Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-10-2011, 12:01 AM   #1
SlickSierra77
SlickSierra
SlickSierra77's Avatar
What do you guys suggest?
Hey guys I just purchased a 355 motor minus the top end, Im looking for mid 400hp range and I was wondering what you guys suggest as far as heads and top end and if I should swap the cam for something else. I got a really good deal on this freshly built motor all parts are brand new and it even came with all receipts from the machine shop.
The brand new internals consist of Speed pro pistons #8KL2490F, Eagle ESP Crankshaft #435034805770, Eagle ESP Rods 356CRS5700B3D length 5.7, Edelbrock RPM Cam kit #7102, Pro Comp Billet timing gear double roller #220, oil pan studs, CV steel oil pan and timing cover, Melling HP oil pump, Speed pro rod and main bearings.
Thanks for any help and here is a pic for ya
'77 GMC Sierra 2wd SWB 355SB, TH350
SlickSierra77 is offline   Reply With Quote
Old 01-10-2011, 01:14 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: What do you guys suggest?
How big is your budget? AFR aluminum heads are top of the line. Next are other aluminum heads. Machined Vortec and stock Vortec heads being last. Check with Edelbrocks website. Run the cam ID number. Check the heads they used for tests.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-10-2011, 01:15 AM   #3
chevytruck1970
chevytruck1970's Avatar
does your trans have a stall? what rear gears will you be running?
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 01-10-2011, 01:24 AM   #4
Ont67shortbox
check out Patriot heads
Ont67shortbox is offline   Reply With Quote
Old 01-10-2011, 02:00 AM   #5
SlickSierra77
SlickSierra
I've got a decent budget but I'm not sure about afr $1500 heads lol. I've got a th350 transmission recently built with a shift kit I'm waiting to purchase a stall until i purchase a cam. I've got 3.73 gears in the rear.
Old 01-10-2011, 03:39 AM   #6
mongoose
mongoose's Avatar
yeah the patriots would get you to mid 400's... you can slap on some ik180's for a bit more.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-10-2011, 08:49 AM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
All I'm gonna say is HEADS is where the power is made. Nothing else in your list of parts means anyting if you don't choose a head that will support the power level your looking for. A set of decent heads, and a good hydraulic / solid roller cam package to support what your wanting to do is going to be in the $2500 - $3500 range when it's all said and done. Don't fool yourself.
You can get that magic 400HP # with a set of Edelbrock RPM heads,, and a flat tappet cam. But it will hit your peak HP at a higher RPM range, and have less drivability in the lower / mid RPM range. That's the trade-off for a big peak HP number of a tighter budget.
gchemist and I agree 100%, one of the best out of the box heads on the market to meet your goal is the AFR line. You get what you pay for. Not some fluffed up flow number advertised to sell a pig in a fancy dress. When AFR says a head flows 280, you can take it to ANY reputable flow bench and it flows 278-285. Broxdix, Dart, RHS / Patriot, GM, NO ONE will guarentee their advertised flow numbers to be +/- 1% like AFR will. That says volumes about their QC and product.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-11-2011, 08:28 PM   #8
chevytruck1970
couldn't agree more Marv
Justin
1.35 60ft
Old 01-14-2011, 10:29 AM   #9
team39763
AFR also has a very nice warranty on their heads too...I believe it's a lifetime warranty.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 02-02-2011, 08:53 PM   #10
oldschool53_BBC
oldschool53_BBC's Avatar
Amen..Heads make the deal as long as the supporting cast is in place, cam headers etc..
HP cost if you want it to last....
1953 BBC 3100
427 T-400 12 Bolt
Al
oldschool53_BBC is offline   Reply With Quote
Old 02-03-2011, 12:23 AM   #11
Rodms
Rodms's Avatar
When you race it all warranty is void,you can check though,don't tell them I guess?
Built chevy tuff!
Rodms is offline   Reply With Quote
