12-31-2010, 02:36 PM | #1 |
Tachs in automatics?
I see a lot of people on here with tachometers in there trucks, and a lot of them are automatics. I know that in a manual you can you use it to help with shifts but what exactly do you use it for in an automatic? Or do people just like to have an idea what RPM there motors at?
12-31-2010, 02:39 PM | #2 |
Re: Tachs in automatics?
Use it for the same thing in an automatic that you would a manual
1985 Chevy C10 350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker |
12-31-2010, 02:43 PM | #3 |
The One And Only !!!
It's just kool seeing that little needle move when you push the gas !
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
12-31-2010, 02:50 PM | #4 |
Lol thats good enough for me i just didn't know if i was missing something because i see a lot of people just put one stick on the dash where IMO it just looks out of place i would just rather not do that unless there was use for it
12-31-2010, 03:18 PM | #5 |
helps with tuning...other than that...I like looking at it jump when I really get on it.
12-31-2010, 03:43 PM | #6 |
Watchin the rust grow
I like to watch it when I kick-down or when pulling trailers and it helps you keep a light foot when your trying to save fuel.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
12-31-2010, 04:12 PM | #7 |
GoatLube Experss
I had one in an old truck , on trips I'd set the cruise at 2000 in hopes of better MPG.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
12-31-2010, 04:22 PM | #8 |
MOTORHEAD!
My speedo is way off... I know 2750rpm is 60mph... I rarely use the speedometer!!!
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
12-31-2010, 04:28 PM | #9 |
Slots go on anything!
That's why I added one, too.
1974 Jimmy- 5.3/4L80e/NP241 |
12-31-2010, 04:49 PM | #10 |
A day should have 30 hours.
I just like seeing the needle hit 9000 rpm. On a V8 it sounds amazing.
12-31-2010, 05:35 PM | #11 |
With a stock engine it's not as huge of a deal but as soon as you start adding cams , headers, carbs or any other higher performance product that usually also gets your rpm higher so you want to be able to keep an eye on it as you can soon over rev your engine
12-31-2010, 05:53 PM | #12 |
I got mine as soon as I took out the stock 305 and installed a rebuilt 350. Needed it to make sure I was breaking in the cam properly and wouldn't go back.
Evan B. Last edited by evan; 12-31-2010 at 05:54 PM. |
01-01-2011, 01:00 AM | #13 | |
And on the later model vehicles i like them because i can keep an eye on it and know when the converter locks and unlocks. For performance engines, shift points, tuning, and the ever important "cool factor". Posted via Mobile Device
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
01-01-2011, 10:08 AM | #14 |
I agree with the above. I can keep an eye on when the converter is locking and unlocking, and how much RPM drop there is when it does. It would be handy for cam break-in, often as that happens. And also for tuning/setting the idle. And yeah, it's just generally cool to have.
01-01-2011, 12:18 PM | #15 |
Happy to be here
I have one simply because they were an option in 77 and it looks good in my dash
01-01-2011, 12:53 PM | #16 |
Other than the obvious benefits during tuning....
Ever had a clutch wear out or an automatic transmission start slipping and need repaired / replaced? The tachometer will help you to determine this at the onset of the problem. Drive in the snow or on slick roads? If you accelerate and are mindful of the tachometer you can tell if your tire(s) spinning. Ever do a burnout? The tachometer will help you to keep from over revving the engine. Ever manually shift an automatic? The tachometer lets you hit your shift points. Last edited by lakeroadster; 01-01-2011 at 12:53 PM. |
01-03-2011, 07:16 PM | #17 |
.. !WAR FEDOR! ..
that would make a cool garage poster or photo N2TRUX!
"san diego chargers #1" |
01-03-2011, 07:49 PM | #18 |
Jonny
but with the needles pointing to the other side
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
01-03-2011, 08:31 PM | #19 |
Happy to be here
Hmmm? Not a bad idea. My wife had a nice pic blown up for me for a Christmas present. That would compliment it rather nicely.
01-03-2011, 08:54 PM | #20 |
I like the factory tach because having that huge gas gauge is ugly, the tach looks great there.
01-03-2011, 09:32 PM | #21 |
OutOfMyMind & I'llNeverKnowWhy
i like the looks
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
01-03-2011, 10:46 PM | #22 | |
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
01-03-2011, 11:13 PM | #23 |
Were they still available in 88-91 Blazers and Burb'ns?
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
01-04-2011, 12:35 AM | #24 |
My family hits the sand dunes pretty often and it helps a lot in dragging big toys out... I always watch it to make sure I'm not going to blow the motor since it's easy to do in sand and mud. It spends a lot of off-road time in 4 low, so it spins up really quick.
01-04-2011, 10:02 AM | #25 |
Another Day, Another Dollar
i have one so that i know what the hell is going on when the tunes are so loud my ears bleed
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
