Old 01-14-2011, 09:24 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Idea, can it be done?
they do fit, the center hole is a tick tight, a quick buz with a grinder would fix that, otherwise a sledgeis frequently needed to remove the wheel from the hub. The back spacing issue isn't nearly as bas as the 99 to date trucks, but they are tucked in a little further than stock. I had 275 width tires on a set of those rims and they were a bit too wide, but do-able... I think a 285 would be too much.
