Old 01-02-2011, 03:39 AM   #1
RdoubleU
RdoubleU's Avatar
Overbuilding - Looking for advice on how not to : '68 SWB Step LS250
BUILD THREAD STARTS POST # 12
This is a great site and a big help for me with detail information and how to's for various projects on these 67-72 trucks.
I've acquired a '68 C10 SWB stepside with the 250 3spd setup. The truck has been sitting in the original owners sons garage for years and I finally was able to get my hands on it.
The trucks currently runs and drives but still needs alot of work to have it reliable enough to drive to town with no worries.
In the past few months I've:
- Replace the fuel system (new tank, lines, fuel pump, carb)
- Replaced the Radiator
- New Valve cover gasket/breather/pcv
Future plans:
1) HEI (read numerous times best upgrade you can do for these motors)
2) Power steering and front end rebuild (loose manual steering as is)
3) Power Brakes
4) ECE 4/6 drop with 6 lug disk
Goal: get this truck mechanically solid and reliable without getting into the overbuilding nightmare that keeps projects in the garage for years. Right now my plan is to follow the 1-4 sequence as above unless others have suggestions that doing certain upgrades together at once is best or any other upgrades are key.
Last edited by RdoubleU; 04-16-2013 at 08:55 PM. Reason: Turning Thread into a build thread
RdoubleU is offline   Reply With Quote
Old 01-02-2011, 04:36 AM   #2
67chevy1series
67chevy1series's Avatar
Re: Overbuilding - Looking for advice on how not to
you should take care of that but your not over building it you ve got great plans ,you know us guys we need pics got any
67chevy1series is offline   Reply With Quote
Old 01-02-2011, 06:54 AM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Sounds like you have a goal and a plan.I would fix the oil leak and stick with the plan you outlined.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-02-2011, 09:18 AM   #4
Luvlegs
Luvlegs's Avatar
oh yeah... yeah,... yeah yeah,, the plan... geesch - almost forgot about that! Man... 5 years in, ha! forgot what I was doing there for a year or two.....
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-02-2011, 09:39 AM   #5
If you're not losing a great amount of oil,like making the whole underside wet and leaving puddles,the leak is just an annoyance. The main threat is losing track and letting it run low. Gaskets dry up when a vehicle sits a period of time,then start leaking once it starts being driven. It's a common practice to go ahead and re-gasket/seal the whole motor and would not be considered overbuilding. It's no big project to go ahead and replace the timing cover,oil pan,side cover gaskets,and crank seals. You can let them go,fix them as they leak,or do it all and be done.
Old 01-02-2011, 11:52 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
The first thing I would do is try re-tightening the bolts on the pan. Just don't get carried away, they are easy to twist off if you get heavy handed.
LockDoc
Leon
Old 01-02-2011, 12:11 PM   #7
firedog
firedog's Avatar
Regarding overbuilding... just try to keep in mind, if you think at any time you may sell your truck you will probably not get much in return for your labor... That is unless you are locdock then everything you touch turns to gold... Or some sweet wine!
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 01-02-2011, 01:02 PM   #8
cdowns
cdowns's Avatar
make it a habit for work// must b able to drivein in the morning and driveout compleated at night// live by that rule you'll never overbuild
Old 01-02-2011, 01:34 PM   #9
swamp rat
swamp rat's Avatar
Thats my goal, but sometimes its more like 1-2 weeks.. i'm sure i'll break it this year tho.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-03-2011, 01:28 AM   #10
RdoubleU
RdoubleU's Avatar
There is a decent amount of oil spray on the lower oil pan/flywheel/trans area and about a coffee mug sized puddle on the ground so the leak issues will definitely need to be addressed once the truck starts to see the road more often.
Believe I will shoot for the HEI upgrade next and follow that up with new seals once I'm positive the engine is good to go and dependable enough to drive anywhere anytime.
Heres a few shots:
- the day the truck left the garage
- Proof of the wonders of simple green and time: Before/Halfway/Done
- And my fauxpantina valve cover so it wouldn't stand out
Old 01-03-2011, 01:48 AM   #11
jablack
Classic Chevy Recycler
jablack's Avatar
I bought a truck with a 250 in it. It was covered in oil and gunk. I changed the valve cover gasket and cleaned it a little. It hasn't leaked since.
2004 Chevrolet Trailblazer EXT
1970 Chevrolet C50
1979 Chevrolet C30
Need another 67 or 68 soon...
jablack is offline   Reply With Quote
Old 04-14-2013, 02:27 AM   #12
RdoubleU
RdoubleU's Avatar
Re: Overbuilding - Looking for advice on how not to : '68 SWB Step LS250
Future plans:
3) Power Brakes
Goal: Im looking for advice on how to get this truck mechanically solid and reliable without getting into the overbuilding nightmare that keeps projects in the garage for years. Right now my plan is to follow the 1-4 sequence as above unless others have suggestions that doing certain upgrades together at once is best or any other upgrades are key.
