Retired Air Force Veteran
![]() Join Date: Aug 2007
Power Steering Pump Needs A Bath - Any Suggestions?
I took the Power Steering pump off to replace the rubber lines and this thing is in need of a bath real bad. I'm sure a degreaser of some kind is going to be the answer. Other than plugging the holes, should there be any other things I need to watch out for? What have you done? Any Suggestions?
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Old member
Don't get any water in it. if you do make sure you dry it very good before using it. Mositure is the worst thing on a power steering pump.
Make sure it's pumping. I would take it and have it cleaned and tested at a hydrolic shop. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Power Steering Pump Needs A Bath - Any Suggestions?
Thanks Andy
i'd use kerosene and a stiffbush to clean it up
I think it's CPP has new PS pumps on sale for a X-Mas special $39 plus shipping. At that price you could do that, borrow a pulley puller from one of the chain stores and swap out your clean brackets.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Jun 2010
I think those are brackets for $39.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
Thanks for the info guys
![]() Join Date: Apr 2010
That is for just the reservoir at CPP. You still have to use your pump.
Watch out for your cornhole !
![]() Join Date: Jun 2003
You can get a complete reseal kit for your pump from the parts store for about 10 dollars. It's a very easy project to reseal one. This is one I did for Scoti and powdercoated all the parts during the job...
![]() ![]() Remove the old front seal with a drywall screw... ![]() Install new seal... ![]() All reassembled with new seals on reservoir and fittings... ![]()
#10 | |
#11 | |
I've been so busy building hay trailers that I haven't been doing any powdercoating lately. I'm gonna be covered up until the winter is over and folks quit buying hay before I can do anymore.
