare keeps the one in the HEI from retiring early. LOL.
Bryan
Old 11-25-2010, 02:27 PM   #19
3r!c84
Badass
3r!c84's Avatar
sweet thankyou i will get one of them this weekend. and the coil is new i just got it 2 days ago cus i thought it a bad coil. when it was only the box i fucd up
-00 Saturn 5spd
1/4:13:90
Old 11-26-2010, 05:41 PM   #20
nbpro
I agree. also
this link shows how to set it up and may be reverse the process
Old 11-26-2010, 07:45 PM   #21
ont_guy_38
ont_guy_38's Avatar
Do you not take the module out with an msd box? I don't know anything about them but am picking one up this weekend
ont_guy_38 is offline   Reply With Quote
Old 11-26-2010, 08:35 PM   #22
cableguy0
you can just leave it there unhooked. use the existing mag pickup to trigger the box its simple.msd also sells an adapter harness
Old 11-26-2010, 09:28 PM   #23
3r!c84
Badass
3r!c84's Avatar
Got a link to this adaptor ?
-00 Saturn 5spd
1/4:13:90
Old 11-26-2010, 09:46 PM   #24
cableguy0
You have it already. Thats the two wires hanging out of the distributor. It plugs into the plug for the magnetic pickup under the cap that used to plug into the hei module then plugs into the two wire trigger plug on the msd box. If you cooked the msd box theres a good chance you have another issue in the truck. They are very stable when the rest of the wiring is correct. The box should always be unplugged when charging the battery or every hooking up battery cable. They need a good ground as well.
Old 11-26-2010, 10:21 PM   #25
ont_guy_38
ont_guy_38's Avatar
whats a better box msd 6al or crane 6000-6440 ?
