Old 01-16-2011, 05:31 AM   #1
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Air Intake, what are you guys using on your swaps?
Well I'm sure theres a couple other threads about this but I just can't seem to figure out what air intake would work/look good under the hood of my truck. I've always just had a 90 degree tube with the MAF and air filter off the end of it. First it doesn't look good and second the super hot air from the Efans blows right into it. Not good for the IAT's I'm sure.
Here's a pic of the intake right now, I was think of running a intake tube with a box on the end over to the drivers side behind the core support.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-16-2011, 05:46 AM   #2
skoffice
skoffice's Avatar
Re: Air Intake, what are you guys using on your swaps?
Great looking engine bay!!! I'm just starting on mine and have a near identical setup in mind but was going to use some black 4" drain pipe, the PVC type not the flexi garbage, and put it over to the corner like you said. I was thinking of cutting some kind of hole in the core support out of sight and behind the headlight sort of. Not to poke the filter into but just so it can get direct cool airflow. Damn your engine looks nice man
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 01-16-2011, 06:09 AM   #3
harnalien
TruckincrazY
harnalien's Avatar
Hmm, I actually liked yours or one with just the filter. I didn't really think about the heat issue though.
My build thread - '84 2wd w/ a 6.0 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=433595
harnalien is offline   Reply With Quote
Old 01-16-2011, 06:14 AM   #4
matthew20061
69' Chevy Stepside
Well its not too bad but I just don't like the angle it has to sit at because it hits the belt tensioner if not tipped up at that angle and the heat issues.
-Matthew
Old 01-16-2011, 06:19 AM   #5
matthew20061
69' Chevy Stepside
Thanks! That sounds like it could work with the PVC, but I can't picture how it would look. I'm sure it could be done right and look good!
-Matthew
Old 01-16-2011, 05:44 PM   #6
matthew20061
69' Chevy Stepside
So anyone have any pictures of there intakes? I know there has to be some...
-Matthew
Old 01-16-2011, 09:47 PM   #7
67C10BUB
67C10BUB's Avatar
This one is a Spectra kit I got from Pep Boys. It is P# 9900. I took the straight piece and flipped it backwards (from its normal install position) and then cut off the mount to make it bolt to the radiator hold-down bracket.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 01-16-2011, 10:42 PM   #8
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I used the 9900 Spectre also, but moved the batt to the opposite side.
See it here it is a later truck how ever.
http://67-72chevytrucks.com/vboard/s...d.php?t=421589
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 01-17-2011, 01:17 AM   #9
matthew20061
69' Chevy Stepside
I like the looks of that, epically because I just checked with the O'Rilleys store and they've got one. might pic that up tomorrow!
-Matthew
Old 01-17-2011, 01:25 AM   #10
skoffice
skoffice's Avatar
I like that too. If I hadn't already started on mine I would have probably gotten it! Looks sweet!
Old 01-17-2011, 09:28 AM   #11
Shon
Here's mine
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 01-17-2011, 11:54 AM   #12
harnalien
TruckincrazY
harnalien's Avatar
Originally Posted by Shon View Post
Here's mine
That's another one I like, do you know what the part number is for that?
Old 01-17-2011, 11:58 AM   #13
Shon
just went to Advance Auto and picked up a universal filter from Spectre, it fits 3-4" tubes with inserts.
NOTE: I am running Speed Density, no MAF. the MAF that came with this junk yard van motor was about 5-6" long so it would not fit between TB and radiator. probably have better chance with a 'regular' MAF but I like the SD stuff, one less sensor to mess up.
Old 01-18-2011, 12:23 AM   #14
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
what radiator are you using? I like how the piping looks.. real clean looking.. mine goes to the passenger side over the upper hose... looks ok, but I think it would look good if it went over to the side with no battery. I dont know if the inlet on the upper radiator will be in the way or not... I havent opened my hood recently.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 01-18-2011, 12:25 PM   #15
67C10BUB
67C10BUB's Avatar
clint
I am using the original 4 row radiator. I think mine is routed exactly as you are saying.
67 5.3L Build
Old 01-19-2011, 12:32 AM   #16
TR65
TR65's Avatar
Here is one way,
Here is the thread,
http://67-72chevytrucks.com/vboard/s...d.php?t=412824
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 01-19-2011, 12:34 AM   #17
Pop's C-10
Pop's C-10's Avatar
Originally Posted by TR65 View Post
Here is one way,
Here is the thread,
That look good
Pop's C-10 is offline   Reply With Quote
Old 01-19-2011, 02:35 AM   #18
matthew20061
69' Chevy Stepside
Wow that's quite the air cleaner, pretty classic!
-Matthew
Old 02-05-2011, 06:23 AM   #19
eagleuh1
eagleuh1's Avatar
Hers mine. 2 90 deg big truck steel elbows welded together. Used rubber unions from intakeelbows.com with band clamps from same. Cut hole in core support next to headlight to let in cool air. Battery moved to drivers side.
eagleuh1 is offline   Reply With Quote
Old 02-08-2019, 02:48 PM   #20
69ls4.8swap
Hey there. Just ran across your thread on your cold air intake and was wondering what top rad hose you used? I'm also using factory 4 core
69ls4.8swap is offline   Reply With Quote
Old 02-08-2019, 10:16 PM   #21
mongocanfly
mongocanfly's Avatar
That's gonna depend alot on what truck,radiator,and engine you have...more Info please
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-11-2019, 07:08 PM   #22
e015475
e015475's Avatar
Here's mine in a '49 GMC
The other side
Laid out on the shop floor. Still a little tight with a MAF, but I may go speed/density so it won't matter anyway
e015475 is online now   Reply With Quote
Old 02-12-2019, 09:55 AM   #23
Wgesnerjr
Wgesnerjr's Avatar
I used the original LS one for a while but noticed the baffled silencers hit the fan shroud and kicked the whole thing up a little.
So I found this cheap kit on eBay for $49 an decided to use just the main tube and rubber couplers. I like the stock air box better than the open filter so I merged the two together. Clears the mechanical fan as well.
Happy with the results but do not like the shiney pipe. Will probably have powder coated satin black soon.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 02-12-2019, 09:59 AM   #24
Wgesnerjr
Wgesnerjr's Avatar
I have also started modifying the stock one. Cut off the baffled silencers and started fiberglassing up the holes.
Might go back to this one if it turns out good enough.
Jay Gesner
Atlanta, GA
LS 5.3, 4L60E
Old 02-12-2019, 10:59 AM   #25
Rich84
Rich84's Avatar
Is that a kit for a Silverado? How tight is that elbow? I had to remove my upper shroud because there is not enough room with the factory setup. My engine is slid forward to allow room for the A/C in the lower position. D.D sliders almost all the way forward.
Rich84 is online now   Reply With Quote
