Old 01-07-2011, 01:45 AM   #1
69C-owner
Re: 69 LWB Fleet Build thread "The Beast"
Ok I'm between the Boss 338 and the Coy C55, still havnt looked at any TT's yet, still lookin but so far those are the two I'm most interested and looks wise im kinda drawn to the C55, I guess it all just comes down to money and how complicated it is to make them work, basically the same design.
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 01-07-2011, 01:52 AM   #2
67chevy1series
67chevy1series's Avatar
i think coys i always loved the coys more then the boss
67chevy1series is offline   Reply With Quote
Old 01-07-2011, 02:06 AM   #3
69C-owner
Yeah if I can find a set of C55's in a size I like I'll go with those cuz I like those better that the 338's and alot better than all the TT's I see and with the TT's I cant really find a price and the bolt patterns are measured in millimeters which is weird as h(*l, i mean we're all used to 5 on 5 5x5 5x4 3/4 not 5x132.465
1994 GMC Sonoma
Old 01-07-2011, 02:10 AM   #4
67chevy1series
i agree 100%
Old 01-07-2011, 02:22 AM   #5
69C-owner
I just got on the Coys site and they made me happy, regular bolt pattern terms, decent prices, looks like you pay for what you get, not way over priced like "DONK" wheels, I've never really been a guy that liked anything huge, nothin over a 17 really, I plan to lower "The Beast" about as low as you can without C-notching, I might put a mini notch in by just cutting enough that the axle tubes will tuck up in the frame and I'll also put a dropmember in up front but deffinatley not a full C-notch so idk if 17 will be big enough to look right, the widest rim they have that I see is a 17x9.5, if I go that route with 17x9.5s in the rear what would look better up front 17x8's or 17x7's or maybe even put 17x9.5's at all 4 corners?
1994 GMC Sonoma
Old 07-26-2011, 11:06 AM   #6
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Just want to post a few things to get facts straight.
350 Pontiac's are more expensive to build than 400's because of piston and ring prices, otherwise they are the same.
Stock Pontiac motors make torque in huge amounts that no stock small block Chevy can without expensive mods, but the 1st gen small blocks and Pontiac's are as different as night and day.
There are cast in numbers on the side of the block such as "400" or "350" or "455".
The center exhaust port cast numbers tell you what heads you have. A 350 Pontiac will limit what heads you can use unless you are lucky enough to have a notched block.
Headers are no problem as long as you don't have one of the few heads that were manufactured without end exhaust bolt holes. Not a deal buster but something to consider.
Factory cast iron headers are around and flow well.
700r4 will NOT bolt to a Pontiac but the good news is a TH400 and a 3.42 gear can put your truck on the road and get decent gas mileage and the Buick Grand National 200-4R will live behind a street Pontiac.
Pontiac is a LOW rpm motor compared to a mouse motor and high gears are NOT necessary. My 68 firebird ran a best 11.44 with a 3.55 gear. Something to consider.
I have been building Pontiac motors for a long time and have gathered information that I am happy to share freely.
I had a BBC in my 67 GTO that I ran for a season but pulled it out because it wasn't as good a motor as my 474 inch Pontiac.
I am not slamming Chevy, they are fine for what they are, it's just that I love to be different and have no problem helping others improve their trucks too.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 09-19-2011, 03:42 AM   #7
69C-owner
No question that its a pontiac, almost totally positive its a 350 and knowing myself Ill build it
1994 GMC Sonoma
Old 09-19-2011, 04:06 AM   #8
67chevy1series
been awhile since you logged on!
Old 09-19-2011, 07:58 AM   #9
66-PMD-GMC
66-PMD-GMC's Avatar
Right on dude!
Pontiacs Rock and so do the people that build them!
Projects..
440CID 2X4 Pontiac
Old 09-25-2011, 12:07 AM   #10
69C-owner
No doubt Rick its been too long, been a prisoner to walmart aka work and been down with the buick fever but I'm gettin back to the board and slowly makin progress on the truck and thanks for the support PMD
1994 GMC Sonoma
Old 09-25-2011, 03:40 AM   #11
69C-owner
Almost forgot to say that someone has started stripping the 67, the broke part of the shroud and took the radiator along with some wiring that they cut out, well i got the shroud and radiator mounts, my dad got the name and phone number of the woman who owns the land that the truck is sitting on, lost the info, trying to get it again cuz there used to be an astro van sitting there and its gone now and I'm guessing this lady is gonna say haul that old truck off of my land and ill be hugging that old woman thinking "do u know how low the production numbers are on that truck"
1994 GMC Sonoma
Old 01-22-2012, 09:21 PM   #12
66-PMD-GMC
66-PMD-GMC's Avatar
My advise, for what it is worth, pull the tank and flush it out, replace the rubber line between the tank and hardline and between the fuel pump and hardline. In fact, blow out the metal lines all together. Replace the filter if you have one, between the carb and fuel pump and don't forget that there is a filter in the carb too.
A 650 cfm is the biggest carb you will need for that big "poncho" motor your sporting.
Shoot me a PM and let me know what heads you have on that 350 and I can give you some cam choices.
This is the triple D setup my best friend and I put on his 474 inch motor we put in his 66 GTO and a dual quad setup that has been my signature setup for about 20 years.
Pontiac motors get me fired up!
