Old 01-10-2011, 09:06 PM   #1
502ss
502ss's Avatar
Gas filler option when moving tank to rear of truck
For those of you that have forgone saddle tanks and instead installed a suburban tank between the frame rails what have you done for a filler? I really don't want to have the filler come up through the floor so I was thinking of installing one of these doors on the outside of the body and building the filler neck to go behind it. The door would be located behind the dually fender on the drivers side.
I am open to other options?
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 01-10-2011, 09:23 PM   #2
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: Gas filler option when moving tank to rear of truck
The kit I got from Transfer Flow allowed the use of the original fill pipe on the passenger side of my square. It's still a long process and a pain in the neck to put gas in my truck.
78 Big10 454 is offline   Reply With Quote
Old 01-10-2011, 09:49 PM   #3
BigRed76
BigRed76's Avatar
I posted a thread about this in the blazer/suburban forum, with not much luck yet. What I had in mind was cutting out the stock fuel door from another square body and having it welded in place in the rear, and then plumb the filler tube right up to the fuel door. I am still open for ideas too because my idea does involve a decent amount of bodywork.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-10-2011, 10:36 PM   #4
502ss
502ss's Avatar
This is exactly what I want to avoid! I did all the measurements and I just don't have enough of a downward angle to maintain a good flow of fuel! I fear it would be burping all the time and would take forever to fill up!
Old 01-10-2011, 10:37 PM   #5
502ss
502ss's Avatar
I thought that also but I am trying to avoid a lot of body work! In addition I already have two doors now from my dual saddle tanks!
Old 01-10-2011, 10:42 PM   #6
BigRed76
BigRed76's Avatar
I understand not wanting to go through the bodywork. I have also seen people route the filler up behind the tail light, so that the whole light assembly opens on a hinge to access the filler, but I havent found any results of how well they worked or how the wiring worked out...
Zach
Old 01-10-2011, 11:37 PM   #7
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Put it behind the taillight
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-11-2011, 02:02 AM   #8
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Good example, what about boxing it into the inside of the bed behind a wheel well? Is there clearance for the filler tube between the box and the top of the tank?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-11-2011, 07:39 PM   #9
DBLSPRT68
DBLSPRT68's Avatar
I thought of actually cutting out the Suburban filler and placing it on my truck in the same place? Just forward of the tail light. I haven't researched this at all, but I have a Suburban and a truck, so I have everything I need.....ecept a welder and welding skills!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 01-11-2011, 07:48 PM   #10
ghettoluxury
ghettoluxury's Avatar
A rear mounted tank was offered in the 75-81 pickups and is filled from the rear at the plate. LMC carries the tank, sending unit, and the straps.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-11-2011, 08:32 PM   #11
SeanPaintsFlames
SeanPaintsFlames's Avatar
There are these pre-fabbed pieces:
http://www.hotrodhardware.com/index....od/prd2266.htm
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 01-11-2011, 08:53 PM   #12
502ss
502ss's Avatar
Took the drivers side tail light out and I think behind the tail light is going to work pretty easily. I will need to make a custom filler tube and fabricate a hinge for the light assembly but the initial look is this shouldn't be to bad!
Old 01-11-2011, 09:41 PM   #13
joe231
joe231's Avatar
What "plate" are you referring to?
Not the license plate I'm guessing?
It is lower than the top of the gas tank.
Also can you tell me where you got the info?
To my knowledge, there were no rear tanks in any of the square pickup trucks (from the factory) just blazers and burbs.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-11-2011, 10:06 PM   #14
BigRed76
BigRed76's Avatar
To my knowledge there, were no rear tanks in any of the square pickup trucks (from the factory) just blazers and burbs.
I would also like to hear more about this
Zach
Old 01-11-2011, 10:39 PM   #15
bigblock73
yeller
bigblock73's Avatar
I think LMC has some wrong info there, I never heard of a rear mounted and filled tank on any 73-87 pickup either.
That could be a retrofit kit they are offering.
bigblock73 is offline   Reply With Quote
Old 01-12-2011, 02:10 PM   #16
burger
BTT... I'd like to know more about this rare rear tank option...
burger is offline   Reply With Quote
Old 01-12-2011, 02:16 PM   #17
Goldfinger
Goldfinger's Avatar
I'd place it behind the licence plate like a caprice. Just adapt the part into the existing bumper.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 01-13-2011, 06:35 PM   #18
502ss
502ss's Avatar
For those of you that thought a license plate mounted filler would work I can't see how. This is a burb tank, you can see where the filler neck exits. Even if you relocated the filler neck you would have to mount the tank really low so the top of the tank fell in the middle of the license plate.
Old 01-13-2011, 06:38 PM   #19
502ss
502ss's Avatar
Plenty of room for a gas nozzle and room to spare for the light assembly. This will be a cool mod!
Old 01-13-2011, 07:25 PM   #20
joe231
joe231's Avatar
Right on the money 502ss,
I almost have my tail light filler worked out, just need to build a hinge (I'm a procrastinator )
CHEVY ONLY
Old 01-13-2011, 07:28 PM   #21
Goats86
When you figure out the hinged tail light, make 2 so I can get one!
Goats86 is offline   Reply With Quote
Old 01-13-2011, 07:56 PM   #22
joe231
joe231's Avatar
I got it figured out in my head, just need to make it reality
CHEVY ONLY
Old 01-13-2011, 08:05 PM   #23
Keith Seymore
Keith Seymore's Avatar
There was a rear mount location for the cab & chassis models (aka pickups with no box). I wonder if that's what LMC is showing.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 01-13-2011, 08:41 PM   #24
502ss
502ss's Avatar
I think I might modify the hinge used for a bed gas door. I need to take a close look at the hinge to see if I have the clearance
Oh btw.....
Let's see some pics of what you have done!
Old 11-19-2013, 09:01 PM   #25
cst 72 blazer
cst 72 blazer's Avatar
I love this thread!im putting a blazer tank in a 87 swb with blazer brackets and have been worried about the filler as well
Chris Heinz
cst 72 blazer is offline   Reply With Quote