This was 2 years ago and I've since change my plans a little but never strayed from my goal and made sure I didn't get into new areas of the build without closing the current project first. This has allowed me to get to the current stage without ever letting the project get out of control
Since I did not create a build thread as I went, I am going to try and do alittle catch up and also provide some links to information i collected along the way that might help others out working on the same issues
This forum is a great resource, just have to do some searching for the info
But to start heres the As Was to As Is comparison and then I'll start posting all the stuff that happened inbetween
'68 SWB Stepside - Inline Long Six 250 C.I. (LS250): http://67-72chevytrucks.com/vboard/s...ferrerid=83901
Old 04-14-2013, 02:38 AM   #13
RdoubleU
RdoubleU's Avatar
Again here's the straight from the garage day and Original Stance
Old 04-14-2013, 02:45 AM   #14
RdoubleU
RdoubleU's Avatar
Future plans Update :
I went with the Skip White HEI: http://67-72chevytrucks.com/vboard/s...d.php?t=405650
And Followed the FAQ Index Thread for the Install: http://67-72chevytrucks.com/vboard/s...d.php?t=148346
Plug Gap : http://67-72chevytrucks.com/vboard/s...d.php?t=349565
Additional Wiring Detail: http://67-72chevytrucks.com/vboard/s...d.php?t=388275
Working great and no issues
Old 04-14-2013, 03:06 AM   #15
RdoubleU
RdoubleU's Avatar
Future plans Update:
I followed this How To in the FAQ Index Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=216886
I did have the flat front frame on my '68 which required me to indent the frame to clear the steering box bulge. It really a simple task and I used a Hand Torch with a Hammer just enough to get the clearance I needed.:
http://www.classicheartbeat.com/panel_5.htm
http://67-72chevytrucks.com/vboard/s...d.php?t=456086
http://67-72chevytrucks.com/vboard/s...d.php?t=419306
Used all the part #'s and parts sourced from the FAQ thread and purchased a set of power steering brackets for a 250 I6 from a member here on the board
I did run into some issues with the pulley alignment, but was able to figure out a solution by making some custom washers and "keying" them to match the power steering pumps shaft and align the pulley as needed (see below)
http://67-72chevytrucks.com/vboard/s...d.php?t=354622
http://67-72chevytrucks.com/vboard/s...d.php?t=470040
Alignment Solution:
Old 04-14-2013, 03:17 AM   #16
RdoubleU
RdoubleU's Avatar
So these were supposed to be the next Future Plans Update:
3) Power Brakes
But when I took the truck to get aligned after replacing all of my steering components they would not touch it due to my control arm bushings and ball joints were completely shot.
So I started researching costs on what it would take to rebuild them......
And then I found Rob's thread and it was all over from there: http://67-72chevytrucks.com/vboard/s...d.php?t=419251
Originally Posted by robnolimit View Post
If you guys (and gals) want, i'll try to keep responding to your handling questions.
Making these trucks handle is easy at first, but the more you want to get out of it, the more work it becomes. The are several things to consider. Tires, Wheels, Weight, Suspension, Brakes, Gears, ....... Set your goals before you start, as some of the parts change the deeper you go. Also, decide how streetable you want it to stay. The more you want to pull one 'G', the stiffer it's going to get. Drop spindles are better, in general, than short springs, this helps to keep the suspension in the sweet spot. In the rear, (trailing arm) blocks are better than short springs for the first 2 inches. Then go to springs. For leaf trucks, use de-arch springs or a flip kit, no blocks. Go BIG on the sway bars. And, spend $$$ on shocks. Doetsch, KYB, or Bilstien, this is where it happens.
Give me some questions, and I'll be more specific on the details.
Old 04-14-2013, 08:36 AM   #17
Low Elco
Oh no, you found the make it handle thread! Lotta good info there. Did you do the 3/4" LC mod and how do you like it post-op? Neat little truck!
Low Elco is offline   Reply With Quote
Old 04-14-2013, 11:53 AM   #18
RdoubleU
RdoubleU's Avatar
Lots of great info and I suggest to anyone reading on that thread and over in the Suspension forum. I didn't do the exact mod Rob talks about doing to the factory control arms but I did go with Porterbuilt Forward Arms that accomplish the same goal - ill post up more on that later
Old 04-14-2013, 12:01 PM   #19
RRC
RRC's Avatar
Nice work....truck looks great!!!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 04-14-2013, 12:05 PM   #20
RdoubleU
RdoubleU's Avatar
So after reading the Make It Handle Thread and other posts on suspension/handling I decided I was going to move forward and do it right the first time
Next step was to remove the bed, clean and prep the frame and put some chassis black on it
Old 04-14-2013, 12:07 PM   #21
longbed67
longbed67's Avatar
Looking back I should have taken your approach! I definitely took the overbuild approach! I'll follow this!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-14-2013, 07:49 PM   #22
1lo67
1lo67's Avatar
Looking Good
1lo67 is offline   Reply With Quote
Old 04-15-2013, 09:57 AM   #23
67cheby
67cheby
67cheby's Avatar
love the truck
67cheby is offline   Reply With Quote
Old 04-15-2013, 03:26 PM   #24
jae
Nice. I just saw a pic of your truck pop up on my Facebook timeline today, believe it was posted by Pro Performance.
Looks good. I'm in to follow the rest of your updates.
jae is offline   Reply With Quote
Old 04-16-2013, 01:40 PM   #25
RdoubleU
RdoubleU's Avatar
Neat little truck!
Originally Posted by longbed67 View Post
I'll follow this!
Originally Posted by 1lo67 View Post
Looking Good
Originally Posted by 67cheby View Post
love the truck
Thanks Guys, I appreciate it
Once I was done painting the frame and under the cab, next issue was to address my front pinion seal on the axle leaking
So Since I had to tear the entire axle down that lead to:
- Moser 5 Lug axle swap
- All new bearings and seals throughout
- Richmond 3.42 gears
- Eaton Posi
All done so I shouldn't have to touch that axle again for awhile
I followed this How To for the rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=484897