Projects..
440CID 2X4 Pontiac
Old 01-29-2012, 07:53 PM   #13
69C-owner
Got the drivers side of the cab cleaned up so I can sit in there again and start moving the truck around my yard som. Been sitting there for no reason for too long. Recently got a shed so its time to move it close to the shed and clean out the cab and bed so the cab is clean, the bed has as little in it as possible and i can pull the seat and tank and flush out the tank, put the tank and seat back in, and put a few gallons of gas in it. Got a good fuel filter to put on it and plenty of trans fluid. Need to get a front and rear trans seal and a pan gasket
1994 GMC Sonoma
Old 01-29-2012, 08:03 PM   #14
66-PMD-GMC
66-PMD-GMC's Avatar
Sounds like a good plan
Projects..
440CID 2X4 Pontiac
Old 01-29-2012, 08:12 PM   #15
69C-owner
Thanks PMD, from ur sig I'm guessin ur real name is Chris, with stock maifolds, crushed rusty mufflers and a little staight pipe the old pontiac still sounds mean lol
1994 GMC Sonoma
Old 01-29-2012, 11:59 PM   #16
66-PMD-GMC
66-PMD-GMC's Avatar
Yes, I am Chris, the worlds biggest Pontiac fanatic.
Nothing sounds better than old Pontiac Iron...
Projects..
440CID 2X4 Pontiac
Old 01-30-2012, 04:51 AM   #17
69C-owner
Well I guess what I'd like to have in one post will become three cuz im being lazy, using my phone and i dont feel like writing down long web adresses, well anyway i have 3 radiators and 2 fan assemblies laying around from a few vehicles that sadly got crushed, one fan assembly is a dual :-D the other is a single with the the brackets hanging off of it, you know the electric fan that kinda looks like a spider, yeah one of those. Well here is the first link; 2001 chevy venture minivan
http://www.autozone.com/autozone/par...1813_266534_0_
My question is willl any of these radiators (links for the other two will be up soon) along with any of the fans i have (guessing probably the dual setup) cool the pontiac well enough to drive the truck daily and sit in traffic or even just well enough to drive around town every now and then and not worry about overheating in the summer
1994 GMC Sonoma
Old 01-30-2012, 05:04 AM   #18
69C-owner
Radiator number 2, 1987 S10 Blazer
http://www.autozone.com/autozone/par..._0_1277%2C5603
1994 GMC Sonoma
Old 01-30-2012, 05:13 AM   #19
69C-owner
And lucky radiator number 3, 1995 Buick Roadmaster stationwagon, yep an LT1 car
http://www.autozone.com/autozone/par..._266534_0_5603
1994 GMC Sonoma
Old 01-30-2012, 05:18 AM   #20
69C-owner
Looking at cooling capacity and deminsions with all 3 of these, I know none of them are 4 cores, I have a big monsterous 4 core in the truck now thats way too wide to fit into the core support so I just want somethin that will fit and do its job whether it be radiator and mechanical fan or rad and electric fan or both fans, which with running one of these three radiators i believe there will be room for the mechanical clutch fan and the dual electric fan setup i have from the minivan
1994 GMC Sonoma
Old 01-30-2012, 09:12 AM   #21
66-PMD-GMC
66-PMD-GMC's Avatar
There is no real difference in cooling the Pontiac over a chebby V8. There are things to look at if you have cooling problems with the motor on a Pontiac. If you aren't using a high efficiency radiator and you are using the copper stock job, you will be better off with a 4 row than anything else. Putting on a thermostatically controlled electric fan helps a lot.
Of course everything needs to be in good working order to begine with.
Projects..
440CID 2X4 Pontiac
Old 02-02-2012, 11:04 PM   #22
69C-owner
no idea when ill be able to buy the things i have planned for the truck but the best deak ive found on a radiator that i like is a 4 core Murray copper/brass from oreilly for $180 and as far as cleaning up my wiring im eventually gonna get a painless performance kit made just for 67-72s, gotta clean up my offenhauser intake and find a good 650 cfm, finally decided pn just a single four barrel, thats another dream until funds are available, id say a 650 vaccum secondary with electric choke is my best bet at runnin how i want it to and being convenient
1994 GMC Sonoma
Old 02-02-2012, 11:18 PM   #23
66-PMD-GMC
66-PMD-GMC's Avatar
OK, where are the photos?
lol
Projects..
440CID 2X4 Pontiac
Old 02-02-2012, 11:50 PM   #24
69C-owner
Yay page 5!!!!!!!!!!!!! Chris I agree I need some pics, working from a pc that isnt mine and my cell phone well lack of a cell phone right now, lol got a loner phone till the 18th, should have pics of the radiator intake and wiring harness up soon, radiator and wiring harness sooner than the intake and even pics of a carb.......and along with all of these promised pics ill throw in some of the monster radiator and some of the truck before and after a good cleaning, remember radiator carb and wiring harness are dreams as of now but well thought out plans too lol, now comes a question Chris, I have 6X heads, found the boss on both heads where 4 is supposed to be, can see or feel a 4 on either head, looks and feels smooth, does that mean i have something different than "6X-4" heads???
1994 GMC Sonoma
Old 02-02-2012, 11:55 PM   #25
69C-owner
as promised some pics
1994 GMC Sonoma
