01-10-2011, 10:40 PM | #1 |
Tire size for Rally rims
Well guys time to lower the Blue Heeler. Just bought some new 15x8 rally
need to know what tires you guys could recommend on a 4 inch lowering kit. thank. Steve |
01-10-2011, 10:44 PM | #2 |
Re: Tire size for Rally rims
275/60r 15 , is about all you can get under it without any more mods, might be a little tight on the front, fender might come down on the wheel with a four inch drop.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-10-2011, 11:06 PM | #3 |
Resistance is Futile
I'd consider the rear end ratio if you're planning on a lot of driving. A taller tire mite help a bit. On my bagged 'burb I ran 295/50/15's and 255/60/15's. With the '66 LB I went with 235/70/15's all around.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-10-2011, 11:09 PM | #4 |
Good point protrash, I`m running 373, just buzzing the motor to death..!
01-10-2011, 11:50 PM | #5 |
Which lowering kit are you running? and are those 15x8 on there? the kit i'm looking at is 4"drop in rear x 3"drop in front does that make sense.
01-11-2011, 02:51 PM | #6 |
Im running 245 60 r 15 with 15x8 ralleys 4inches in front and 5 inches so far in rear no problems so far
01-11-2011, 03:34 PM | #7 |
1962 C-10
The '65 has a 2/4 drop. Running 15x7's in the front with 245/60's and 15x8's in the rear with 275/60's.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
01-11-2011, 04:28 PM | #8 |
Slots go on anything!
I have 255/70's on an 8" rally on my '74. It helps fill the fender well. Mine is a little lower though.
1974 Jimmy- 5.3/4L80e/NP241 |
01-11-2011, 09:39 PM | #9 |
3/5 drop, 8x15 rims, 275/60 r 15 all four corners.
01-11-2011, 10:04 PM | #10 |
01-11-2011, 10:13 PM | #11 |
Are you running power steering,? If your not going any lower than mine 15x8 is fine, lower and I would step down to a 7, only because of the interferance issue while turning into a steep driveway for instance.
01-11-2011, 10:17 PM | #12 | |
boggler trying to figure out how to do this with out buying a bunch of stuff that i'm gonna regret purchasing. thanks and thank:{ |
01-11-2011, 11:07 PM | #13 |
Are you sure it's 373?? I thought a 275/60/15 was at least 28'' tall; I considered that size before deciding on the 70's series and narrower tires.
01-11-2011, 11:36 PM | #14 |
Yes I`m pretty sure it is, going by the numbers that were on the housing some many years ago, I`m into thrd gear (turbo 350 ) standard 2 lane intersection before I even clear it...
01-12-2011, 11:40 AM | #15 | |
steering pump and gearbox just need to get the hoses. Thanks for the help!!! |
01-12-2011, 11:57 AM | #16 |
I run the same gears but with a 700r4 25% reduction in rpms look at making the 700r4 your next mod.....Kieth
01-12-2011, 05:13 PM | #17 |
265/70/15 on 15x8 rallye-rear
255/70/15 on 15x7 rallye-front I have to watch sharp turns and driveways, the fronts rub, 4/5 drop.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
01-12-2011, 10:24 PM | #18 |
That was the plan in `93 when I first did the make over, well just never got around to it always too many projects in the fire..
01-15-2011, 01:35 AM | #19 |
Anyone got anything lower?
01-15-2011, 10:26 AM | #20 |
Dont understand?? Lower suspension? My 'burb is bagged and my LB '66 is lowered 4/4. Tire sizes in previous post.
01-15-2011, 10:53 AM | #21 |
01-15-2011, 12:57 PM | #22 |
01-15-2011, 06:24 PM | #23 |
Om my 62 I'm running 15x8's with 305/50R/15's on the rear , 235/60R/15's on the front ... Gonna go to the 275/60R/15's on the rear after these tires wear out ... Good Luck with your choice ....
01-15-2011, 10:05 PM | #24 |
275 50 15 look like a custom centering job on the rallies. I would not mind going a 1/2 " narrower. but if you change any aspect on these metric tires everything is changed. I do not understand how it is better than dimension tall x dimension wide x rim diameter. thats like everything there is to know about tire size in a few simple numbers. or we can resort to the algebra [widthXaspectx2] /2550+rim diameter. for the height and w/25.50 for the width. for those that prefer the hard way. stupid. I found an online calculator a few years ago that would give you the rpm and effective gear ratio with a given size tire. my 275/60/15 with 3.50 came out to the equevalent of 4.10 with stock tire diameter. not terrible but not 75mph either. especially with flowmasters. those had to go.
01-15-2011, 10:24 PM | #25 | |
a tire that fit under there, it's kinda tuff trying to deside. |
